01-WLAN特性与硬件适配关系(AC)
本章节下载: 01-WLAN特性与硬件适配关系(AC) (151.08 KB)
H3C MSR产品支持无线控制器功能。在使用H3C MSR支持无线控制产品前请先阅读本章内容,支持无线控制器功能的款型及相应适配的AP款型如下。
表1-1 适配Wi-Fi4&Wi-Fi5 AP款型支持情况
支持无线控制器功能的款型 |
适配的AP款型 |
MSR810 MSR810-W MSR810-W-DB MSR810-LM MSR810-LM-HK MSR810-LM-CNDE-SJK MSR810-W-LM MSR810-W-LM-HK MSR810-LME MSR2600-6-X1 MSR2600-10-X1 MSR26-30 MSR3600-28 MSR3600-28-X1 MSR3600-28-X1-DP MSR3600-51 MSR3600-51-X1 MSR3600-51-X1-DP MSR36-10 MSR3610-X1-DP MSR3610-X1-DC MSR3610-X1-DP-DC MSR36-20 MSR36-40 MSR36-60 MSR3620-X1 MSR3620-X1-WiNet MSR3640-X1 MSR3640-X1-HI |
WA4320i-ACN WA4320H-ACN WA4320-ACN WA4320X WA4330-ACN WA4320-ACN-B WA4320H-ACN-HI WA4320-ACN-SI WA4320H WA4320H-EI WA5320 WA5320H WA5320E WA5320i WA5320-SI WA5530 WA5530-SI WA5620 WA5620i-CAN SIC-AP320(仅MSR2600-6-X1、MSR3610-X1-DP、MSR3610-X1-DC、MSR3610-X1-DP-DC、MSR3620-X1、MSR3640-X1支持) WA4320-H20 WA4320H-SI |
MSR3610-I-DP MSR3610-I-DP+DDR4-16GB MSR3610-I-DP+DDR4-32GB MSR3610-IE-DP MSR3610-IE-DP+DDR4-8GB MSR3610-IE-DP+DDR4-32GB MSR3610-IE-EAD MSR-EAD-AK770 MSR-iMC |
WA4320i-ACN WA4320H-ACN WA4320-ACN WA4320X WA4330-ACN WA4320-ACN-B WA4320H-ACN-HI WA4320-ACN-SI WA4320H WA4320H-EI WA5320 WA5320H WA5320E WA5320i WA5320-SI WA5530 WA5530-SI WA5620 WA5620i-ACN SIC-AP220 SIC-AP320 WA4320-H20 WA4320H-SI |
MSR1004S-5G-CN MSR1104S-5G-CN |
WA5320 WA5320H WA5320E WA5320i WA5320-SI WA5530 WA5530-SI WA5620 WA5620i-CAN WA4320-H20 WA4320H-ACN WA4320H-SI |
MSR810 MSR810-10-PoE MSR3610-X1 MSR3620-DP |
WA4320i-ACN WA4320H-ACN WA4320-ACN WA4320X WA4330-ACN WA4320-ACN-B WA4320H-ACN-HI WA4320-ACN-SI WA4320H WA4320H-EI WA5320 WA5320H WA5320E WA5320i WA5320-SI WA5530 WA5530-SI WA5620 WA5620i-ACN WA510H-WW WA530-WW WA530X-WW WA536-WW WA538-WW WA560-WW SIC-AP320(仅MSR3610-X1支持) WA4320-H20 WA4320H-SI |
MSR3610-I-DP+DDR4-8GB MSR3610-IE-DP+DDR4-16GB |
WA4320i-ACN WA4320H-ACN WA4320-ACN WA4320X WA4330-ACN WA4320-ACN-B WA4320H-ACN-HI WA4320-ACN-SI WA4320H WA4320H-EI WA5320 WA5320H WA5320E WA5320i WA5320-SI WA5530 WA5530-SI WA5620 WA5620i-ACN WA510H-WW WA530-WW WA530X-WW WA536-WW WA538-WW WA560-WW SIC-AP220 SIC-AP320 WA4320-H20 WA4320H-SI |
MSR1004S-5G MSR1004S-5G-GL MSR2600-15-X1 |
WA5320 WA5320H WA5320E WA5320i WA5320-SI WA5530 WA5530-SI WA5620 WA5620i-CAN WA5620i-CAN WA4320-H20 WA4320H-ACN WA4320H-SI |
MSR810-LM-GL MSR810-W-LM-GL MSR830-6EI-GL MSR830-10EI-GL MSR830-6HI-GL MSR830-10HI-GL MSR2600-6-X1-GL |
WA510H-WW WA530-WW WA530X-WW WA536-WW WA538-WW WA560-WW |
MSR2630-XS MSR3600-28-XS MSR3610-XS MSR3610-I-XS MSR3610-IE-XS MSR3620-XS MSR860-6EI-XS MSR860-6HI-XS MSR3620-X1-XS MSR3640-XS MSR3660-XS |
