06-Layer 3 - IP Routing Configuration Guide
HomeSupportResource CenterSwitchesH3C S10500X Switch SeriesH3C S10500X Switch SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S10500X Switch Series Configuration Guides-Release757X-6W10006-Layer 3 - IP Routing Configuration Guide
02-Static routing configuration
02-Static routing configuration 193.05 KB
Configuring static routing
Static routes are manually configured. If a network's topology is simple, you only need to configure static routes for the network to work correctly.
Static routes cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually.
Configuring a static route
Before you configure a static route, complete the following tasks:
·          Configure the physical parameters for related interfaces.
·          Configure the link-layer attributes for related interfaces.
·          Configure the IP addresses for related interfaces.
You can associate Track with a static route to monitor the reachability of the next hops. For more information about Track, see High Availability Configuration Guide.
To configure a static route:
Step
Remarks
1.       Enter system view.
N/A
2.       (Optional.) Create a static route group and enter its view.
ip route-static-group group-name
By default, no static route group is configured.
3.       (Optional.) Add a static route prefix to the static route group.
prefix dest-address { mask-length | mask }
By default, no static route prefix is added to the static route group.
4.       (Optional.) Return to system view.
N/A
5.       Configure a static route.
·         Method 1:
ip
route-static { dest-address { mask-length | mask } | group group-name } { interface-type interface-number [ next-hop-address ] | next-hop-address [ recursive-lookup host-route ] | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
·         Method 2:
ip route-static vpn-instance s-vpn-instance-name { dest-address { mask-length | mask } | group group-name } { interface-type interface-number [ next-hop-address ] | next-hop-address [ recursive-lookup host-route ] [ public ] | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ]  } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, no static route is configured.
6.       (Optional.) Enable periodic sending of ARP requests to the next hops of static routes.
ip route-static arp-request interval interval
By default, the device does not send ARP requests to the next hops of static routes.
7.       (Optional.) Configure the default preference for static routes.
ip route-static default-preference default-preference
The default setting is 60.
8.       (Optional.) Delete all static routes, including the default route.
delete [ vpn-instance vpn-instance-name ] static-routes all
To delete one static route, use the undo ip route-static command.
Configuring BFD for static routes
IMPORTANT
IMPORTANT:
Enabling BFD for a flapping route could worsen the situation.
BFD provides a general-purpose, standard, medium-, and protocol-independent fast failure detection mechanism. It can uniformly and quickly detect the failures of the bidirectional forwarding paths between two routers for protocols, such as routing protocols and MPLS.
For more information about BFD, see High Availability Configuration Guide.
Bidirectional control mode
To use BFD bidirectional control detection between two devices, enable BFD control mode for each device's static route destined to the peer.
To configure a static route and enable BFD control mode, use one of the following methods:
·          Specify an output interface and a direct next hop.
·          Specify an indirect next hop and a specific BFD packet source address for the static route.
To configure BFD control mode for a static route (direct next hop):
Step
Remarks
N/A
2.       Configure BFD control mode for a static route.
·         Method 1:
ip route-static dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd control-packet [ preference preference ] [ tag tag-value ] [ description text ]
·         Method 2:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd control-packet [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD control mode for a static route is not configured.
To configure BFD control mode for a static route (indirect next hop):
Step
Remarks
N/A
·         Method 1:
ip route-static dest-address { mask-length | mask } { next-hop-address bfd control-packet bfd-source ip-address | vpn-instance d-vpn-instance-name next-hop-address bfd control-packet bfd-source ip-address } [ preference preference ] [ tag tag-value ] [ description text ]
·         Method 2:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { next-hop-address bfd control-packet bfd-source ip-address | vpn-instance d-vpn-instance-name next-hop-address bfd control-packet bfd-source ip-address } [ preference preference ] [ tag tag-value ] [ description text ]
Single-hop echo mode
With BFD echo mode enabled for a static route, the output interface sends BFD echo packets to the destination device, which loops the packets back to test the link reachability.
