H3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
HomeSupportSwitchesH3C S9500 Series SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-04 IP Multicast Volume
03-IGMP Commands
03-IGMP Commands 126.33 KB
Chapter 1  IGMP Configuration Commands
&  Note:
The term “router” in this document refers to a router in a generic sense or an S9500 series routing switch running IGMP.
1.1  IGMP Configuration Commands
1.1.1  debugging igmp
debugging igmp { all | event | leave [ basic-acl-number ] | report [ advanced-acl-number ] | query [ advanced-acl-number ] | timer }
undo debugging igmp { all | event | leave | report | query | timer }
View
Default Level
1: Monitor level
Parameter
all: Specifies all types of IGMP debugging.
event: Specifies IGMP event debugging.
leave: Specifies IGMP leave message debugging.
basic-acl-number: Basic ACL number.
report: Specifies IGMP report message debugging.
advanced-acl-number: Advanced ACL number.
query: Specifies IGMP query message debugging.
timer: Specifies IGMP timer debugging.
Use the debugging igmp command to enable IGMP debugging.
Use the undo debugging igmp command to disable IGMP debugging.
By default, IGMP debugging is disabled.
Table 1-1 debugging igmp event command output description
Creating/creation/created
aux join/aux prune
adding interface/deleting downstream
deleting/unregister/deleted
Enqueue/Dequeing
Elected/ Un-elected
Event types include:
l      Creating/creation/created
l      Join/prune
l      Adding outgoing interface/deleting outgoing interface
l      Being deleted/unregistered/deleted
l      Enqueuing/dequeuing
l      Elected/un-elected
Interface interfacename(ifadd)
Interface that responds to events (interface address)
(sadd, gadd)
(S, G) entry
(*, gadd)
(*, G) entry
Table 1-2 debugging igmp leave command output description
LEAVE
IGMP leave message
Interfacename(ifadd)
Interface that receives messages (interface address)
group gadd
Address of the group that a host will leave
Ignoring
Ignoring the IGMP leave message
Table 1-3 debugging igmp query command output description
version <1-3>
Version of the IGMP query
Interface that sends/receives messages (interface address)
Ignoring
Ignoring the IGMP query
Received/Send
Received/sent IGMP query
General/group specific query/group-source specific query
IGMP general query/group-specific query/group-and-source specific query
Group gadd
Group address to be queried
Table 1-4 debugging igmp report command output description
Ignoring
Ignoring the IGMP membership report message
IS_IN/IS_EX/TO_IN/TO_EX/ALLOW/BLOCK
Record type of IGMPv3 membership report
Group gadd
Group address of IGMP membership report
(sadd, gadd)
(S, G) entry
v1/v2/v3
Version of IGMP membership report
Interface that sent/received messages (interface address)
Table 1-5 debugging igmp timer command output description
Source sadd timeout
The multicast source timer times out.
Group gadd timeout
The multicast group timer times out.
Other querier present timeout
The other querier present interval timer times out.
Deleting v1 host timer
IGMPv1 host timer times out.
Deleting v2 host timer
IGMPv2 host timer times out.
Setting v1 host timer
Setting IGMPv1 host timer
Setting v2 host timer
Setting IGMPv2 host timer
Example
# Enable IGMP timer debugging.
<Sysname> debugging igmp timer
*Mar 26 14:20:10:635 2007 Sysname IGMP/7/TIMER:Setting v2 host timer for group 235.1.1.1 on interface Vlan-interface20(1.1.1.1) (B033137)
// IGMPv2 host timer is set.
*Mar 26 14:20:11:635 2007 Sysname IGMP/7/TIMER:Group 235.1.1.1 timeout. Deleting group record associated with interface Vlan-interface20(1.1.1.1). (B012920)
// The multicast group timer times out.
1.1.2  display igmp group
display igmp group [ group-address | interface interface-type interface-number ] [ static | verbose ]
View
Default Level
1: Monitor level
Parameter
group-address: Multicast group address.
interface interface-type interface-number: Displays the IGMP multicast group information about a particular interface.
static: Displays the information of statically joined IGMP multicast groups.
verbose: Displays the detailed information of IGMP multicast groups.
Use the display igmp group command to view IGMP multicast group information.
