- 07-Security Command Reference
- 01-AAA Commands
- 02-802.1X Commands
- 03-MAC Authentication Commands
- 04-Portal Commands
- 05-Port Security Commands
- 06-User Profile Commands
- 07-Password Control Commands
- 08-Public Key Commands
- 09-PKI Commands
- 10-SSH2.0 Commands
- 11-SSL Commands
- 12-TCP and ICMP Attack Protection Commands
- 13-ARP Attack Protection Commands
- 14-FIPS Commands
- 15-IPsec Commands
13-ARP Attack Protection Commands | 124.16 KB |
ARP attack protection configuration commands
ARP defense against IP packet attacks configuration commands
display arp source-suppression
ARP packet rate limit configuration commands
arp rate-limit (interface view)
Source mac address based ARP attack detection configuration commands
arp anti-attack source-mac aging-time
arp anti-attack source-mac exclude-mac
arp anti-attack source-mac threshold
display arp anti-attack source-mac
ARP packet source mac address consistency check configuration commands
arp anti-attack valid-ack enable
ARP active acknowledgement configuration commands
arp anti-attack active-ack enable
ARP detection configuration commands
display arp detection statistics
reset arp detection statistics
ARP gateway protection configuration commands
ARP filtering configuration commands
arp resolving-route enable
undo arp resolving-route enable
View
Default level
2: System level
None
Use arp resolving-route enable to enable ARP black hole routing.
Use undo arp resolving-route enable to disable the function.
By default, ARP black hole routing is disabled.
# Enable ARP black hole routing.
[Sysname] arp resolving-route enable
arp source-suppression enable
undo arp source-suppression enable
View
Default level
2: System level
None
Use arp source-suppression enable to enable the ARP source suppression function.
Use undo arp source-suppression enable to disable the function.
By default, the ARP source suppression function is disabled.
Related commands: display arp source-suppression.
# Enable the ARP source suppression function.
[Sysname] arp source-suppression enable
arp source-suppression limit
undo arp source-suppression limit
View
Default level
2: System level
limit-value: Specifies the maximum number of packets with the same source IP address but unresolvable destination IP addresses that the device can receive in five seconds. It ranges from 2 to 1024.
Use arp source-suppression limit to set the maximum number of packets with the same source IP address but unresolvable destination IP addresses that the device can receive in five seconds.
Use undo arp source-suppression limit to restore the default value, which is 10.
With this feature configured, whenever the number of packets with unresolvable destination IP addresses from a host within five seconds exceeds the specified threshold, the device suppresses the sending host from triggering any ARP requests within the following five seconds.
# Set the maximum number of packets with the same source address but unresolvable destination IP addresses that the device can receive in five seconds to 100.
[Sysname] arp source-suppression limit 100
display arp source-suppression [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display arp source-suppression to display information about the current ARP source suppression configuration.
# Display information about the current ARP source suppression configuration.
<Sysname> display arp source-suppression
ARP source suppression is enabled
Current suppression limit: 100
Current cache length: 16
ARP source suppression is enabled |
The ARP source suppression function is enabled. |
Current suppression limit |
Maximum number of packets with the same source IP address but unresolvable destination IP addresses that the device can receive in five seconds. |
Current cache length |
Size of cache used to record source suppression information. |
arp rate-limit { disable | rate pps drop }
undo arp rate-limit
View
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, WLAN-ESS interface view
Default level
2: System level
disable: Disables ARP packet rate limit.
rate pps: ARP packet rate, ranging from 5 to 3072 pps.
drop: Discards the exceeded packets.
Use arp rate-limit to configure ARP packet rate limit on an interface.
Use undo arp rate-limit to restore the default.
By default, ARP packet rate limit is disabled.
# Specify the ARP packet rate on GigabitEthernet 1/0/1 as 50 pps, and exceeded packets will be discarded.
[Sysname- GigabitEthernet1/0/1] arp rate-limit rate 50 drop
arp anti-attack source-mac { filter | monitor }
undo arp anti-attack source-mac [ filter | monitor ]
View
Default level
2: System level
filter: Specifies the filter mode.
monitor: Specifies the monitor mode.
Use arp anti-attack source-mac to enable source MAC address based ARP attack detection and specify the detection mode.
Use undo arp anti-attack source-mac to restore the default.
By default, source MAC address based ARP attack detection is disabled.
After you enable this feature, the device checks the source MAC address of ARP packets received from the VLAN. If the number of ARP packets received from a source MAC address within five seconds exceeds the specified threshold:
· In filter detection mode, the device displays a log message and filters out the ARP packets from the MAC address.
· In monitor detection mode, the device only displays a log message.
If no detection mode is specified in the undo arp anti-attack source-mac command, both detection modes are disabled.