IMPORTANT:
Do not use BFD for a static route with the output interface in spoofing state.
To configure BFD echo mode for a static route:
Step
Remarks
N/A
2.       Configure the source address of echo packets.
bfd echo-source-ip ip-address
By default, the source address of echo packets is not configured.
For more information about this command, see High Availability Command Reference.
3.       Configure BFD echo mode for a static route.
·         Method 1:
ip route-static dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd echo-packet [ preference preference ] [ tag tag-value ] [ description text ]
·         Method 2:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd echo-packet [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD echo mode for a static route is not configured.
Configuring static route FRR
A link or router failure on a path can cause packet loss and even routing loop. Static route fast reroute (FRR) enables fast rerouting to minimize the impact of link or node failures.
Figure 1 Network diagram
As shown in Figure 1, upon a link failure, packets are directed to the backup next hop to avoid traffic interruption. You can either specify a backup next hop for FRR or enable FRR to automatically select a backup next hop (which must be configured in advance).
When you configure static route FRR, follow these restrictions and guidelines:
·          Do not use static route FRR and BFD (for a static route) at the same time.
·          Static route does not take effect when the backup output interface is unavailable.
·          Equal-cost routes do not support static route FRR.
·          The backup output interface and next hop must be different from the primary output interface and next hop.
·          To change the backup output interface or next hop, you must first remove the current setting.
·          Besides the configured static route for FRR, the device must have another route to reach the destination.
When the state of the primary link (with Layer 3 interfaces staying up) changes from bidirectional to unidirectional or down, static route FRR quickly redirects traffic to the backup next hop. When the Layer 3 interfaces of the primary link are down, static route FRR temporarily redirects traffic to the backup next hop. In addition, the device searches for another route to reach the destination and redirects traffic to the new path if a route is found. If no route is found, traffic interruption occurs.
Configuring static route FRR by specifying a backup next hop
Step
Remarks
N/A
2.       Configure static route FRR.
·         Method 1:
ip route-static dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
·         Method 2:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, static route FRR is disabled.
Configuring static route FRR to automatically select a backup next hop
Step
Remarks
N/A
2.       Configure static route FRR to automatically select a backup next hop.
ip route-static fast-reroute auto
By default, static route FRR is disabled from automatically selecting a backup next hop.
Enabling BFD echo packet mode for static route FRR
By default, static route FRR uses ARP to detect primary link failures. Perform this task to enable static route FRR to use BFD echo packet mode for fast failure detection on the primary link.
To enable BFD echo packet mode for static route FRR:
Step
Remarks
N/A
2.       Configure the source IP address of BFD echo packets.
By default, the source IP address of BFD echo packets is not configured.
The source IP address cannot be on the same network segment as any local interface's IP address.
3.       Enable BFD echo packet mode for static route FRR.
ip route-static primary-path-detect bfd echo
By default, BFD echo mode for static route FRR is disabled.
Displaying and maintaining static routes
Display static route information.
display ip routing-table protocol static [ inactive | verbose ]
Display static route next hop information.
display route-static nib [ nib-id ] [ verbose ]
Display static routing table information.
display route-static routing-table [ vpn-instance vpn-instance-name ] [ ip-address { mask-length | mask } ]
Static route configuration examples
Basic static route configuration example
Network requirements
As shown in Figure 2, configure static routes on the switches for interconnections between any two hosts.
Figure 2 Network diagram
Configuration procedure
1.        Configure IP addresses for interfaces. (Details not shown.)
2.        Configure static routes:
# Configure a default route on Switch A.
[SwitchA] ip route-static 0.0.0.0 0.0.0.0 1.1.4.2
# Configure two static routes on Switch B.
[SwitchB] ip route-static 1.1.2.0 255.255.255.0 1.1.4.1
[SwitchB] ip route-static 1.1.3.0 255.255.255.0 1.1.5.6
# Configure a default route on Switch C.
[SwitchC] ip route-static 0.0.0.0 0.0.0.0 1.1.5.5
3.        Configure the default gateways of Host A, Host B, and Host C as 1.1.2.3, 1.1.6.1, and 1.1.3.1. (Details not shown.)