Note that:
l           If you do not specify a multicast group address, this command will display the IGMP information of all multicast groups.
l           If you do not specify an interface, this command will display the IGMP multicast group information on all the interfaces.
l           If you do not use the static keyword, this command will display the detailed information about dynamically joined IGMP multicast groups.
Example
# Display the information about dynamically joined IGMP multicast groups on all interfaces.
<Sysname> display igmp group
Total 3 IGMP Group(s).
Interface group report information
 Vlan-interface245(192.168.245.2):
 Total 3 IGMP Groups reported
  Group Address       Last Reporter   Uptime      Expires
   239.192.0.1     192.168.245.1   00:02:25    00:01:53
   239.192.245.1   192.168.245.1   00:02:17    00:01:49
   239.255.255.250 192.168.245.111 00:02:24    00:01:55
Table 1-6 display igmp group command output description
Group address
Last reporter
Address of the last host that reported its multicast membership
Uptime
Length of time for which the multicast group has been up (hours:minutes:seconds)
Expires
Length of time in which the multicast group will expire (hours:minutes:seconds)
1.1.3  display igmp group port-info
display igmp group port-info [ vlan vlan-id ] [ slot slot-id ] [ verbose ]
View
Default Level
1: Monitor level
Parameter
vlan-id: VLAN ID. If you do not specify a VLAN, this command will display the Layer 2 port information of IGMP multicast groups in all VLANs.
slot slot-id: Displays the Layer 2 port information about IGMP multicast groups on the specified card. If you do not specify a slot number, this command will display the Layer 2 port information about IGMP multicast groups on the SRPU.
verbose: Displays the detailed information about Layer 2 ports of IGMP multicast groups.
Use the display igmp group port-info command to view Layer 2 port information of IGMP multicast groups..
Example
# View detailed Layer 2 ports information of IGMP multicast groups.
<Sysname> display igmp group port-info verbose
    Total 4 IP Group(s).
    Total 4 IP Source(s).
    Total 4 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, A-Aggregation port, C-Copy port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):12.
    Total 1 IP Group(s).
    Total 1 IP Source(s).
    Total 1 MAC Group(s).
    Router port(s):total 1 port.
            Eth2/1/15                            (D)
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:225.1.1.1
        (10.1.1.3, 225.1.1.1):
          Attribute:    MFIB
          Host port(s):total 0 port.
    MAC group(s):
      MAC group address:0100-5e01-0101
  Vlan(id):245.
    Total 3 IP Group(s).
    Total 3 IP Source(s).
    Total 3 MAC Group(s).
    Router port(s):total 0 port.
      IP group address:239.192.0.1
        (0.0.0.0, 239.192.0.1):
          Attribute:    Host Board
          Host port(s):total 1 port.
            Eth2/1/20                            (D)
    MAC group(s):
      MAC group address:0100-5e40-0001
            Eth2/1/20
      IP group address:239.255.255.250
        (0.0.0.0, 239.255.255.250):
            Eth2/1/20                            (D)
    MAC group(s):
      MAC group address:0100-5e7f-fffa
            Eth2/1/20
      IP group address:239.192.245.1
        (0.0.0.0, 239.192.245.1):
            Eth2/1/20                            (D)
    MAC group(s):
      MAC group address:0100-5e40-f501
            Eth2/1/20
Table 1-7 display igmp group port-info command output description
Total number of IP multicast groups
Total number of IP multicast sources
Total number of MAC multicast groups
Port flags: D for dynamic port, S for static port, A for aggregation port, and C for a port copied from a (*, G) entry to an (S, G) entry
Sub-VLAN flags: R for a real egress sub-VLAN under the current entry, and C for a sub-VLAN copied from a (*, G) entry to an (S, G) entry
Router port(s)
Number of router ports
IP group address
Address of IP multicast group
MAC group address
Address of MAC multicast group
Attribute
Attribute of IP multicast group
Host port(s)
Number of host ports
1.1.4  display igmp interface
display igmp interface [ interface-type interface-number ] [ verbose ]
View
Default Level
1: Monitor level
Parameter
interface-type interface-number: Specifies an interface to display the IGMP information about. If no interface is specified, this command will display the related information of all IGMP-enabled interfaces.
verbose: Displays the detailed IGMP configuration and running information.