# Enable filter-mode source MAC address based ARP attack detection.
[Sysname] arp anti-attack source-mac filter
arp anti-attack source-mac aging-time time
undo arp anti-attack source-mac aging-time
View
Default level
2: System level
time: Age timer for protected MAC addresses, in the range of 60 to 6000 seconds.
Use arp anti-attack source-mac aging-time to configure the age timer for protected MAC addresses.
Use undo arp anti-attack source-mac aging-time to restore the default.
By default, the age timer for protected MAC addresses is 300 seconds (five minutes).
# Configure the age timer for protected MAC addresses as 60 seconds.
[Sysname] arp anti-attack source-mac aging-time 60
arp anti-attack source-mac exclude-mac mac-address&<1-10>
undo arp anti-attack source-mac exclude-mac [ mac-address&<1-10> ]
View
Default level
2: System level
mac-address&<1-10>: MAC address list. The mac-address argument indicates a protected MAC address in the format H-H-H. &<1-10> indicates up to ten protected MAC addresses that you can configure.
Use arp anti-attack source-mac exclude-mac to configure protected MAC addresses which will be excluded from ARP packet detection.
Use undo arp anti-attack source-mac exclude-mac to remove the configured protected MAC addresses.
By default, no protected MAC address is configured.
If no MAC address is specified in the undo arp anti-attack source-mac exclude-mac command, all the configured protected MAC addresses are removed.
# Configure a protected MAC address.
[Sysname] arp anti-attack source-mac exclude-mac 2-2-2
arp anti-attack source-mac threshold threshold-value
undo arp anti-attack source-mac threshold
View
Default level
2: System level
threshold-value: Threshold for source MAC address based ARP attack detection, ranging from 10 to 100.
Use arp anti-attack source-mac threshold to configure the threshold for source MAC address based ARP attack detection. If the number of ARP packets sourced from a MAC address within five seconds exceeds this threshold, the device considers this an attack.
Use undo arp anti-attack source-mac threshold to restore the default.
By default, up to 50 ARP packets can be received from a MAC address within five seconds.
# Configure the threshold for source MAC address based ARP attack detection as 30.
[Sysname] arp anti-attack source-mac threshold 30
display arp anti-attack source-mac [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays attacking MAC addresses detected on the interface.
Use display arp anti-attack source-mac to display attacking MAC addresses detected by source MAC address based ARP attack detection.
If no interface is specified, the display arp anti-attack source-mac command displays attacking MAC addresses detected on all the interfaces.
# Display the attacking MAC addresses detected by source MAC address based ARP attack detection.
<Sysname> display arp anti-attack source-mac
Source-MAC VLAN ID Interface Aging-time
23f3-1122-3344 4094 GE1/0/1 10
23f3-1122-3355 4094 GE1/0/2 30
23f3-1122-33ff 4094 GE1/0/3 25
23f3-1122-33ad 4094 GE1/0/4 30
arp anti-attack valid-check enable
undo arp anti-attack valid-check enable
View
Default level
2: System level
None
Use arp anti-attack valid-check enable to enable ARP packet source MAC address consistency check on the gateway. After you execute this command, the gateway device can filter out ARP packets with the source MAC address in the Ethernet header different from the sender MAC address in the ARP message.
Use undo arp anti-attack valid-check enable to restore the default.
By default, ARP packet source MAC address consistency check is disabled.
# Enable ARP packet source MAC address consistency check.
[Sysname] arp anti-attack valid-check enable
undo arp anti-attack active-ack enable
View
Default level
2: System level
None
Use arp anti-attack active-ack enable to enable the ARP active acknowledgement function.
Use undo arp anti-attack active-ack enable to restore the default.
By default, the ARP active acknowledgement function is disabled.
This feature is configured on gateway devices to identify invalid ARP packets.
# Enable the ARP active acknowledgement function.
[Sysname] arp anti-attack active-ack enable
arp detection enable
undo arp detection enable
View
VLAN view
Default level
2: System level
None
Use arp detection enable to enable ARP detection for the VLAN.
Use undo arp detection enable to restore the default.
By default, ARP detection is disabled for a VLAN.
# Enable ARP detection for VLAN 1.
[Sysname] vlan 1
[Sysname-Vlan1] arp detection enable
arp detection trust
arp detection trust
undo arp detection trust
View
Layer 2 Ethernet port view, WLAN-ESS interface view
Default level
2: System level
None
Use arp detection trust to configure the port as an ARP trusted port.
Use undo arp detection trust to restore the default.
By default, the port is an ARP untrusted port.