# Display static routes on Switch A.
[SwitchA] display ip routing-table protocol static
Summary Count : 1
Static Routing table Status : <Active>
Summary Count : 1
0.0.0.0/0           Static 60   0            1.1.4.2         Vlan500
Static Routing table Status : <Inactive>
Summary Count : 0
# Display static routes on Switch B.
[SwitchB] display ip routing-table protocol static
Summary Count : 2
Summary Count : 2
1.1.2.0/24          Static 60   0            1.1.4.1         Vlan500
Summary Count : 0
# Use the ping command on Host B to test the reachability of Host A (Windows XP runs on the two hosts).
C:\Documents and Settings\Administrator>ping 1.1.2.2
Pinging 1.1.2.2 with 32 bytes of data:
Reply from 1.1.2.2: bytes=32 time=1ms TTL=126
Ping statistics for 1.1.2.2:
# Use the tracert command on Host B to test the reachability of Host A.
C:\Documents and Settings\Administrator>tracert 1.1.2.2
Tracing route to 1.1.2.2 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  1.1.6.1
  2    <1 ms    <1 ms    <1 ms  1.1.4.1
  3     1 ms    <1 ms    <1 ms  1.1.2.2
Trace complete.
BFD for static routes configuration example (direct next hop)
Configure the following, as shown in Figure 3:
·          Configure a static route to subnet 120.1.1.0/24 on Switch A.
·          Configure a static route to subnet 121.1.1.0/24 on Switch B.
·          Enable BFD for both routes.
·          Configure a static route to subnet 120.1.1.0/24 and a static route to subnet 121.1.1.0/24 on Switch C.
When the link between Switch A and Switch B through the Layer 2 switch fails, BFD can detect the failure immediately. Switch A then communicates with Switch B through Switch C.
Figure 3 Network diagram
Device
IP address
Switch A
VLAN-interface 10
12.1.1.1/24
Switch A
VLAN-interface 11
10.1.1.102/24
Switch B
VLAN-interface 10
12.1.1.2/24
Switch B
VLAN-interface 13
13.1.1.1/24
Switch C
VLAN-interface 11
10.1.1.100/24
Switch C
VLAN-interface 13
13.1.1.2/24
1.        Configure IP addresses for the interfaces. (Details not shown.)
2.        Configure static routes and BFD:
# Configure static routes on Switch A and enable BFD control mode for the static route that traverses the Layer 2 switch.
[SwitchA-vlan-interface10] bfd min-transmit-interval 500
[SwitchA-vlan-interface10] bfd min-receive-interval 500
[SwitchA-vlan-interface10] bfd detect-multiplier 9
[SwitchA-vlan-interface10] quit
[SwitchA] ip route-static 120.1.1.0 24 vlan-interface 10 12.1.1.2 bfd control-packet
[SwitchA] ip route-static 120.1.1.0 24 vlan-interface 11 10.1.1.100 preference 65
[SwitchA] quit
# Configure static routes on Switch B and enable BFD control mode for the static route that traverses the Layer 2 switch.
[SwitchB-vlan-interface10] bfd min-transmit-interval 500
[SwitchB-vlan-interface10] bfd min-receive-interval 500
[SwitchB-vlan-interface10] bfd detect-multiplier 9
[SwitchB-vlan-interface10] quit
[SwitchB] ip route-static 121.1.1.0 24 vlan-interface 10 12.1.1.1 bfd control-packet
[SwitchB] ip route-static 121.1.1.0 24 vlan-interface 13 13.1.1.2 preference 65
[SwitchB] quit
# Configure static routes on Switch C.
[SwitchC] ip route-static 120.1.1.0 24 13.1.1.1
[SwitchC] ip route-static 121.1.1.0 24 10.1.1.102
# Display BFD sessions on Switch A.
<SwitchA> display bfd session
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 4/7            12.1.1.1        12.1.1.2        Up       2000ms      Vlan10
The output shows that the BFD session has been created.