Use the display igmp interface command to view IGMP configuration and running information of the specified interface or all IGMP-enabled interfaces.
Example
# View the IGMP configuration and running status on all IGMP-enabled interfaces.
<Sysname> display igmp interface
Interface information
 Vlan-interface240(10.1.2.2):
   IGMP is enabled
   Current IGMP version is 2
   Value of query interval for IGMP(in seconds): 60
   Value of other querier present interval for IGMP(in seconds): 125
   Value of maximum query response time for IGMP(in seconds): 10
   Querier for IGMP: 10.1.2.2 (this router)
   IGMP is enabled
   Querier for IGMP: 192.168.245.2 (this router)
Table 1-8 display igmp interface command output description
Interface name (IP address)
IGMP is enabled
IGMP is enabled.
Version of IGMP currently running on the interface
IGMP general query interval, in seconds
Other querier present interval, in seconds
Maximum response time for IGMP general queries, in seconds
Querier for IGMP
IP address of the querier
Total number of groups recorded on the interface.
1.1.5  display igmp routing-table
display igmp routing-table [ group-address [ mask { mask | mask-length } ] | source-address [ mask { mask | mask-length } ] ] *
View
Default Level
1: Monitor level
Parameter
source-address: Multicast source address.
mask: Subnet mask of the multicast group/source address, 255.255.255.255 by default.
mask-length: Subnet mask length of the multicast group/source address. For a multicast source address, this argument has an effective value range of 0 to 32; for a multicast group address, this argument has an effective value range of 4 to 32. The system default is 32 in both cases.
Use the display igmp routing-table command to view the routing information of the IGMP routing table.
&  Note:
After PIM is enabled on a VLAN interface or a POS interface, IGMP does not maintain the information related to the downstream interfaces any more. In this case, you cannot view the routing information of the IGMP routing table with the display igmp routing-table command.
Example
# View IGMP routing table information
<Sysname> display igmp routing-table
Routing table
 Total 2 entries
 00001. (*, 225.1.1.1)
       List of 1 downstream interface
        Vlan-interface245 (20.1.1.1),
                   Protocol: STATIC
 00002. (*, 239.255.255.250)
        Vlan-interface246 (20.20.20.20),
                   Protocol: IGMP
Table 1-9 display igmp routing-table command output description
00001
Sequence number the (*, G) entry
(*, 225.1.1.1)
An (*, G) entry of the IGMP routing table
Downstream interface list: these interfaces need to forward multicast packets
Protocol
Protocol type
1.1.6  fast-leave
fast-leave [ group-policy acl-number ]
undo fast-leave
View
IGMP view
Default Level
2: System view
Use the fast-leave command to enable fast leave processing for multicast group members globally.
Use the undo fast-leave command to disable fast leave processing globally.
By default, fast leave processing is disabled, namely, the IGMP querier sends an IGMP group-specific query upon receiving an IGMP leave message from a host, instead of sending a Leave notification directly to the upstream.
This command is the same as the igmp fast-leave command for interface view, but the value configured by the igmp fast-leave command has a higher priority, that is, the system gives priority to configurations made in interface view.
&  Note:
l      The configurations made by the fast-leave command in IGMP view are effective only for POS interfaces rather than VLAN interfaces.
l      To enable fast leave processing in a VLAN, you can use the igmp-snooping fast-leave or the fast-leave (IGMP Snooping) command. For more information, see IGMP Snooping Commands in the IP Multicast Volume.
Related commands: igmp fast-leave, last-member-query-interval.
# Enable the fast leave function globally.
[Sysname] igmp
[Sysname-igmp] fast-leave
1.1.7  igmp
igmp
undo igmp
View
Default Level
2: System level
None
Use the igmp command to enter IGMP view.
Use the undo igmp command to remove configurations performed in IGMP view.
Note that IP multicast must be enabled on the device before this command can take effect.
Related commands: igmp enable; multicast routing-enable in Multicast Routing and Forwarding Commands in the IP Multicast Volume.
