02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10102-WLAN Command Reference
02-WLAN Access Commands
02-WLAN Access Commands 221.48 KB
a-mpdu enable
Use a-mpdu enable to enable the Aggregated MAC Protocol Data Unit (A-MPDU) function for the radio.
Use undo a-mpdu enable to disable the A-MPDU function for the radio.
a-mpdu enable
undo a-mpdu enable
The A-MPDU function is enabled.
WLAN-Radio interface view
Default command level
2: System level
This command only takes effect on 802.11n radios.
If you change the radio type of an 802.11n radio, the default setting for this function of the new radio type is restored.
# Disable the A-MPDU function.
<sysname> system-view
[sysname] interface WLAN-Radio 1/0/1
[sysname-WLAN-Radio1/0/1] undo a-mpdu enable
a-msdu enable
Use a-msdu enable to enable the A-MSDU function for the radio.
Use undo a-msdu enable to disable the A-MSDU function for the radio.
a-msdu enable
undo a-msdu enable
The A-MSDU function is enabled.
2: System level
This command only takes effective on 802.11n radios. If you change the radio type of an 802.11n radio, the default setting for this function of the new radio type is restored.
The device only receives but does not send A-MSDU frames.
# Disable the A-MSDU function.
[sysname] interface wlan-radio 1/0/1
[sysname-WLAN-Radio1/0/1] undo a-msdu enable
ani enable
Use ani enable to enable the Adaptive Noise Immunity (ANI) function.
Use undo ani enable to disable the ANI function.
ani enable
undo ani enable
ANI is enabled.
2: System level
After the ANI function is enabled, the device automatically adjusts the noise immunity level according to the surrounding signal environment to eliminate RF interference.
# Disable ANI.
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio 1/0/1] undo ani enable
antenna type
Use antenna type to specify the antenna type.
Use undo antenna type to restore the default.
antenna type type
undo antenna type
The default antenna type is internal for WA4620i-ACN and WA4300 series and Ext-Def for WA4620E-ACN.
2: System level
type: Specifies the antenna type.
# Specify the antenna type.
[sysname-WLAN-Radio1/0/1] antenna type internal
beacon-measurement enable
Use beacon-measurement enable to enable beacon measurement.
Use undo beacon-measurement enable to disable beacon measurement.
Beacon measurement is disabled.
Service template view
2: System level
Enable beacon measurement for the AP to send beacon measurement requests to clients that support the 802.11k protocol.
# Disable beacon measurement.
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] beacon-measurement enable
beacon-measurement interval
Use beacon-measurement interval to set the interval at which the AP sends beacon measurement requests to clients.
Use undo beacon-measurement interval to restore the default.
beacon-measurement interval interval
The interval is 60 seconds.
2: System level
interval: Specifies the interval at which the AP sends beacon measurement requests to clients, in the range of 10 to 200 seconds.
# Set the interval for sending beacon measurement requests to 60 seconds.
beacon-measurement type
Use beacon-measurement type to set the beacon measurement mode.
Use undo beacon-measurement type to restore the default.
beacon-measurement type { active | beacon-table | passive }
The beacon-table mode is used.
2: System level
active: Enables the active beacon measurement mode. In this mode, the AP sends a beacon measurement request to a client. Upon receiving the request, the client broadcasts probe requests on all supported channels, sets a measurement duration timer, and, at the end of the measurement duration, compiles all received beacons and probe responses into a measurement report.
beacon-table: Enables the beacon-table beacon measurement mode. In this mode, the AP sends a beacon measurement request to a client. Upon receiving the request, the client measures beacons and returns a report to the AP. The report contains all beacon information stored on the client.. The client does not perform any additional measurements.
passive: Enables the passive beacon measurement mode. In this mode, the AP sends a beacon measurement request to a client. Upon receiving the request, the client sets a measurement duration timer, and, at the end of the measurement duration, compiles all received beacons and probe responses into a measurement report.
# Set the beacon measurement mode to active.
[Sysname-wlan-st-1] beacon-measurement type active
beacon ssid-hide
Use beacon ssid-hide to disable the advertising of the Service Set Identifier (SSID) in beacon frames.
Use undo beacon ssid-hide to restore the default.
beacon ssid-hide
The SSID is advertised in beacon frames.
2: System level
If the advertising of the SSID in beacon frames is disabled, the SSID must be configured for the clients to associate with the AP.
Disabling the advertising of the SSID in beacon frames inhibits wireless security. Allowing the advertising of the SSID in beacon frames enables clients to discover an AP more easily.
# Disable the advertising of the SSID in beacon frames.
[Sysname-wlan-st-1] beacon ssid-hide
beacon-interval
Use beacon-interval to set the interval for sending beacon frames. Beacon frames are transmitted at a regular interval to allow mobile clients to join the network.
Use undo beacon-interval to restore the default beacon interval.
beacon-interval interval
The beacon interval is 100 TUs.
2: System level
interval: Specifies the interval for sending beacon frames. The value is in the range of 32 to 8191 time units (TUs).
# Specify the beacon interval as 1000 TUs.
<Sysname> System-view
[Sysname-WLAN-Radio1/0/1] beacon-interval 1000
channel
Use channel to specify a channel for the radio.
Use undo channel to restore the default.
channel { channel-number | auto }
undo channel
auto mode is set.
2: System level
channel-number: Specifies a channel. The working channels depend on the country code and radio mode. An 802.11a, 802.11ac, or 802.11an radio interface supports the 36, 40, 44, 48, 52, 56, 60, 64, 149, 153, 157, 161, and 165 channels. An 802.11b, 802.11g, or 802.11gn radio interface supports channels 1 through 13.
auto: Configures the channel to be automatically selected by the device according to the actual environment during system initialization.
# Specify channel 6 for radio interface 1/0/2.
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] radio-type dot11b
[Sysname-WLAN-Radio1/0/2] channel 6
channel band-width
Use channel band-width to specify the channel bandwidth of the radio.
Use undo channel band-width to restore the default.
channel band-width { 20 | 40 | 80 }
The channel bandwidths of an 802.11an radio, the 802.11gn radio and the 802.11ac radio are 40 MHz, 20 MHz, and 80 MHz, respectively.
2: System level
20: Specifies the channel bandwidth of the 802.11n radio as 20 MHz.
40: Specifies the channel bandwidth of the 802.11n radio as 40 MHz.
80: Specifies the channel bandwidth for the 802.11ac radio as 80 MHz.