# Display the static routes on Switch A.
<SwitchA> display ip routing-table protocol static
Summary Count : 1
Summary Count : 1
120.1.1.0/24        Static 60   0            12.1.1.2        Vlan10
Summary Count : 0
The output shows that Switch A communicates with Switch B through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
Summary Count : 1
Summary Count : 1
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
120.1.1.0/24        Static 65   0            10.1.1.100      Vlan11
Summary Count : 0
The output shows that Switch A communicates with Switch B through VLAN-interface 11.
BFD for static routes configuration example (indirect next hop)
Figure 4 shows the network topology as follows:
·          Switch A has a route to interface Loopback 1 (2.2.2.9/32) on Switch B, with the output interface VLAN-interface 10.
·          Switch B has a route to interface Loopback 1 (1.1.1.9/32) on Switch A, with the output interface VLAN-interface 12.
·          Switch D has a route to 1.1.1.9/32, with the output interface VLAN-interface 10, and a route to 2.2.2.9/32, with the output interface VLAN-interface 12.
Configure the following:
·          Configure a static route to subnet 120.1.1.0/24 and a static route to subnet 121.1.1.0/24 on both Switch C and Switch D.
When the link between Switch A and Switch B through Switch D fails, BFD can detect the failure immediately. Switch A then communicates with Switch B through Switch C.
Figure 4 Network diagram
Device
IP address
Switch A
VLAN-interface 10
12.1.1.1/24
Switch A
VLAN-interface 11
10.1.1.102/24
Switch A
Loopback 1
1.1.1.9/32
Switch B
VLAN-interface 12
11.1.1.1/24
Switch B
VLAN-interface 13
13.1.1.1/24
Switch B
Loopback 1
2.2.2.9/32
Switch C
VLAN-interface 11
10.1.1.100/24
Switch C
VLAN-interface 13
13.1.1.2/24
Switch D
VLAN-interface 10
12.1.1.2/24
Switch D
VLAN-interface 12
11.1.1.2/24
# Configure static routes on Switch A and enable BFD control mode for the static route that traverses Switch D.
[SwitchA] bfd multi-hop min-transmit-interval 500
[SwitchA] bfd multi-hop min-receive-interval 500
[SwitchA] bfd multi-hop detect-multiplier 9
[SwitchA] ip route-static 120.1.1.0 24 2.2.2.9 bfd control-packet bfd-source 1.1.1.9
[SwitchA] quit
# Configure static routes on Switch B and enable BFD control mode for the static route that traverses Switch D.
[SwitchB] bfd multi-hop min-transmit-interval 500
[SwitchB] bfd multi-hop min-receive-interval 500
[SwitchB] bfd multi-hop detect-multiplier 9
[SwitchB] ip route-static 121.1.1.0 24 1.1.1.9 bfd control-packet bfd-source 2.2.2.9
[SwitchB] quit
# Configure static routes on Switch D.
<SwitchD> system-view
[SwitchD] ip route-static 120.1.1.0 24 11.1.1.1
[SwitchD] ip route-static 121.1.1.0 24 12.1.1.1
 4/7            1.1.1.9         2.2.2.9         Up       2000ms      N/A
Summary Count : 1
Summary Count : 1
Summary Count : 0
Summary Count : 1
Summary Count : 1
Summary Count : 0
Static route FRR configuration example
As shown in Figure 5, configure static routes on Switch A, Switch B, and Switch C, and configure static route FRR. When Link A becomes unidirectional, traffic can be switched to Link B immediately.