# Enter IGMP view.
[Sysname] multicast routing-enable
[Sysname] igmp
[Sysname-igmp]
1.1.8  igmp enable
igmp enable
undo igmp enable
View
VLAN interface view, POS interface view
Default Level
2: System level
None
Use the igmp enable command to enable IGMP on the current interface.
Use the undo igmp enable command to disable IGMP on the current interface.
By default, IGMP is disabled on an interface.
Note that:
l           IP multicast must be enabled on the device before this command is meaningful.
l           Before IGMP is enabled on an interface, any other IGMP feature configured on the interface will not take effect.
l           After IGMP is enabled on a VLAN interface, IGMP Snooping cannot be enabled in the VLAN corresponding to the VLAN interface, and vice versa.
Related commands: igmp.
# Enable IGMP on VLAN-interface 11.
[Sysname-Vlan-interface11] igmp enable
1.1.9  igmp fast-leave
igmp fast-leave [ group-policy acl-number ]
undo igmp fast-leave
View
POS interface view
Default Level
2: System level
acl-number: Basic ACL number. If you do not include this option in your command, this command will take effect for all multicast groups.
Use the igmp fast-leave command to enable the fast leave function on the current interface for multicast group members.
Use the undo igmp fast-leave command to disable the fast leave function on the current interface.
By default, the fast leave function is disabled, namely, the IGMP querier sends an IGMP group-specific query upon receiving an IGMP leave message from a host, instead of sending a Leave notification directly to the upstream.
Related commands: fast-leave, igmp lastmember-queryinterval.
By using the group-policy keyword, you can configure an ACL rule to implement control specific to certain groups.
&  Note:
To enable fast leave in a VLAN, you can use the igmp-snooping fast-leave or fast-leave (IGMP Snooping view) command. For more information, refer to IGMP Snooping Commands in the IP Multicast Volume.
# Enable fast leave for multicast group members on POS 4/1/1.
[Sysname] interface pos 4/1/1
[Sysname-Pos4/1/1] igmp fast-leave
1.1.10  igmp group-policy
igmp group-policy acl-number [ version-number ]
undo igmp group-policy
View
POS interface view
Default Level
2: System level
acl-number: Basic or advanced ACL number.
version-number: IGMP version. If you do not specify an IGMP version, the configured group filter will apply to IGMP reports of all versions.
Use the igmp group-policy command to configure a multicast group filter on the current interface.
Use the undo igmp group-policy command to remove the configured multicast group filter.
Be default, no multicast group filter is configured, namely a host can join any multicast group.
&  Note:
l      When you use an advanced ACL as a filter, the source address in the ACL rule is the address of the multicast source specified in the IGMPv3 reports, rather than the source address in the IP packets.
l      To configure a multicast group filter on an Ethernet port, you can use the igmp-snooping group-policy or group-policy (IGMP Snooping view) command. For more information, refer to IGMP Snooping Commands in the IP Multicast Volume.
l      A multicast group filter is not effective for statically joined multicast groups on a POS interface.
Related commands: display igmp group.
# Configure an ACL rule so that hosts on the subnet attached to POS 4/1/1 can join multicast group 225.1.1.1 only.
[Sysname] acl number 2005
[Sysname-acl-basic-2005] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2005] quit
[Sysname-Pos4/1/1] igmp group-policy 2005
1.1.11  igmp last-member-query-interval
igmp last-member-query-interval interval
undo igmp last-member-query-interval
View
Default Level
2: System level
interval: IGMP last-member query interval in seconds.
Use the igmp last-member-query-interval command to configure the last-member query interval on the current interface.
Use the undo igmp last-member-query-interval command to restore the last member query interval to the system default on the current interface.
By default, the last-member query interval is 1 second.
Related commands: last-member-query-interval, igmp robust-count, display igmp interface.
# Set the last-member query interval to 3 seconds on Vlan-interface11.
[Sysname-Vlan-interface11] igmp last-member-query-interval 3
1.1.12  igmp max-response-time
igmp max-response-time interval
undo igmp max-response-time
View
Default Level
2: System level
interval: Maximum response time in seconds for IGMP general queries.
Use the igmp max-response-time command to configure the maximum response time for IGMP general queries on the current interface.
Use the undo igmp max-response-time command to restore the maximum response time for IGMP general queries to the system default.