WA2610H WA2610H-LI WA4320H-SI WA4320-ACN-E WA4320-ACN-D WA4320-ACN-C WA4320i-X WA4320H WA5320H-LI WA5320-D WA5320-C WA5320-C-IOT WA5320 WA5320i-LI WA5320H WA5320-C-EI WA5320X-E WA5320X-SI WA5320X WA5320X-LI WA5530S WA5530-LI WA5530 SIC-AP320(仅MSR2630-XS、MSR3610-XS、MSR3610-I-XS、MSR3610-IE-XS、MSR3620-X1-XS、MSR3640-XS支持) |
MSR810-W-WiNet MSR810-LM-WiNet MSR830-4LM-WiNet MSR830-6EI-WiNet MSR830-5BEI-WiNet MSR830-10BEI-WiNet MSR830-6BHI-WiNet MSR830-10BHI-WiNet MSR2600-6-WiNet MSR2600-10-WiNet |
EWP-WAP712C-HI-FIT EWP-WAP712C-LI EWP-WAP712C-LI-G-FIT EWP-WAP712C-LI-S-FIT EWP-WAP712E-FIT EWP-WAP722E-W2-FIT EWP-WAP722S-W2 EWP-WAP722S-W2-FIT EWP-WAP722S-W2-IOT-FIT EWP-WAP922 EWP-WAP922E-FIT WAP722S-HI EWP-WAP723-W2-FIT EWP-WAP923-FIT EWP-WAP711H EWP-WAP711H-FIT-G EWP-WAP711H-FIT-W EWP-WAP712H-FIT EWP-WAP712H-G EWP-WAP722H-FIT EWP-WAP922H EWP-WAP712X-FIT EWP-WAP722XS-W2-FIT EWP-WAP722X-W2 EWP-WAP722X-W2-FIT EWP-WAP922X EWP-WA2620E-WiNet-FIT EWP-WA2620-WiNet-FIT EWP-WA5320E-WiNet-FIT EWP-WA5320H-WiNet-FIT EWP-WA5320-WiNet-FIT |
MSR610 |
EWP-WA530-WW |
表1-2 适配Wi-Fi6AP款型支持情况
支持无线控制器功能的款型 |
适配的AP款型 |
MSR810 MSR810-EI MSR810-W MSR810-W-DB MSR810-LM MSR810-LM-HK MSR810-LM-CNDE-SJK MSR810-W-LM MSR810-W-LM-HK MSR810-LME MSR810-LM-EI MSR2600-6-X1 MSR2600-10-X1 MSR3600-28-X1 MSR3600-28-X1-DP MSR3600-51-X1 MSR3600-51-X1-DP MSR3610-X1 MSR3610-X1-DP MSR3610-X1-DC MSR3610-X1-DP-DC MSR3610-I-DP MSR3610-IE-DP MSR3620-DP MSR3620-X1 MSR3640-X1 MSR3640-X1-HI |
WA6320-FIT WA6320H-FIT WA6322-FIT WA6322H-FIT WA6330-FIT WA6338-FIT WA6528-FIT WA6620-FIT WA6620X-FIT WA6622-FIT WA6628-FIT WA6638-FIT WA6636 WA6320-SI WA6520 WA6520-HI WA6320-HI WA6522 WA6522H-HI WA6530 WA6338-HI WA6320-SI-H20 WA6638i |
WA6320-FIT WA6320H-FIT WA6322-FIT WA6322H-FIT WA6330-FIT WA6338-FIT WA6528-FIT WA6620-FIT WA6622-FIT WA6628-FIT WA6638-FIT WA6620X-FIT WA6630X-FIT WA6636 WA6320-SI WA6322H WA6520 WA6520-HI WA6320-HI WA6522 WA6522H-HI WA6530 WA6338-HI WA6320-SI-H20 WA6638i |
MSR810 MSR810-EI MSR3610-X1 MSR3620-DP MSR3610-I-DP+DDR4-8GB MSR3610-IE-DP+DDR4-16GB RT-MSR1004S-5G RT-MSR1004S-5G-GL RT-MSR2600-15-X1 |
MSR810-10-PoE |
WA6320H-FIT WA6322-FIT WA6322H-FIT WA6330-FIT WA6338-FIT WA6528-FIT WA6620-FIT WA6622-FIT WA6628-FIT WA6638-FIT WA6620X-FIT WA6630X-FIT WA6636 WA6320-SI WA6322H WA6520 WA6520-HI WA6320-HI WA6522 WA6522H-HI WA6530 WA6338-HI WA6320-SI-H20 WA6638i WA6530i WA6620X |
WA6320-FIT WA6320H-FIT WA6330-FIT WA6622-FIT WA6628-FIT WA6638-FIT WA6620X-FIT WA6630X-FIT |
MSR2630-XS MSR3600-28-XS MSR3610-XS MSR3620-XS MSR3610-I-XS MSR3610-IE-XS MSR3640-XS MSR3660-XS MSR2660-XS MSR2680-XS |
WA6320-C-FIT WA6320-D-FIT WA6330-LI-FIT WA6320H-LI-FIT WA6520S-C WA6520S-E WA6522H-LI |
MSR610 |
EWP-WA6126 EWP-WA6120X EWP-WA6120 EWP-WA6120H |
MSR810-10-PoE MSR830-10HI-GL MSR3610-X1 |
WA6526E |
MSR3620-DP MSR3620-X1 |
WA6530i WA6620X |