This command is only effective on 802.11n and 802.11ac radios.
If the channel bandwidth of the radio is set to 40 MHz, a 40 MHz channel is used as the working channel. If no 40 MHz channel is available, only a 20 MHz channel can be used. For more information, see IEEE 802.11n-2009.
# Configure the channel bandwidth of the radio as 40 MHz.
[sysname-WLAN-Radio1/0/1] radio-type dot11ac
[sysname-WLAN-Radio1/0/1] channel band-width 40
client
Use client to allow 802.11n or 802.11ac client access.
Use undo client to restore the default.
client { dot11n-only | dot11ac-only }
undo client { dot11n-only | dot11ac-only }
An 802.11an or 802.11ac radio permits 802.11a, 802.11an, and 802.11ac clients access. An 802.11gn radio permits both 802.11b/g and 802.11gn client access.
2: System level
dot11n-only: Permits 802.11n or 802.11ac clients in 5 GHz radio interface view. Permits 802.11n clients in 2.4 GHz radio interface view.
dot11ac-only: Permits only 802.11ac clients.
The client dot11n-only command permits only 802.11n or 802.11ac clients' access. To provide access for all 802.11a/b/g clients, disable this command.
The client dot11ac-only command permits only 802.11ac clients to access the WLAN. To provide access for 802.11a/n clients, disable this command.
# Configure the radio to allow only 802.11n and 802.11ac clients to access the WLAN.
[sysname-WLAN-Radio1/0/1] radio-type dot11an
[sysname-WLAN-Radio1/0/1] client dot11n-only
# Configure the radio to allow only 802.11ac clients to access the WLAN.
<Sysname>system-view
[sysname-WLAN-Radio1/0/1] radio 1 type dot11ac
[sysname-WLAN-Radio1/0/1] client dot11ac-only
·          dot11n mandatory maximum-mcs
·          dot11ac mandatory maximum-nss
client max-count (service template view)
Use client max-count to specify the maximum number of allowed clients for a radio.
Use undo client max-count to restore the default.
client max-count max-number
Up to 64 clients can be associated with an SSID on a radio.
2: System level
max-number: Maximum number of clients associated with an SSID, in the range of 1 to 124.
When the maximum number is reached, the SSID is automatically hidden.
# Specify the maximum number of clients associated with the SSID service on a radio as 10.
[Sysname-wlan-st-1] ssid service
[Sysname-wlan-st-1] client max-count 10
debugging wlan mac
Use debugging wlan mac to enable the WLAN MAC to output debugging information such as error, event, packet, frame, and FSM debugging information.
Use undo debugging wlan mac to disable the specified debugging.
debugging wlan mac { all | error | event | frame [ acl acl-number | verbose ] | fsm [ acl acl-number ] | timer }
undo debugging wlan mac { all | error | event | frame | fsm | timer }
No WLAN debugging is enabled.
2: System level
all: Enables all WLAN MAC debugging.
error: Enables WLAN MAC error debugging.
event: Enables WLAN MAC event debugging.
frame: Enables WLAN MAC frame debugging.
acl acl-number: Specifies an ACL for frames. The value is in the range of 4000 to 4999.
verbose: Displays detailed debugging information.
fsm: Enables WLAN MAC FSM debugging.
timer: Enables WLAN MAC timer debugging.
# Enable WLAN MAC error debugging on the AC.
<Sysname> debugging wlan mac error
display wlan client
Use display wlan client to display WLAN client information. The information is displayed in the order of client MAC address.
display wlan client { interface wlan-radio [ radio-number ] | mac-address mac-address | service-template service-template-number } [ verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface wlan-radio radio-number: Displays information about clients that are attached to the specified WLAN-radio interface.
mac-address mac-address: Specifies the MAC address of a client.
service-template service-template-number: Displays client information based on the specified service template. The service template number is in the range of 1 to 1024.
verbose: Displays detailed client information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case sensitive string of 1 to 256 characters.
# Display information about all the clients.
<Sysname> display wlan client
Total Number of Clients           : 3
                               Client Information
 SSID: office
 MAC Address   User Name            APID/RID IP Address              VLAN
000f-e265-6400 –NA-                  1/1     1.1.1.1                 1
000f-e265-6401 user                 1024/1   3.0.0.3                 3
000f-e265-6402 [email protected]       103 /1   FE:11:12:03::11:25:13   1
SSID
SSID with which the client is associated.
MAC address
MAC address of the client.
User Name
Username of the client:
·         The field is displayed as -NA- if the client adopts plain-text authentication or cipher-text authentication with no username.
·         The field is irrelevant to the portal authentication method. If the client uses the portal authentication method, the field does not display the portal username of the client.
APID/RID
ID of the AP or radio that the client is associated with.
IP Address
IP address of the client.
VLAN
VLAN to which the client belongs.
# Display detailed information about all clients.
<Sysname> display wlan client verbose
 Total Number of Clients           : 1
                              Client Information
 MAC Address                       : 60a4-4c82-c1ee
 User Name                         : -NA-
 IP Address                        : 50.30.1.3
 AID                               : 1
 Radio Interface                   : WLAN-Radio1/0/1
 Service Template Number           : 1
 SSID                              : office
 BSSID                             : 0023-8900-4320
 Port                              : WLAN-BSS32
 VLAN                              : 30
 State                             : Running
 Power Save Mode                   : Active
 Wireless Mode                     : 11ac
 Channel Band-width                : 20/40/80MHz
 SM Power Save Enable              : Disabled
 Short GI for 20MHz                : Supported
 Short GI for 40MHz                : Supported
 Short GI for 80MHz                : Supported
 Short GI for 160/80+80MHz         : Not Supported
 LDPC RX capability                : Not Supported
 STBC TX capability                : Supported
 STBC RX capability                : Supported For 1 Nss
 Support VHT-MCS and Nss Set       : 2,2,2,3,3,3,3,3
 BLOCK ACK-TID 0                   : IN
 QoS Mode                          : WMM
 Listen Interval (Beacon Interval) : 10
 RSSI                              : 54
 Rx/Tx Rate                        : 6/1300
 Client Type                       : PRE-RSNA
 Authentication Method             : Open System
 Authentication Mode               : Central
 AKM Method                        : None
 Key Derivation                    : -NA-
 4-Way Handshake State             : -NA-
 Group Key State                   : -NA-
 Encryption Cipher                 : Clear
 PMF Status                        : -NA-
 Roam Status                       : Normal
 Roam Count                        : 0
 Up Time (hh:mm:ss)                : 00:05:25
MAC address
User Name
AID
Association ID of the client.