By default, the maximum response time for IGMP general queries is 10 seconds.
Related commands: max-response-time, igmp timer other-querier-present, display igmp interface.
# Set the maximum response time for IGMP general queries to 8 seconds on Vlan-interface11.
[Sysname-Vlan-interface11] igmp max-response-time 8
1.1.13  igmp require-router-alert
undo igmp require-router-alert
View
Default Level
2: System level
None
Use the igmp require-router-alert command to configure the interface to discard IGMP messages that do not carry the Router-Alert option.
Use the undo igmp require-router-alert command to restore the default configuration.
By default, the device does not check the Router-Alert option, namely it passes all the IGMP messages it receives to the upper layer protocol for processing.
After you use the igmp require-router-alert command, when the interface receives an IGMP message, the device checks the Router-Alert option carried in the IGMP message. If the device finds that the message does not carry the Router-Alert option, the device discards the IGMP message.
Related commands: require-router-alert, igmp send-router-alert.
# Configure Vlan-interface11 to discard IGMP messages that do not carry the Router-Alert option.
[Sysname-Vlan-interface11] igmp require-router-alert
1.1.14  igmp robust-count
igmp robust-count robust-value
undo igmp robust-count
View
Default Level
2: System level
robust-value: IGMP querier robustness variable. The IGMP querier robustness variable determines the number of general queries the IGMP querier sends on startup and the number of IGMP group-specific queries the IGMP querier sends upon receiving an IGMP leave message.
Use the igmp robust-count command to configure the IGMP querier robustness variable on the current interface.
Use the undo igmp robust-count command to restore the system default.
By default, the IGMP querier robustness variable is 2.
Related commands: robust-count, igmp timer query, igmp last-member-query-interval, display igmp interface.
# Set the IGMP querier robustness variable to 3 on VLAN-interface 11.
[Sysname-Vlan-interface11] igmp robust-count 3
1.1.15  igmp send-router-alert
undo igmp send-router-alert
View
Default Level
2: System level
None
Use the igmp send-router-alert command on the current interface to enable insertion of the Router-Alert option in IGMP messages to be sent.
Use the undo igmp send-router-alert command on the current interface to disable insertion of the Router-Alert option in IGMP messages to be sent.
By default, IGMP messages are sent with the Router-Alert option.
Related commands: igmp require-router-alert, igmp require-router-alert.
# Disable insertion of the Router-Alert option into IGMP messages that leave Vlan-interface11.
[Sysname-Vlan-interface11] undo igmp send-router-alert
1.1.16  igmp static-group
igmp static-group group-address [ source source-address ]
undo igmp static-group { all | group-address [ source source-address ] }
View
POS interface view
Default Level
2: System level
all: Specifies to remove all static multicast groups that the current interface has joined.
Use the igmp static-group command to configure the current interface to be a statically connected member for the specified multicast group or source-group.
Use the undo igmp static-group command to restore the default.
By default, an interface is not a static member for any multicast group or source-group.
If the specified multicast address is in the SSM multicast address range, you must specify a multicast source address at the same time; otherwise IGMP routing table entries cannot be established. There is no such a restriction if the specified multicast group address is not in the SSM multicast address range.
&  Note:
To configure an Ethernet port to be a static member of a multicast group, you can use the igmp-snooping static-group command. For more information, refer to IGMP Snooping Commands in the IP Multicast Volume.
# Configure POS 4/1/1 as a statically connected member for multicast group 224.1.1.1.
[Sysname] interface pos4/1/1
[Sysname-Pos4/1/1] igmp static-group 224.1.1.1
# Configure POS 4/1/1 as a statically connected member for multicast source and group (192.168.1.1, 232.1.1.1).
[Sysname-Pos4/1/1] igmp static-group 232.1.1.1 source 192.168.1.1
1.1.17  igmp timer other-querier-present
igmp timer other-querier-present interval
undo igmp timer other-querier-present
View
Default Level
2: System level
interval: Other querier present interval in seconds.
Use the igmp timer other-querier-present command to configure the other querier present interval on the current interface.
Use the undo igmp timer other-querier-present command to restore the default configuration.
By default, the other querier present interval is 125 seconds.
