10-ACL和QoS命令参考
02-QoS命令
本章节下载 02-QoS命令  (610.42 KB)
02-QoS命令
  录
1 QoS策略
1.1 定义类的命令
1.1.1 description
1.1.2 display traffic classifier
1.1.3 if-match
1.1.4 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 nest top-most
1.2.6 redirect
1.2.7 remark customer-vlan-id
1.2.8 remark dot1p
1.2.9 remark drop-precedence
1.2.10 remark dscp
1.2.11 remark ip-precedence
1.2.12 remark local-precedence
1.2.13 remark qos-local-id
1.2.14 remark service-vlan-id
1.2.15 remark source-mac
1.2.16 traffic behavior
1.3 定义和应用QoS策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 control-plane management
1.3.4 display qos policy
1.3.5 display qos policy control-plane
1.3.6 display qos policy control-plane management pre-defined
1.3.7 display qos policy control-plane pre-defined
1.3.8 display qos policy global
1.3.9 display qos policy interface
1.3.10 display qos policy l2vpn-ac
1.3.11 display qos policy user-profile
1.3.12 display qos policy vsi
1.3.13 display qos vlan-policy
1.3.14 qos apply policy (Ethernet service instance view, interface view, control plane view, control-plane management view, VSI view)
1.3.15 qos apply policy (user profile view)
1.3.16 qos apply policy global
1.3.17 qos policy
1.3.18 qos vlan-policy
1.3.19 reset qos policy control-plane
1.3.20 reset qos policy global
1.3.21 reset qos policy l2vpn-ac
1.3.22 reset qos vlan-policy
2 优先级映射
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 import
2.1.3 map export
2.1.4 qos map-table
2.2 端口优先级信任模式配置命令
2.2.1 display qos trust interface
2.2.2 qos trust
2.2.3 qos trust tunnel-dscp
2.3 端口优先级配置命令
2.3.1 qos priority
3 流量整形和限速
3.1 流量整形配置命令
3.1.1 display qos gts interface
3.1.2 qos gts
3.2 限速配置命令
3.2.1 display qos lr interface
3.2.2 qos lr
4 拥塞管理
4.1 拥塞管理公共配置命令
4.1.1 display qos queue interface
4.2 严格优先级队列配置命令
4.2.1 display qos queue sp interface
4.2.2 qos sp
4.3 加权轮询队列配置命令
4.3.1 display qos queue wrr interface
4.3.2 qos wrr
4.3.3 qos wrr { byte-count | weight }
4.3.4 qos wrr group sp
4.4 加权公平队列配置命令
4.4.1 display qos queue wfq interface
4.4.2 qos bandwidth queue
4.4.3 qos wfq
4.4.4 qos wfq { byte-count | weight }
4.4.5 qos wfq group sp
4.5 队列调度策略配置命令
4.5.1 bandwidth queue
4.5.2 display qos qmprofile configuration
4.5.3 display qos qmprofile interface
4.5.4 qos apply qmprofile
4.5.5 qos qmprofile
4.5.6 queue (queue scheduling profile view)
5 拥塞避免
5.1 WRED配置命令
5.1.1 display qos wred interface
5.1.2 display qos wred table
5.1.3 qos wred apply
5.1.4 qos wred queue
5.1.5 qos wred queue ecn
5.1.6 qos wred queue table
5.1.7 qos wred queue weighting-constant
5.1.8 queue (Wred table view)
5.1.9 queue ecn
5.1.10 queue weighting-constant
6 全局CAR
6.1 全局CAR配置命令
6.1.1 car name
6.1.2 display qos car name
6.1.3 qos car (system view)
6.1.4 reset qos car name
7 端口队列统计
7.1 端口队列统计配置命令
