H3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
Table of Contents
Related Documents
33-Control Plane-Based QoS Policy Configuration Examples
Introduction
This chapter provides examples for configuring control plane-based QoS policies.
This document assumes that you have basic knowledge of QoS policies.
Example: Rate limiting ICMP packets
As shown in Figure 1, the device receives a large number of ICMP packets from the Internet. As a result, CPU usage is high, and device performance degrades.
Configure a control plane-based QoS policy to meet the following requirements:
·     Rate limit ICMP packets sent to the control plane to 320 kbps.
·     Drop excess ICMP packets.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     Use the if-match command to classify ICMP packets into a class.
·     Use the car command to configure the rate limit value for ICMP packets and drop excess packets.
Hardware
Software version
S6520XE-HI switch series
Supported in Release 11xx
S5560X-EI switch series
Not supported
S5500V2-EI switch series
Not supported
MS4520V2-30F switch
Not supported
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
Not supported
S5000E-X switch series
Not supported
WAS6000 switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4520V2 switch series (except the MS4520V2-30F switch)
Not supported
MS4320V2 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
Procedures
# Create a class named ICMP, and use the ICMP protocol as the match criterion.
[Device] traffic classifier ICMP
[Device-classifier-ICMP] if-match control-plane protocol icmp
[Device-classifier-ICMP] quit
# Create a behavior named ICMP, and configure a CAR action for ICMP packets.
[Device] traffic behavior ICMP
[Device-behavior-ICMP] car cir 320
[Device-behavior-ICMP] quit
# Create a QoS policy named ICMP, and associate the class ICMP with the behavior ICMP in the QoS policy.
[Device] qos policy ICMP
[Device-qospolicy-ICMP] classifier ICMP behavior ICMP
[Device-qospolicy-ICMP] quit
# Apply the QoS policy ICMP to the inbound direction of the control plane.
[Device] control-plane slot 1
[Device-cp-slot1] qos apply policy ICMP inbound
[Device-cp-slot1] quit
Verify the configuration
# Verify that the QoS policy is correctly applied to the control plane.
[Device] display qos policy control-plane slot 1
Control plane slot 1
  Direction: Inbound
  Policy: ICMP
   Classifier: ICMP
     Operator: AND
     Rule(s) :
      If-match control-plane protocol icmp
     Behavior: ICMP
      Committed Access Rate:
        CIR 320 (kbps), CBS 20480 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
        Green packets : 0 (Packets)
        Red packets   : 0 (Packets)
Configuration files
traffic classifier ICMP operator and
 car cir 320 cbs 20480 ebs 0 green pass red discard yellow pass
qos policy ICMP