Radio Interface
WLAN radio interface.
SSID
SSID of the client.
BSSID
ID of the BSS.
Port
WLAN-DBSS interface associated with the client.
VLAN
State of the client such as running.
Power Save Mode
Client’s power save mode such as active or sleep.
Wireless Mode
Wireless mode such as 802.11a, 802.11b, 802.11g, 802.11gn, 802.11an, and 802.11ac.
Channel Band-width
Channel bandwidth, 20 MHz, 40 MHz, or 80 MHz.
SM Power Save enables a client to have one antenna in the active state, and others in sleep state to save power.
·         EnabledSM Power Save is enabled.
·         DisabledSM Power Save is disabled.
Short GI for 20MHz
Whether the client supports short GI when its channel bandwidth is 20 MHz.
Short GI for 40MHz
Whether the client supports short GI when its channel bandwidth is 40 MHz.
Short GI for 80MHz
Whether the client supports short GI when its channel bandwidth is 80 MHz.
Whether the client supports short GI when its channel bandwidth is 160/80+80 MHz.
LDPC
Whether LDPC is supported:
·         Not Supported.
·         Supported.
STBC Tx Capability
STBC transmission capability:
·         Not Supported.
·         Supported.
The AP and a client negotiate the STBC transmission capability. The negotiation can succeed only when both the AP and client have STBC transmission capability.
STBC Rx Capability
STBC receive capability:
·         Not Supported.
·         Supported.
The AP and a client negotiate the STBC receive capability. The negotiation can succeed only when both the AP and client have STBC receive capability.
Support MCS Set
MCS supported by the client.
VHT-MCS and NSS supported by the client.
BLOCK ACK-TID 0
BLOCK ACK is negotiated based on traffic identifier (TID) 0:
·         OUTOutbound direction.
·         INInbound direction.
·         BOTHBoth outbound and inbound directions.
QoS Mode
WMM indicates that the WMM function is supported; None indicates that the WMM function is not supported.
WMM information negotiation is carried out between an AP and a client that both support WMM.
Listen Interval(Beacon Interval)
Number of times the client has woken up to listen to beacon frames.
RSSI
Received signal strength indication. This value indicates the client signal strength detected by the AP.
Rx/Tx Rate
Represents the receiving and sending rates of the frames such as data, management, and control frames.
Client Type
Client type such as RSN, WPA, or Pre-RSN.
Authentication method such as open system or shared key.
AKM Method
AKM suite used such as Dot1X or PSK.
Key Derivation
Key derivation type:
·         SHA1—Uses the HMAC-SHA1 hash algorithm.
·         SHA256—Uses the HMAC-SHA256 hash algorithm.
·         -NA-—No key derivation algorithm is involved for the authentication type.
Display either of the 4-way handshake states:
·         IDLEDisplayed in initial state.
·         PTKSTARTDisplayed when the 4–way handshake is initialized.
·         PTKNEGOTIATINGDisplayed after sending valid message 3.
·         PTKINITDONEDisplayed when the 4-way handshake is successful.
Group Key State
Display the group key state such as:
·         REKEYNEGOTIATEDisplayed after the AC sends the initial message to the client.
·         REKEYESTABLISHEDDisplayed when re-keying is successful.
Encryption Cipher
Encryption cipher such as clear or crypto.
PMF Status
Management frame protection state:
·         Active.
·         Inactive.
·         -NA-—No PMF is involved for the authentication type.
Roam Status
Display the roam status such as Normal or Fast Roaming.
Roam Count
Roaming count of the client, including intra-AC roaming and inter-AC roaming.
Up Time
Time for which the client has been associated with the AP.
display wlan client beacon-report
Use display wlan client beacon-report to display beacon reports received from clients.
display wlan client [ mac-address mac-address ] beacon-report [ | { begin | exclude | include } regular-expression ]
1: Monitor level
mac-address mac-address: Specifies the MAC address of a client. If the mac-address mac-address option is not specified, beacon reports from all clients are displayed.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display beacon reports received from the specified client.
<Sysname>  display wlan client mac-address 000f-e265-6400 beacon-report
Report Information
MAC Address              : 000f-e265-6400
Total Number of Reports  : 4
----------------------------------------------------------------------------------------Channel         BSSID       Regulatory Class  Antenna ID      SSID
1           0026-3e08-1150        12             1            eagle
1           0026-3e08-1151        12             1            eagle
6           0026-3e08-1152        12             1            eagle
6           0026-3e08-1153        12             1            eagle
MAC address
Total number of received beacon reports.
Channel
Channel number.
BSSID
ID of the BSS.
Regulatory Class
Regulatory class with the value of 12 or 5. For more information, see the 802.11k protocol.
Antenna ID
ID of the antenna.
SSID
display wlan client bridge
Use display wlan client bridge to display information about bridge clients.
display wlan client bridge [ interface wlan-radio [ radio-number ] ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface wlan-radio radio-number: Specifies a WLAN-Radio interface by its number.
regular-expression: Specifies a regular expression, which is a case-sensitive string of 1 to 256 characters.
Clients mentioned in this command refer to bridges working as clients to associate with the AP.
This command can display information about only H3C wireless bridges.
# Display information about all clients.
<Sysname> display wlan client bridge
                               Client Information
 SSID: dragon
5866-baf2-d7cd -NA-                 2   /2   192.168.1.48                   1
SSID
MAC address
User Name
·         The field is displayed as -NA- if the client uses plain-text authentication or cipher-text authentication with no username.
·         If the client uses the portal authentication method, the field does not display the portal username of the client.
APID/RID
ID of the AP or radio with which the client is associated.