7.1.1 display qos queue-statistics interface outbound
1 QoS策略
1.1  定义类的命令
1.1.1  description
description命令用来配置类的描述信息。
undo description命令用来恢复缺省情况。
未配置类的描述信息。
类视图
text:表示类的描述信息,为1~127个字符的字符串,区分大小写。
多次执行本命令,最后一次执行的命令生效。
# 为类class1配置描述信息。
[Sysname-classifier-class1] description classifier
display traffic classifier命令用来显示类的配置信息。
(独立运行模式)
display traffic classifier user-defined [ classifier-name ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定单板的流分类的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主用主控板的类的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的流分类的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示全局主用主控板的类的配置信息。(IRF模式)
# 显示用户定义类的配置信息。
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
表1-1 display traffic classifier命令显示信息描述表
用户自定义类的信息
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
1.1.3  if-match
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match match-criteria
undo if-match match-criteria
未定义匹配数据包的规则。
类视图
表1-2 类的匹配规则取值
取值
acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } [ inner ]
定义匹配ACL的规则
·     acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999,用户自定义ACL序号的取值范围是5000~5999
·     acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
·     inner表示if-match命令引用的ACL是用于匹配VXLAN报文的内层头内容,不配置inner则表示if-match命令引用的ACL是用于匹配未经封装报文的报文头内容或封装后的VXLAN报文的外层头内容。需要注意的是,上述引用的ACL中的规则不能配置为rule [ rule-id ] { deny | permit } vxlan。如果引用的ACL中配置的规则是rule [ rule-id ] { deny | permit } vxlan,则if-match acl命令不需要携带inner也能匹配封装后的VXLAN报文的内层头内容。
ACL规则中未指定VPN实例时,表示该规则对非VPN报文和VPN报文均有效。出方向上不支持匹配VPN实例
any
定义匹配所有数据包的规则
control-plane protocol protocol-name&<1-8>
定义匹配控制平面协议的规则,protocol-name&<1-8>为系统预定义匹配协议报文类型名称的列表,具体如表1-3所示,&<1-8>表示前面的参数最多可以输入8次
control-plane protocol-group protocol-group-name
定义匹配控制平面协议组的规则,protocol-group-name取值为critical、important、management、monitor、normal、redirect
customer-dot1p dot1p-value
定义匹配内层VLAN Tag 802.1p优先级的规则,dot1p-value为802.1p优先级值的列表,802.1p优先级的取值范围为0~7
customer-vlan-id vlan-id-list
定义匹配内层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
destination-mac mac-address
定义匹配目的MAC地址的规则,仅对以太网接口生效
dscp dscp-value
定义匹配DSCP的规则,dscp-value为DSCP取值的列表,DSCP的取值范围为0~63;也可以输入关键字,具体如表1-5所示
forwarding-layer route
定义匹配三层转发的报文
inbound-interface interface-type interface-number
定义匹配入接口的规则,interface-type interface-number为接口类型和接口编号
在“and”模式的流分类中如果配置了本规则,然后将入接口所在单板或子卡拔出,会导致流分类失效,此时如果将单板或子卡恢复,则流分类会重新生效。但如果不恢复单板或子卡,请删除该流分类并按需重新配置。否则,即使再向该流分类中新增其他匹配规则,该流分类也不会生效
ip-precedence ip-precedence-value
定义匹配IP优先级的规则,ip-precedence-value为IP优先级的列表,IP优先级的取值范围为0~7
定义匹配协议的规则,protocol-name取值为ip、ipv6
qos-local-id local-id-value
定义匹配QoS本地ID值的规则,local-id-value为QoS本地ID,取值范围为1~4095,目前仅支持取值为1~3999
仅支持在入方向上匹配QoS本地ID值
qos-local-id egress-active local-id-value
定义匹配报文出方向QoS本地ID值的规则:
