H3C EPON |
OLT Operation Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-081646-20070415-C-1.02 Product Version: Release 5200 Series |
Copyright 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
service@h3c.com
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C EPON OLT documentation set includes the following:
Manual |
H3C EPON OLT Command Manual |
It provides the commands for EPON system configuration, OLT configuration, ONU configuration, ONU UNI configuration, and alarm configuration. |
H3C EPON OLT Installation Manual |
It introduces the switching engine, service board, installation, booting, configuration and maintenance of the EPON OLT devices (the S7500 series Ethernet switches applying EPON feature). |
Organization
H3C EPON OLT Operation Manual is organized as follows:
Chapter |
Contents |
1 EPON System Configuration |
Introduces the basic concept of the EPON technology, its operation mode and the configurations of the entire system. |
2 OLT Configuration |
Elaborates the configurations about the OLT devices. |
3 ONU Configuration |
Elaborates the configurations about the ONU. |
4 ONU UNI Configuration |
Elaborates the configurations about the ONU UNI. |
5 Alarm Configuration |
Presents the configurations about the alarm types supports by the EPON system. |
6 Switch Features Supported by EPON |
Lists Switch Features Supported by EPON and Description of configuration precautions. |
Conventions
The manual uses the following conventions:
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Convention |
Caution |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