Figure 5 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Switch A
VLAN-interface 100
12.12.12.1/24
Switch A
VLAN-interface 200
13.13.13.1/24
Switch A
Loopback 0
1.1.1.1/32
Switch B
VLAN-interface 101
24.24.24.4/24
Switch B
VLAN-interface 200
13.13.13.2/24
Switch B
Loopback 0
4.4.4.4/32
Switch C
VLAN-interface 100
12.12.12.2/24
Switch C
VLAN-interface 101
24.24.24.2/24
2.        Configure static route FRR on link A by using one of the following methods:
¡  (Method 1.) Specify a backup next hop for static route FRR:
# Configure a static route on Switch A, and specify VLAN-interface 100 as the backup output interface and 12.12.12.2 as the backup next hop.
[SwitchA] ip route-static 4.4.4.4 32 vlan-interface 200 13.13.13.2 backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
# Configure a static route on Switch B, and specify VLAN-interface 101 as the backup output interface and 24.24.24.2 as the backup next hop.
[SwitchB] ip route-static 1.1.1.1 32 vlan-interface 200 13.13.13.1 backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
¡  (Method 2.) Configure static route FRR to automatically select a backup next hop:
# Configure static routes on Switch A, and enable static route FRR.
[SwitchA] ip route-static 4.4.4.4 32 vlan-interface 100 12.12.12.2 preference 70
[SwitchA] ip route-static fast-reroute auto
# Configure static routes on Switch B, and enable static route FRR.
[SwitchB] ip route-static 1.1.1.1 32 vlan-interface 101 24.24.24.2 preference 70
[SwitchB] ip route-static fast-reroute auto
3.        Configure static routes on Switch C.
[SwitchC] ip route-static 4.4.4.4 32 vlan-interface 101 24.24.24.4
[SwitchC] ip route-static 1.1.1.1 32 vlan-interface 100 12.12.12.1
# Display route 4.4.4.4/32 on Switch A to view the backup next hop information.
[SwitchA] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.4/32
   Protocol: Static
 Process ID: 0
  SubProtID: 0x0                     Age: 04h20m37s
       Cost: 0                Preference: 60
      IpPre: N/A              QosLocalID: N/A
        Tag: 0                     State: Active Adv
  OrigTblID: 0x0                 OrigVrf: default-vrf
    TableID: 0x2                  OrigAs: 0
      NibID: 0x26000002           LastAs: 0
     AttrID: 0xffffffff         Neighbor: 0.0.0.0
      Flags: 0x1008c         OrigNextHop: 13.13.13.2
      Label: NULL            RealNextHop: 13.13.13.2
    BkLabel: NULL              BkNextHop: 12.12.12.2
  Tunnel ID: Invalid           Interface: Vlan-interface200
BkTunnel ID: Invalid         BkInterface: Vlan-interface100
   FtnIndex: 0x0            TrafficIndex: N/A
  Connector: N/A
# Display route 1.1.1.1/32 on Switch B to view the backup next hop information.
[SwitchB] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
Destination: 1.1.1.1/32
   Protocol: Static
 Process ID: 0
      Flags: 0x1008c         OrigNextHop: 13.13.13.1
      Label: NULL            RealNextHop: 13.13.13.1
    BkLabel: NULL              BkNextHop: 24.24.24.2
BkTunnel ID: Invalid         BkInterface: Vlan-interface101
  Connector: N/A
Configuring a default route
A default route is used to forward packets that do not match any specific routing entry in the routing table. Without a default route, packets that do not match any routing entries are discarded and an ICMP destination-unreachable packet is sent to the source.
A default route can be configured in either of the following ways:
·          The network administrator can configure a default route with both destination and mask being 0.0.0.0. For more information, see "Configuring static routing."
·          Some dynamic routing protocols, such as OSPF, RIP, and IS-IS, can generate a default route. For example, an upstream router running OSPF can generate a default route and advertise it to other routers. These routers install the default route with the next hop being the upstream router. For more information, see the respective chapters on these routing protocols in this configuration guide.
  • Become a Partner
  • Partner Resources