Related commands: timer other-querier-present, igmp timer query, igmp robust-count, igmp max-response-time, display igmp interface.
# Set the other querier present interval to 200 seconds on VLAN-interface 11.
[Sysname-Vlan-interface11] igmp timer other-querier-present 200
1.1.18  igmp timer query
igmp timer query interval
undo igmp timer query
View
Default Level
2: System level
interval: IGMP query interval in seconds, namely the interval between IGMP general queries sent by the querier.
Use the igmp timer query command to configure the IGMP query interval on the current interface.
Use the undo igmp timer query command to restore the system default.
By default, the IGMP query interval is 60 seconds.
The IGMP querier periodically sends IGMP general queries to decide whether any multicast group member exists on the local subnet. You can modify this interval as required.
Related commands: timer query, igmp timer other-querier-present, display igmp interface.
# Set the IGMP general query interval to 125 seconds on Vlan-interface11.
[Sysname-Vlan-interface11] igmp timer query 125
1.1.19  igmp version
igmp version version-number
undo igmp version
View
Default Level
2: System level
Use the igmp version command to configure the IGMP version on the current interface.
Use the undo igmp version command to restore the IGMP version to the system default.
The default IGMP version is version 2.
All systems (including hosts and routers) on the same subnet must run the same version of IGMP, and cannot automatically switch between different IGMP versions.
Related commands: version.
# Set the IGMP version to IGMPv1 on Vlan-interface11.
[Sysname-Vlan-interface11] igmp version 1
1.1.20  last-member-query-interval
undo last-member-query-interval
View
IGMP view
Default Level
2: System level
interval: Last-member query interval in seconds.
Use the last-member-query-interval command to configure the global IGMP last-member query interval.
Use the undo last-member-query-interval command to restore the global IGMP last member query interval to the system default.
By default, the IGMP last-member query interval is 1 second.
This command is the same as the igmp last-member-query-interval command for interface view, but the value configured by the igmp last-member-query-interval command has a higher priority, that is, the system gives priority to configurations made in interface view.
Related commands: igmp last-member-query-interval, robust-count, display igmp interface.
# Set the global IGMP last-member interval to 3 seconds.
[Sysname] igmp
[Sysname-igmp] lastmember-queryinterval 3
1.1.21  max-response-time
View
IGMP view
Default Level
2: System level
interval: Maximum response time for IGMP general queries in seconds.
Use the max-response-time command to configure the maximum response time for IGMP general queries.
Use the undo max-response-time command to restore globally the maximum response time for IGMP general queries to the system default.
This command is the same as the igmp max-response-time command for interface view, but the value configured by the igmp max-response-time command has a higher priority, that is, the system gives priority to configurations made in interface view.
Related commands: igmp max-response-time, timer other-querier-present, display igmp interface.
# Set the maximum response time for IGMP general queries to 8 seconds globally.
[Sysname] igmp
[Sysname-igmp] max-response-time 8
1.1.22  require-router-alert
undo require-router-alert
View
IGMP view
Default Level
2: System level
None
Use the require-router-alert command to configure the router to discard IGMP messages that do not carry the Router-Alert option.
Use the undo require-router-alert command to restore the default configuration.
By default, the device does not check the Router-Alert option, namely it handles all the IGMP messages it received to the upper layer protocol for processing.
After you use the require-router-alert command, when an IGMP message arrives, the device checks the Router-Alert option carried in the IGMP message. If the device finds that the message does not carry the Router-Alert option, the device discards the IGMP message.
This command is the same as the igmp require-router-alert command for interface view, but the value configured by the igmp require-router-alert command has a higher priority, that is, the system gives priority to configurations made in interface view.
Related commands: igmp require-router-alert.
# Configure the router to discard IGMP messages that do not carry the Router-Alert option.
[Sysname] igmp
[Sysname-igmp] require-router-alert
1.1.23  reset igmp group
reset igmp group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
View
Default Level
2: System level
all: The first all specifies to clear IGMP multicast group information on all interfaces, while the second all specifies to clear the information of all IGMP multicast groups.
interface interface-type interface-number: Clears the IGMP group information on the specified interface.
mask-length: Subnet mask length of the multicast group/source address. For a multicast group address, this argument has an effective value range of 4 to 32; for a multicast source address, this argument has an effective value range of 0 to 32. The system default is 32 in both cases.