IP Address
VLAN
<Sysname> display wlan client bridge verbose
                              Client Information
 MAC Address                       : 5866-baf2-d7cd
 User Name                         : -NA-
 IP Address                        : 192.168.1.48
 AID                               : 1
 AP Name                           : floor11
 Radio Id                          : 2
 SSID                              : dragon
 BSSID                             : 5866-ba21-2770
 Port                              : WLAN-DBSS1:0
 VLAN                              : 1
 State                             : Running
 Wireless Mode                     : 11gn
 Channel Band-width                : 20MHz
 Short GI for 40MHz                : Not Supported
 Support MCS Set                   : 0,1,2,3,4,5,6,7
 QoS Mode                          : WMM
 RSSI                              : 80
 Rx/Tx Rate                        : 52/0
 AKM Method                        : None
 Roam Count                        : 0
 Up Time (hh:mm:ss)                : 00:13:56
 Serial Number                     : 219801A0BHM125002207
 Device Information                : WB524
 Software Version                  : WB524V100R004
 Associated AP RSSI                : -NA-
 Associated AP SNR                 : -NA-
 Tx Power (dBm)                    : -NA-
 Rx Packets                        : 0
 Rx Bytes                          : 0
 Tx Packets                        : 0
 Tx Bytes                          : 0
 Tx Dropped Packets                : 0
 Command Execution Result          : -NA-
Table 5 Command output
MAC address
User Name
IP Address
AID
AP Name
Name of the associated AP.
Radio Id
ID of the radio with which the client is associated.
Serial number of the service template.
SSID
SSID of the client.
Port
VLAN
State of the client:
·         Running—The client is connected to the AC through the primary link.
·         Running (Backup)—The client is connected to the AC through the backup link.
Power Save Mode
Client's power save mode, active or sleep.
Wireless Mode
Wireless mode such as 802.11a, 802.11b, 802.11g, 802.11gn, and 802.11an.
Channel Band-width
Channel bandwidth, 20 MHz or 40 MHz.
·         Enabled.
·         Disabled.
Short GI for 20MHz
Short GI for 40MHz
STBC Tx Capability
·         Not Supported.
·         Supported.
STBC Rx Capability
·         Not Supported.
·         Supported.
Support MCS Set
BLOCK ACK-TID
BLOCK ACK is negotiated based on traffic identifier (TID):
QoS Mode
WMM indicates that the WMM function is supported. None indicates that the WMM function is not supported.
RSSI
Rx/Tx Rate
The sending and receiving rates of the frames such as data, management, and control frames. For the AC + fit AP architecture, there is delay because Rx rate information is transmitted periodically from AP to AC.
Client Type
Authentication Mode
Authentication mode:
·         CentralCentral authentication. The AC authenticates clients.
·         LocalLocal authentication. The AP authenticates clients.
AKM Method
·         IDLEDisplayed in initializing state.
·         PTKSTARTDisplayed when the 4–way handshake initialization is completed.
·         PTKNEGOTIATINGDisplayed after valid message 3 is sent.
Group Key State
Display the group key state:
Encryption Cipher
Encryption mode such as clear or crypto.
Roam Status
Display the roam status:
·         Normal
·         Intra-AC roam association
·         Inter-AC roam association
Roam Count
·         For intra-AC roaming, this field is reset after the client is de-associated with the AP connected to the AC.
·         For inter-AC roaming, this field is reset after the client leaves the mobility group to which the AC belongs.
Up Time
Serial Number
Serial number of the client.
Device Information
Device model of the client.
Software Version
Software version of the client.
Associated AP RSSI
Received Signal Strength Indicator. It indicates the associated AP's signal strength detected by the client.
Associated AP SNR
The associated AP's SNR detected by the client.
Tx Power (dBm)
Transmission rate of the client radio.
Rx Packets
Total number of packets received by the client.
Rx Bytes
Total number of bytes received by the client.
Tx Packets
Total number of packets sent by the client.
Tx Bytes
Total number of bytes sent by the client.
Tx Dropped Packets
Total number of dropped packets by the client.
Command execution result reported by the client.
The field is displayed as -NA- if the device did not receive any command execution results reported by the client. For more information about the output, see the wireless bridge manual.
display wlan service-template
Use display wlan service-template to display WLAN service template information. If no service template is specified, all service templates are displayed.
display wlan service-template [ service-template-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
service-template-number: Number of a service template, in the range of 1 to 1024.
# Display the configuration information for service template 1.
<Sysname> display wlan service-template 1
                           Service Template Parameters
 SSID                         : nsw-nsw
 Description                  : Not Configured
 Service Template Type        : Crypto
 Security IE                  : WPA2(RSN) WPA
 Beacon-measurement           : Enable
 Beacon-measurement Interval  : 30
 Beacon-measurement Type      : Passive
 SSID-hide                    : Disabled
 Cipher Suite                 : TKIP AES-CCMP
 WEP Key Index  1             : WEP40
 WEP Key Mode                 : ASCII
 WEP Key                      : ******
 TKIP Countermeasure Time(s)  : 60
 PTK Life Time(s)             : 180
 GTK Rekey                    : Enabled
 GTK Rekey Method             : Packet-based
 GTK Rekey Packets            : 5000
 PMF Status                   : Optional
 Service Template Status      : Enabled
 Maximum clients per BSS      : 35
Table 6 Command output
Current service template number.
SSID
SSID that is associated with the client.
Service template type crypto or clear.
Security IE
Security IE such as WPA and WPA2 (RSN).
Type of authentication used, open system or shared key.
Authentication Mode
·         BackupBackup authentication.
Beacon-measurement
Enable—The beacon measurement function is enabled.
Interval for the AP to send beacon requests to clients. The interval is in seconds.
Beacon measurement mode:
·         Passive.
·         Active.
·         Beacon-table.
SSID-hide
Enabled or disabled.
Cipher Suite
Cipher suite such as AES-CCMP, TKIP, WEP40, WEP104 or WEP128.
WEP Key Index
Key index to encrypt or decrypt frames.
WEP Key Mode
WEP key format:
·         HEXHexadecimal string.
·         ASCIIASCII character string.
Counter measure time for MIC failure in seconds.
PTK Life Time(s)
PTK lifetime in seconds.
GTK Rekey
GTK rekey configured.
GTK Rekey Method
GTK rekey method configured such as packet based or time based.
GTK Rekey Time(s)
Time for GTK rekey in seconds.
PMF Status
Management frame protection status:
·         Disable.
·         OptionalPMF is enabled. All clients can associate with the AP.
·         Mandatory—PMF is enabled. Only clients supporting PMF can associate with the AP.
Status such as enabled or disabled.
Maximum number of associated clients per BSS.
display wlan statistics client
Use display wlan statistics client to display client statistics.
display wlan statistics client { all | mac-address mac-address } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
client: Displays client statistics.
all: Displays the statistics of all clients.
mac-address mac-address: Displays the statistics of the client with the specified MAC address.