# Configure GigabitEthernet 1/0/1 as an ARP trusted port.
[Sysname-GigabitEthernet1/0/1] arp detection trust
arp detection validate
undo arp detection validate [ dst-mac | ip | src-mac ] *
View
Default level
2: System level
dst-mac: Checks the target MAC address of ARP responses. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
ip: Checks the source and destination IP addresses of ARP packets. The all-zero, all-one or multicast IP addresses are considered invalid and the corresponding packets are discarded. With this keyword specified, the source and destination IP addresses of ARP replies, and the source IP address of ARP requests will be checked.
src-mac: Checks whether the sender MAC address of an ARP packet is identical to the source MAC address in the Ethernet header. If they are identical, the packet is considered valid. Otherwise, the packet is discarded.
Use arp detection validate to configure ARP detection based on specified objects. You can specify one or more objects in one command line.
Use undo arp detection validate to remove detected objects. If no keyword is specified, all the detected objects are removed.
By default, ARP detection based on specified objects is disabled.
# Enable the checking of the MAC addresses and IP addresses of ARP packets.
[Sysname] arp detection validate dst-mac src-mac ip
undo arp restricted-forwarding enable
View
VLAN view
Default level
2: System level
None
Use arp restricted-forwarding enable to enable ARP restricted forwarding.
Use undo arp restricted-forwarding enable to disable ARP restricted forwarding.
By default, ARP restricted forwarding is disabled.
# Enable ARP restricted forwarding in VLAN 1.
[Sysname] vlan 1
[Sysname-vlan1] arp restricted-forwarding enable
display arp detection [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display arp detection to display the VLANs enabled with ARP detection.
Related commands: arp detection enable.
# Display the VLANs enabled with ARP detection.
<Sysname> display arp detection
ARP detection is enabled in the following VLANs:
1, 2, 4-5
ARP detection is enabled in the following VLANs |
VLANs that are enabled with ARP detection |
display arp detection statistics [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the ARP detection statistics of a specified interface.
Use display arp detection statistics to display statistics about ARP detection. This command only displays numbers of discarded packets. If no interface is specified, the statistics of all the interfaces will be displayed.
# Display the ARP detection statistics of all the interfaces.
<Sysname> display arp detection statistics
State: U-Untrusted T-Trusted
ARP packets dropped by ARP inspect checking:
Interface(State) IP Src-MAC Dst-MAC Inspect
GE1/0/1(U) 40 0 0 78
GE1/0/2(U) 0 0 0 0
GE1/0/3(T) 0 0 0 0
GE1/0/4(U) 0 0 30 0
Interface(State) |
State T or U identifies a trusted or untrusted port. |
IP |
Number of ARP packets discarded due to invalid source and destination IP addresses. |
Src-MAC |
Number of ARP packets discarded due to invalid source MAC address. |
Dst-MAC |
Number of ARP packets discarded due to invalid destination MAC address. |
Inspect |
Number of ARP packets that failed to pass ARP detection (based on static IP Source Guard binding entries/DHCP snooping entries/802.1X security entries/OUI MAC addresses). |
reset arp detection statistics [ interface interface-type interface-number ]
View
Default level
2: System level
interface interface-type interface-number: Clears the ARP detection statistics of a specified interface.
Use reset arp detection statistics to clear ARP detection statistics of a specified interface. If no interface is specified, the statistics of all the interfaces will be cleared.
# Clear the ARP detection statistics of all the interfaces.
<Sysname> reset arp detection statistics
arp filter source
arp filter source ip-address
undo arp filter source ip-address
View
Layer 2 Ethernet interface view, WLAN-ESS interface view
Default level
2: System level
ip-address: IP address of a protected gateway.
Use arp filter source to enable ARP gateway protection for a specified gateway.
Use undo arp filter source to disable ARP gateway protection for a specified gateway.
By default, ARP gateway protection is disabled.
Note:
· You can enable ARP gateway protection for up to eight gateways on a port.
· You cannot configure both arp filter source and arp filter binding commands on a port.
# Enable ARP gateway protection for the gateway with IP address 1.1.1.1.
[Sysname-GigabitEthernet1/0/1] arp filter source 1.1.1.1
arp filter binding
undo arp filter binding ip-address
View
Default level
2: System level
ip-address: Permitted sender IP address.
mac-address: Permitted sender MAC address.
Use arp filter binding to configure an ARP filtering entry. If the sender IP and MAC addresses of an ARP packet match an ARP filtering entry, the ARP packet is permitted. If not, it is discarded.
Use undo arp filter binding to remove an ARP filtering entry.
By default, no ARP filtering entry is configured.
Note:
· You can configure up to eight ARP filtering entries on a port.
# Configure an ARP filtering entry with permitted sender IP address 1.1.1.1 and MAC address 2-2-2.
[Sysname-GigabitEthernet1/0/1] arp filter binding 1.1.1.1 2-2-2
