安装CAStools
CAStools工具与操作系统的兼容性,请参见《H3C UIS服务器虚拟化产品软硬件兼容性列表》。
WindowsLinux系统安装CAStools工具
  1. UIS超融合管理平台,选中待安装CAStools工具的虚拟机,单击<修改>按钮,弹出修改虚拟机对话框。
  1. 选中光驱菜单项,单击<连接>按钮,弹出选择光驱对话框。
  1. 选择类型为“安装CAStools”,单击<确定>按钮。
图-1 挂载CAStools
  1. 根据操作系统类型,完成CAStools工具的安装。安装完成后,请重启虚拟机。
图-2 安装CAStools
[root@localhost~]# mount /dev/cdrom /media
mount: /dev/sr0 is write-protected, mounting read-only
[root@localhost~]# cd /media
[root@localhost media]# ls
CAS_tools_setup.exe CAS_tools_upgrade,js linux query.bat readme.txt
[root@localhost media]# cd linux
[root@localhost linux]# sh ./CAS_tools_install.sh
Preparing               ###########################[100%]
Updating / installing
   1:qemu-ga-6.0.2.0-1   ###########################[100%]
Non-SUSE
Created symlink from /etc/systemd/system/multi-user.target.wants/qemu-ga.service to /usr/lib/systemd/system/qemu-ga.service.
FreeBSD系统安装CAStools工具
  1. 使用root账户登录系统。其中,root账户对应密码为安装操作系统过程中所设置的密码。
  1. 使用FreeBSD ISO镜像文件,通过如下命令安装pkgpython
root@:~ # mkdir /dist
root@:~ # mount –t cd9660 /dev/cd0/dist
root@:~ # setenv REPOS_DIR /dist/packages/repos
root@:~ # pkg bootstrap
The package management tool is not yet installed on your system.
Do you want to fetch and install it now? [y/n]:y
Bootstrapping pkg from file:///dist/packages/FreeBSD:11:amd64, please wait
Installing pkg-1.8.7_1
Extracting pkg-1.8.7_1:100%
root@:~ # pkg install python
Updating FreeBSD_install_cdrom repository catalogue
Fetching meta.tzx:100%   260 B  0.3KB/s  00:01
Fetching packagesite.txz:100%  244 KiB 249.9Kb/s  00:01
Processing entries:100%
FreeBSD_install_cdrom repository update completed.1075 packages processed.
Updating database digests format:100%
Checking intergritydone(0 conflicting)
The following 7 package(s) will be affected (of 0 checked):
New packages to be INSTALLED:
        python:2.7_2,2
        python27:2.7.12
        libffi:3.2.1
        indexinfo:0.2.4
        readline:6.3.8
        gettext-runtime:0.19.8.1
        python2:2_3
Number of packages to be installed:7
The process will require 69 MiB more space.
Proceed with this action?[y/n]:y
  1. UIS超融合管理平台,选中待安装CAStools工具的虚拟机。修改虚拟机,为其挂载CAStools工具软件。
图-3 挂载CAStools
  1. 进入虚拟机控制台,执行以下命令,完成CAStools工具的安装。
root@:~ # mount -t cd9660 /dev/cd0 /media/
root@:~ # cd /media/linux/
root@:~ # ./CAS_tools_install.sh
Installing qemu-ga-6.0.2.0-amd64...
Extracting qemu-ga-6.0.2.0-amd64: 100%
Message from qemu-ga-6.0.2.0-amd64:
Qemu-ga has been installed successfully, Use 'service qemu-ga start' to start!
验证安装结果
UIS超融合管理平台,进入虚拟机概要信息界面,查看安装结果。CAStools状态为“运行”时说明安装成功。