# Display the statistics of all the clients.
<Sysname> display wlan statistics client all
                                Client Statistics
 AP Name                           : sysname
 Radio Id                          : 1
 SSID                              : office
 BSSID                             : 000f-e2ff-7700
 MAC Address                       : 0014-6c8a-43ff
 RSSI                              : 31
 Transmitted Frames:
 Back Ground (Frames/Bytes)        : 0/0
 Best Effort (Frames/Bytes)        : 9/1230
 Video (Frames/Bytes)              : 0/0
 Voice (Frames/Bytes)              : 2/76
 Received Frames:
 Best Effort (Frames/Bytes)        : 18/2437
 Voice (Frames/Bytes)              : 7/468
 Discarded Frames:
 Best Effort (Frames/Bytes)        : 0/0
 Voice (Frames/Bytes)              : 5/389
Table 7 Command output
SSID
SSID to which the client is associated.
BSSID
ID of the BSS.
MAC Address
RSSI
Received Signal Strength Indicator. It indicates the client signal strength detected by the AP.
Transmitted Frames
Transmitted Frames.
Back Ground
Statistics of background traffic.
Best Effort
Statistics of best effort traffic.
Video
Statistics of video traffic.
Voice
Statistics of voice traffic.
Received Frames
Received frames.
Discarded Frames
Discarded frames.
Statistics for background, best effort, video, and voice traffic are only for QoS-capable clients. For QoS-incapable clients, only best effort traffic statistics are available (including SVP packets) and may be inconsistent with the real physical output queues because the priority-queue statistics can only identify priorities carried in Dot11E and WMM packets. Otherwise, statistics of received packets cannot be collected.
display wlan statistics service-template
Use display wlan statistics service-template to display service template statistics.
Use display wlan statistics service-template service-template-number connect-history to display the connection statistics for all APs bound to the service template.
display wlan statistics service-template service-template-number [ connect-history ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
service-template-number: Service template number, in the range of 1 to 1024.
connection-history: Displays the connection history.
# Display the statistics of service template 1.
<Sysname> display wlan statistics service-template office
                        Service Template Statistics
Service Template            : office
AP Name                     : ap1
 Radio                      : 1
 Receive                    :
    Frame Count             : 1713
    Frame Bytes             : 487061
    Data Frame Count        : 1683
    Data Frame Bytes        : 485761
    Associate Frame Count   : 2
 Send                       :
    Frame Count             : 62113
    Frame Bytes             : 25142076
    Data Frame Count        : 55978
    Data Frame Bytes        : 22626600
Table 8 Command output
Service Template
Service template number.
AP Name
AP name.
Receive
Receive statistics:
·         Frame Count—Number of frames received.
·         Frame Bytes—Number of bytes received.
·         Data Frame Count—Number of data frames received.
·         Data Frame Bytes—Number of data bytes received.
·         Associate Frame Count—Number of association requests received.
Send
Send statistics:
·         Frame Count—Number of frames sent.
·         Frame Bytes—Number of bytes sent.
·         Data Frame Count—Number of data frames sent.
·         Data Frame Bytes—Number of data bytes sent.
·         Associate Frame Count—Number of association requests sent.
# Display the connection history of service template office.
<Sysname> display wlan statistics service-template office connect-history
                            Connect History
 AP Name                    : ap1
 Radio                      : 1
 Associations               : 132
 Failures                   : 3
 Reassociations             : 30
 Rejections                 : 12
 Exceptional Deassociations : 2
 Current Associations       : 57
 AP Name                    : ap1
 Radio                      : 2
 Associations               : 1004
 Failures                   : 35
 Reassociations             : 59
 Rejections                 : 4
 Exceptional Deassociations : 22
 Current Associations       : 300
Table 9 Command output
Service Template
AP name
AP name.
Radio
Radio number.
Associations
Total number of associations.
Failures
Total number of failed associations.
Reassociations
Total number of reassociations.
Rejections
Total number of associations rejected.
Total number of exceptional associations.
Number of current associations.
distance
Use distance to configure the maximum distance that the radio can cover.
Use undo distance to restore the default.
distance distance
undo distance
The radio can cover 1 km (0.62 miles) at most.
2: System level
distance: Specifies the maximum distance that the radio can cover, in the range of 1 to 40 km (0.62 to 24.86 miles).
# Configure the maximum distance that the radio can cover as 5 km (3.11 miles).
[Sysname-WLAN-Radio1/0/1] distance 5
dtim
Use dtim to set the number of beacon intervals an AP waits before it sends buffered multicast and broadcast frames. The AP sends buffered broadcast/multicast frames when the DTIM counter reaches the configured value.
Use undo dtim to restore the default.
dtim counter
undo dtim
The DTIM is 1.
2: System level
counter: Number of beacon intervals between DTIM transmissions. The value is in the range of 1 to 31.
# Set the DTIM counter to 10.
[Sysname-WLAN-Radio1/0/1] dtim 10
fast-association enable
Use fast-association enable to enable fast association.
Use undo fast-association enable to disable fast association.
Fast association is disabled.
2: System level
When fast association is enabled, the AP does not perform band navigation and load balancing calculations for clients bound to the SSID.
# Enable fast association.
[Sysname-wlan-st-1] fast-association enable
fragment-threshold
Use fragment-threshold to specify the maximum length of frames that can be transmitted without fragmentation. A packet that exceeds the specified fragment threshold is fragmented.
Use undo fragment-threshold to restore the default value.
fragment-threshold size
The fragment threshold is 2346 bytes. Frames that exceed 2346 bytes are fragmented.
2: System level
size: Maximum frame length without fragmentation. The value is in the range of 256 to 2346 bytes and must be an even number.
# Specify the fragment threshold as 2048 bytes.
[Sysname-WLAN-Radio1/0/1] fragment-threshold 2048
green-energy-management enable
Use green-energy-management enable to enable the energy saving function. When this function is enabled, a radio transmits and receives 1 spatial stream at a time to save power if no clients are associated with the radio.
Use undo green-energy-management enable to disable the energy saving function.
The energy saving function is disabled.
2: System level
# Enable the energy saving function.
[sysname-WLAN-Radio1/0/1] green-energy-management enable
long-retry threshold
Use long-retry threshold to set the number of re-transmission attempts for frames larger than the RTS threshold.
Use undo long-retry threshold to restore the default.
long-retry threshold count
The long retry threshold is 4.
2: System level
count: Number of retransmission attempts for frames larger than the RTS threshold, in the range of 1 to 15.
# Specify the long-retry threshold as 10.
[Sysname-WLAN-Radio1/0/1] long-retry threshold 10
max-power
Use max-power to configure the maximum transmission power on the radio.