Use the reset igmp group command to clear IGMP multicast group information.
Note that:
l           When clearing the IGMP multicast group information of a VLAN interface, this command also clears the IGMP Snooping multicast group information for that VLAN.
l           This command cannot clear IGMP multicast group information of static joins.
# Clear all the IGMP multicast group information on all interfaces.
<Sysname> reset igmp group all
# Clear all IGMP multicast group information on VLAN-interface 100.
<Sysname> reset igmp group interface vlan-interface 100 all
# Clear the information of multicast group 225.0.0.1 on VLAN-interface 100.
<Sysname> reset igmp group interface vlan-interface 100 225.0.0.1
1.1.24  robust-count
undo robust-count
View
IGMP view
Default Level
2: System level
robust-value: IGMP querier robustness variable. The IGMP querier robustness variable determines the default number of general queries the IGMP querier sends on startup and the number of IGMP group-specific queries the IGMP querier sends upon receiving an IGMP leave message.
Use the robust-count command to configure the IGMP querier robustness variable globally.
Use the undo robust-count command to restore the default setting.
This command is the same as the igmp robust-count command for interface view, but the value configured by the igmp robust-count command has a higher priority, that is, the system gives priority to configurations made in interface view.
Related commands: igmp robust-count, last-member-query-interval, timer query, timer other-querier-present, display igmp interface.
# Set the IGMP querier robustness variable to 3 globally.
[Sysname] igmp
[Sysname-igmp] robust-count 3
1.1.25  send-router-alert
send-router-alert
undo send-router-alert
View
IGMP view
Default Level
2: System level
None
Use the send-router-alert command to enable globally the insertion of the Router-Alert option into IGMP messages to be sent.
Use the undo send-router-alert command to disable globally the insertion of the Router-Alert option into IGMP messages to be sent.
By default, an IGMP message carries the Router-Alert option.
This command is the same as the igmp send-router-alert command for interface view, but the value configured by the igmp send-router-alert command has a higher priority, that is, the system gives priority to configurations made in interface view.
Related commands: igmp send-router-alert, require-router-alert.
# Globally disable the insertion of the Router-Alert option in IGMP messages to be sent.
[Sysname] igmp
[Sysname-igmp] send-router-alert
1.1.26  timer other-querier-present
undo timer other-querier-present
View
IGMP view
Default Level
2: System level
interval: Other querier present interval.
Use the timer other-querier-present command to configure the global other querier present interval.
Use the undo timer other-querier-present command to restore the default.
This command is the same as the igmp timer other-querier-present command for interface view, but the value configured by the igmp timer other-querier-present command has a higher priority, that is, the system gives priority to configurations made in interface view.
Related commands: igmp timer other-querier-present, timer query, robust-count, max-response-time, display igmp interface.
# Set the global value of the other querier present interval to 200 seconds.
[Sysname] igmp
[Sysname-igmp] timer other-querier-present 200
1.1.27  timer query
undo timer query
View
IGMP view
Default Level
2: System level
interval: IGMP query interval in seconds, namely interval between IGMP general queries sent by the querier.
Use the timer query command to configure the IGMP query interval globally.
Use the undo timer query command to restore the default setting.
By default, IGMP query interval is 60 seconds.
This command is the same as the igmp timer query command for interface view, but the value configured by the igmp timer query command has a higher priority, that is, the system gives priority to configurations made in interface view.
Related commands: igmp timer query, timer other-querier-present, display igmp interface.
# Set the global value of the IGMP query interval to 125 seconds.
[Sysname] igmp
[Sysname-igmp] timer query 125
1.1.28  version
undo version
View
IGMP view
Default Level
2: System level
Use the version command to configure the global IGMP version.
Use the undo version command to restore the global IGMP version to the system default.
This command is the same as the igmp version command for interface view, but the value configured by the igmp version command has a higher priority, that is, the system gives priority to configurations made in interface view.
Related commands: igmp version.
# Set the global IGMP version to IGMPv1.
[Sysname] igmp
[Sysname-igmp] version 1