Use undo max-power to restore the default.
max-power radio-power
undo max-power
The maximum radio power varies with country codes, channels, AP models, radio types, and antenna types. If 802.11n or 802.11ac is adopted, the maximum radio power also depends on the bandwidth mode.
2: System level
radio-power: Maximum radio transmission power, which varies with country codes and radio types.
# Specify the max transmission power of radio 1/0/1 as 5.
[Sysname-WLAN-Radio1/0/1] radio-type dot11a
[Sysname-WLAN-Radio1/0/1] max-power 5
max-rx-duration
Use max-rx-duration to specify the interval for the AP to hold a received frame. An AP holds received packets in its buffer memory.
Use undo max-rx-duration to restore the default.
max-rx-duration interval
The max-rx-duration is 2000 milliseconds.
2: System level
interval: Interval for which a frame received by an AP can stay in the buffer memory. The value is in the range of 500 to 250000 milliseconds.
# Set the max-rx-duration as 5000 milliseconds.
[Sysname-WLAN-Radio1/0/1] max-rx-duration 5000
mimo
Use mimo to set the MIMO mode for a radio.
Use undo mimo to restore the default.
mimo { 1x1 | 2x2 | 3x3 }
undo mimo
No MIMO mode is set for a radio.
2: System level
1x1: Enables the radio to transmit and receive 1 space stream at a time.
2x2: Enables the radio to transmit and receive 2 space streams at a time.
3x3: Enables the radio to transmit and receive 3 space streams at a time.
The following matrix shows the command and hardware compatibility:
Hardware series
Model
Command compatibility
WA4600 series
WA4620i-ACN
Yes
WA4620E-ACN
Yes
WA4300 series
WA4320H-ACN
WA4320i-ACN
WA4320-ACN
WA4320-ACN-PI
Yes
The 3x3 keyword is not supported.
The MIMO mode supported by an AP depends on the space streams that the AP can transmit and receive. For example, if an AP can transmit and receive 1 space stream at a time, the MIMO mode of the AP can only be 1x1. If an AP can transmit and receive 2 space streams at a time, the MIMO mode of the AP can be 1x1 or 2x2.
# Set the MIMO mode for WLAN-radio 1/0/1 to 1×1.
[sysname-WLAN-Radio1/0/1] mimo 1x1
preamble
Use preamble to specify the type of preamble that an AP can support.
Use undo preamble to restore the default.
preamble { long | short }
undo preamble
The short preamble is supported.
2: System level
long: Indicates that only frames with a long preamble can be transmitted.
short: Indicates that frames with either a short preamble or a long preamble can be transmitted.
Preamble is a pattern of bits at the beginning of a frame so that the receiver can sync up and be ready for the real data. There are two different kinds of preambles, short and long.
802.11a, 802.11an, and 802.11ac does not support this configuration.
# Configure the AP to support long preamble.
[Sysname-WLAN-Radio1/0/1] radio-type dot11b
[Sysname-WLAN-Radio1/0/1] preamble long
protection-mode
Use protection-mode to specify a collision avoidance mechanism.
Use undo protection-mode to restore the default.
protection-mode { cts-to-self | rts-cts }
The collision avoidance mechanism is CTS-to-Self.
2: System level
cts-to-self: Specifies the Clear to Send (CTS)-to-Self collision avoidance mechanism.
rts-cts: Specifies the Request to Send (RTS)/CTS collision avoidance mechanism.
Compared with RTS/CTS, CTS-to-Self reduces the number of control frames. However, data collisions still occur when some clients are hidden and thus cannot receive the CTS frames sent by the AP. Therefore, the RTS/CTS mechanism can solve the data collision problem in a larger coverage than RTS/CTS.
For more information about CTS-to-Self and RTS/CTS, see WLAN Configuration Guide.
# Configure the collision avoidance mechanism as RTS/CTS.
[Sysname-WLAN-Radio1/0/1] protection-mode rts-cts
radio-type
Use radio-type to specify the radio type to be used by a radio.
Use undo radio-type to restore the default.
radio-type { dot11a | dot11an | dot11ac | dot11b | dot11g | dot11gn }
undo radio-type
The default radio type depends on the antenna model.
dot 11a: Specifies the 802.11a radio type.
dot11an: Specifies the 802.11an radio type.
dot11ac: Specifies the 802.11ac radio type.
dot 11b: Specifies the 802.11b radio type.
dot 11g: Specifies the 802.11g radio type.
dot11gn: Specifies the 802.11gn (2.4 GHz) radio type.
WLAN allows you to modify the default radio type for different types of AP.
# Specify the radio type as 802.11an for interface WLAN-Radio 1/0/1.
[Sysname-WLAN-Radio1/0/1] radio-type dot11an
reset wlan statistics
Use reset wlan statistics to clear client or radio statistics.
reset wlan statistics client { all | mac-address mac-address }
2: System level
all: Clears the statistics of all clients.
mac-address mac-address: Clears the statistics of the client.
ap-name: Clears the radio statistics of an AP. The AP name is a case-insensitive string of 1 to 32 characters.
# Clear the radio statistics of all clients.
<Sysname> reset wlan statistics client all
reset wlan client
Use reset wlan client to cut off a client or all clients. When this command is used, the AP sends a de-authentication frame to the client and the client is removed from the WLAN service.
reset wlan client { all | mac-address mac-address }
2: System level
all: Cuts off all clients.
mac address mac-address: Cuts off the client specified by the MAC address.
# Cut off the client with MAC address 000f-e2cc-8501.
<Sysname> reset wlan client mac-address 000f-e2cc-8501
rts-threshold
Use rts-threshold to specify the request to send (RTS) threshold length. If a frame is larger than this value, the RTS mechanism is used.
Use undo rts-threshold to restore the default.
rts-threshold size
undo rts-threshold
The RTS threshold is 2346 bytes.
2: System level
size: Length of frames for which the request to send (RTS) method is used. The value is in the range of 0 to 2346 bytes.
Request to Send (RTS) is used to avoid data sending collisions in a WLAN. You need to set a rational value:
A small value causes RTS packets to be sent more often, consuming more of the available bandwidth. However, the system can recover more quickly from interference or collisions when RTS packets are sent more frequently.
# Specify the RTS threshold as 2046 bytes.
[Sysname-WLAN-Radio1/0/1] rts-threshold 2046
service-template (WLAN-Radio interface view)
Use service-template to map a service template to the current radio.
Use undo service-template to remove the mapping.
service-template service-template-number interface wlan-bss wlan-bss-number
undo service-template service-template-number
No service-template is mapped to a radio.
2: System level
service-template-number: Number of a service template in the range of 1 to 1024.
wlan-bss-number: Number of a WLAN-BSS interface in the range of 0 to 255.
# Map service template 1 to interface WLAN-BSS 1 on interface WLAN-Radio 1/0/1.
[Sysname-WLAN-Radio1/0/1] service-template 1 interface WLAN-BSS 1
service-template (service template view)
Use service-template to map a service template to a WLAN-BSS interface on the current WLAN-Radio interface.
service-template { disable | enable }
The service template is disabled.
2: System level
disable: Disables the service template.
enable: Enables the service template.
# Enable service template 1.
[Sysname-wlan-st-1] ssid clear
[Sysname-wlan-st-1] authentication-method open-system
[Sysname-wlan-st-1] service-template enable
short-gi enable
Use short-gi enable to enable the short GI function.
Use undo short-gi enable to disable the short GI function.
short-gi enable
The short GI function is enabled.
2: System level
This command is only effective on 802.11n radios.
Delays may occur during receiving radio signals due to factors like multi-path reception. Therefore, a subsequently sent frame may interfere with a previously sent frame. The GI function is used to avoid such interference.
The GI interval in 802.11a/g is 800 us. The short GI function can be configured for 802.11n. This can shorten the GI interval to 400 ns, which increases the data speed by 10 percent.
# Disable the short GI function.
[sysname-WLAN-Radio1/0/1] undo short-gi enable
short-retry threshold
Use short-retry threshold to specify the maximum number of attempts to transmit a frame less than the RTS threshold.
Use undo short-retry threshold to restore the default.
short-retry threshold count
The short retry threshold is 7.
2: System level
count: Number of times the AP can send a short unicast frame (less than the RTS threshold) if no acknowledgment is received for it. The value is in the range of 1 to 15.
# Specify the short retry threshold as 10.
[Sysname-WLAN-Radio1/0/1] short-retry threshold 10
shut-all-led enable
Use shut-all-led enable to shut down all LEDs on the AP.
Use undo shut-all-led enable to restore the default.
shut-all-led enable
LEDs on the AP light based on AP status.
2: System level
# Shut down all LEDs on the AP.
[Sysname] shut-all-led enable
ssid
Use ssid to set the SSID for the current service template.
Use undo ssid to remove the SSID.
ssid ssid-name
undo ssid
No SSID is set for the service template.
2: System level
ssid-name: Name of the service set identifier, a case-sensitive string of 1 to 32 characters.
An SSID should be as unique as possible. For security, do not include the company name in the SSID. Additionally, do not use a long random string as the SSID. Doing so only adds payload to the header field and does not improve wireless security.
# Set the SSID as firstfloor for service template 1.
[Sysname-wlan-st-1] ssid firstfloor
stbc enable
Use stbc enable to enable Space Time Block Coding (STBC).
Use undo stbc enable to disable STBC.
stbc enable
undo stbc enable
STBC is enabled.
2: System level
Enabling STBC improves the SNR of the receiver and data transmission reliability.
STBC takes effect only when the number of antennas on an AP is greater than the number of spatial streams corresponding to the rates used by the radio. For example, if the MCS is 8 and the corresponding spatial stream number is 2, STBC takes effect only when the AP has at least three antennas.
# Enable STBC.
[Sysname-WLAN-Radio1/0/1] stbc enable
wlan broadcast-probe reply
Use wlan broadcast-probe reply to enable the AP to respond to the probe requests without SSID.
Use undo wlan broadcast-probe reply to remove the configuration to cause the AP to only respond to probe requests that carry the specified SSID.
An AP responds to probe requests without SSID.
# Enable the AP to respond to probe requests without SSID.
[Sysname] wlan broadcast-probe reply
wlan client idle-timeout
Use wlan client idle-timeout to specify the client idle timeout.
Use undo wlan client idle-timeout to restore the default.
wlan client idle-timeout interval
The client idle timeout is 3600 seconds.
2: System level
interval: Maximum interval for which the link between the AP and a client ( power-save or awake ) can be idle. The value is in the range of 60 to 86400 seconds.
If the AP does not receive any data from a client within the client idle timeout interval, it removes the client from the network.
# Specify the client idle timeout as 600 seconds.
[Sysname] wlan client idle-timeout 600
wlan client keep-alive
Use client keep-alive to specify the client keep alive interval.
Use undo client keep-alive to restore the default.
wlan client keep-alive interval
undo wlan client keep-alive
The client keep-alive functionality is disabled.
2: System level
interval: Interval between keep alive requests. The value is in the range of 3 to 1800 seconds.
The keep-alive mechanism is used to detect clients that are segregated from the system for various reasons such as power failure or crash, and disconnect them from the AP.
# Specify the client keep-alive interval as 60 seconds.
[Sysname] wlan client keep-alive 60
wlan country-code
Use wlan country-code to specify the global country code.
Use undo wlan country-code to restore the default.
wlan country-code code
The global country code value is CN.
2: System level
code: Specifies a global country code. See Table 10.
Table 10 Country code information
Country
Code
Country
Code
Andorra
AD
Korea, Republic of Korea
KR
United Arab Emirates
AE
Kenya
KE
Albania
AL
Kuwait
KW
Armenia
AM
Kazakhstan
KZ
Australia
AU
Lebanon
LB
Argentina
AR
Liechtenstein
LI
Australia
AT
Sri Lanka
LK
Azerbaijan
AZ
Lithuania
LT
Bosnia and Herzegovina
BA
Luxembourg
LU
Belgium
BE
Latvia
LV
Bulgaria
BG
Libyan
LY
Bahrain
BH
Morocco
MA
Brunei Darussalam
BN
Monaco
MC
Bolivia
BO
Moldova
MD
Brazil
BR
Macedonia
MK
Bahamas
BS
Macau
MO
Belarus
BY
Martinique
MQ
Belize
BZ
Malta
MT
Canada
CA
Mauritius
MU
Switzerland
CH
Mexico
MX
Cote d'ivoire
CI
Malay Archipelago
MY
Chile
CL
Namibia
NA
China
CN
Nigeria
NG
Colombia
CO
Nicaragua
NI
Costarica
CR
Netherlands
NL
Serbia
RS
Norway
NO
Cyprus
CY
New Zealand
NZ
Czech Republic
CZ
Oman
OM
Germany
DE
Panama
PA
Denmark
DK
Peru
PE
Dominica
DO
Poland
PL
Algeria
DZ
Philippines
PH
Ecuador
EC
Pakistan
PK
Estonia
EE
Puerto Rico
PR
Egypt
EG
Portugal
PT
Spain
ES
Paraguay
PY
Faroe Islands
FO
Qatar
QA
Finland
FI
Romania
RO
France
FR
Russian Federation
RU
Britain
GB
Saudi Arabia
SA
Georgia
GE
Sweden
SE
Gibraltar
GI
Singapore
SG
Greenland
GL
Slovenia
SI
Guadeloupe
GP
Slovak
SK
Greece
GR
San Marino
SM
Guatemala
GT
Salvador
SV
Guyana
GY
Syrian
SY
Honduras
HN
Thailand
TH
Hong Kong
HK
Tunisia
TN
Croatia
HR
Turkey
TR
Hungary
HU
Trinidad and Tobago
TT
Iceland
IS
, Province of China
TW
India
IN
Ukraine
UA
Indonesia
ID
United States of America
US
Ireland
IE
Uruguay
UY
Israel
IL
Uzbekistan
UZ
Iraq
IQ
The Vatican City State
VA
Italy
IT
Venezuela
VE
Iran
IR
Virgin Islands
VI
Jamaica
JM
Vietnam
VN
Jordan
JO
Yemen
YE
Japan
JP
South Africa
ZA
Democratic People's Republic of Korea
KP
Zimbabwe
ZW
The country code determines characteristics such as the power level and the total number of channels. You must set the correct country code or area code for the AP.
# Specify the global country code as US.
[Sysname] wlan country-code us
wlan link-test
Use wlan link-test to RFPing a client.
wlan link-test mac-address
1: Monitor level
mac-address: MAC address of a client. Only clients that have been associated with the AP can be RFPinged.
# Perform an RFPing operation on the client with the MAC address 000f-e201-0101.
<Sysname> wlan link-test 000f-e201-0101
Testing link to 000f-e201-0101, press CTRL_C to break......
                                   Link Status
 RTT: Round trip time
 MAC Address: 000f-e201-0101
 VHT-MCS Rate(Mbps)  TxCnt   RxCnt   RSSI    Retries     RTT(ms)
NSS = 1
 0      29.3        5       5       68      0           3
 1      58.5        5       5       69      0           0
 2      97.5        5       4       70      2           0
 3      117         5       4       71      2           0
 4      175.5       5       5       70      0           0
 5      234         5       5       69      0           0
 6      263.3       5       5       69      0           0
 7      292.5       5       5       69      0           0
 8      351         5       5       69      0           0
 9      390         5       5       69      0           0
 NSS = 2
 0      58.5        5       5       69      0           0
 1      117         5       4       70      2           0
 2      175.5       5       5       70      0           0
 3      234         5       5       70      0           0
 4      351         5       5       69      0           0
 5      520         5       4       70      2           0
 6      526.5       5       4       69      2           0
 7      585         5       5       69      0           0
 8      702         5       5       70      0           0
 9      780         5       5       69      0           0
 NSS = 3
 0      87.8        5       5       70      0           0
 1      175.5       5       5       70      0           0
 2      263.3       5       5       70      0           0
 3      351         5       5       70      0           0
 4      526.5       5       4       69      2           0
 5      702         5       4       69      6           0
 6      NA          5       0       0       0           0
 7      975         5       0       0       10          0
 8      1170        5       0       0       10          0
 9      1300        5       0       0       10          0
Table 11 RFPing operation results
No./MCS
·         The VHT-MCS field is displayed for an RFPing operation to an 802.11ac client to indicate the VHT-MCS value of the client.
·         The No. field is displayed for an RFPing operation to a non-802.11n client or a non-802.11ac client to indicate the rate index of the client.
·         The MCS field is displayed for an RFPing operation to an 802.11n client to indicate the MCS value of the client.
Rate(Mbps)
Rate for the radio interface to send ping packets.
TxCnt
Number of ping packets sent by the radio interface.
RxCnt
Number of ping packets received by the radio interface from the client.
RSSI
Received signal strength indicator (RSSI).
Retries
Number of retries when the radio interface failed to send ping packets.
RTT(ms)
RTT from the time the radio interface sends a ping packet to the time it receives a response from the client.
NSS
The NSS field is displayed for an RFPing operation to an 802.11ac client to indicate the supported number of spatial streams of the client.
Use wlan service-template to create a service template and enter service template view. If the service template exists, you can directly enter service template view.
Use undo wlan service-template to delete the service template and related configurations. If the specified service template is mapped to a radio, it cannot be directly deleted before it is un-mapped.
wlan service-template service-template-number { clear | crypto }
undo wlan service-template service-template-number
The default setting for this command depends on your device model.
2: System level
service-template-number: Number of the service template, in the range of 1 to 1024.
clear: Sets the current service template type to clear, which means data will be sent in clear text after the template is mapped to an AP.
crypto: Sets the current service template type to crypto, which means data will be sent in cipher text after the template is mapped to an AP.
You cannot change an existing service template to another type. To do so, delete the existing service template and configure a new service template with the new type.
# Create service template 1.
[Sysname] wlan service-template 1 crypto
[Sysname-wlan-st-1]
wlan-client-isolation enable
Use wlan-client-isolation enable to enable WLAN client isolation.
Use undo wlan-client-isolation enable to disable WLAN client isolation.
WLAN client isolation is enabled.
2: System level
# Disable WLAN client isolation.
[Sysname] undo wlan-client-isolation enable
wlan uplink-interface
Use wlan uplink-interface to specify an uplink interface.
Use undo wlan uplink-interface to remove the configuration.
wlan uplink-interface interface-type interface-number
undo wlan uplink-interface interface-type interface-number
No uplink interface is configured.
2: System level
If all configured uplink interfaces are down, WLAN service is unavailable. If one of them is up, WLAN service is available.
You can specify an Ethernet port or a WLAN-Radio interface as an uplink interface as needed. If you specify a WLAN-Radio interface as an uplink interface, you also need to map a mesh profile to the interface.
You can use this command to configure multiple uplink interfaces.
# Configure GigabitEthernet 1/0/1 as an uplink interface.
[Sysname] wlan uplink-interface GigabitEthernet 1/0/1