·     如果在入方向上应用了remark qos-local-id egress-activelocal-id-value命令对报文的QoS本地ID值进行标记且该标记仅在出方向生效,则在出方向上只能使用if-match egress-active qos-local-id local-id-value命令来匹配报文的QoS本地ID值
·     如果应用了remark qos-local-id local-id-value命令且未指定egress-active参数对报文的QoS本地ID值进行标记,重标记报文的QoS本地ID值在任意方向都生效,则只能使用if-match qos-local-id local-id-value来匹配报文的QoS本地ID值
local-id-value为QoS本地ID,取值范围为1~128
service-dot1p dot1p-value
定义匹配外层VLAN Tag 802.1p优先级的规则,dot1p-value为802.1p优先级值的列表,802.1p优先级的取值范围为0~7
service-vlan-id vlan-id-list
定义匹配外层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID规则来匹配
source-mac mac-address
定义匹配源MAC地址的规则,仅对以太网接口生效
tunnel-id tunnel-id
定义匹配指定隧道内的所有VXLAN报文,指定的隧道必须是VXLAN隧道,如果是其它隧道协议的隧道,则该流分类不生效
vxlan { any | vxlan-id }
定义匹配VXLAN编号的规则
当核心设备/VTEP设备接收到的VXLAN报文的VXLAN ID为当前设备已创建的VXLAN,且该报文为过路报文(报文的目的地址不是当前设备的IP地址)时,设备不支持使用本参数匹配该过路报文。
表1-3 系统预定义匹配协议报文类型名称的列表
报文类型
arp
ARP协议
arp-snooping
ARP Snooping协议
bfd
BFD协议
bgp
BGP协议
bgp4+
IPv6 BGP
dhcp
DHCP协议
dhcp-snooping
DHCP Snooping协议
dhcp6
IPv6 DHCP协议
dldp
DLDP协议
dot1x
802.1p 协议
icmp
ICMP协议
icmp6
IPv6 ICMP协议
igmp
IGMP协议
ip-option
带选项字段的IPv4报文
ipv6-option
带选项字段的IPv6报文
isis
IS-IS协议
lacp
LACP协议
lldp
LLDP协议
mvrp
MVRP协议(包含GVRP协议)
ospf-multicast
OSPF组播
ospf-unicast
OSPF单播
ospf3-multicast
OSPFv3组播
ospf3-unicast
OSPFv3单播
pvst
PVST协议
snmp
SNMP协议
ssh
SSH协议
stp
STP协议
telnet
TELNET协议
vrrp
VRRP协议
vrrp6
IPv6 VRRP协议
一个类下可配置多条匹配命令,各个配置之间互相不覆盖。
在定义匹配规则(控制平面和VLAN ID)时,请注意:
·     一条命令可以配置多个规则,如果指定了多个相同的规则,系统默认为一个;一条命令中多个不同的规则是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配的规则时,必须与该规则中定义的完全相同才会删除,顺序可以不同。
在定义匹配ACL的规则时,类中引用的ACL必须已经存在。
在定义匹配VXLAN隧道报文内层内容的规则时,ACL中只能包含匹配报文源IP地址、目的IP地址、源端口号,目的端口号以及传输层协议类型的规则,不能包含匹配其它字段的规则。
在定义匹配VXLAN隧道报文内层内容的规则之前,当前流分类中必须已经存在定义匹配报文VXLAN编号的规则。
当一个流分类中同时存在使用ACL匹配VXLAN隧道报文的内层内容和外层内容的两条规则时,所匹配的ACL中只能存在一条规则,且匹配报文外层内容的ACL中只能包含匹配源IP地址的规则。
if-match中引用的ACL规则的动作为deny时,则忽略ACL规则的动作,以流行为中定义的动作为准,报文匹配只使用ACL中的分类域。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的802.1p优先级为3。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1的报文。
[Sysname-classifier-class1] if-match dscp 1
# 定义类class1的匹配规则为:匹配IP优先级值为1的报文。
[Sysname-classifier-class1] if-match ip-precedence 1
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的VLAN ID值为1或6或9的报文。
[Sysname] traffic classifier class1 operator or
# 定义类class1的匹配规则为:匹配外层VLAN Tag的VLAN ID值为2或7或10的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# 定义类class1匹配QoS本地ID值为3的报文。
[Sysname-classifier-class1] if-match qos-local-id 3
# 在流分类class1中配置匹配上送控制平面的ARP协议报文。
[Sysname-classifier-class1] if-match control-plane protocol arp
# 在流分类class1中配置匹配上送控制平面的normal协议组报文。
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# 在流分类class1中定义匹配隧道编号为2的VXLAN隧道中的所有VXLAN报文。
[Sysname-classifier-class1] if-match tunnel-id 2
# 定义类class1的匹配规则为:匹配VXLAN编号为10的报文。
[Sysname-classifier-class1] if-match vxlan 10
traffic classifier命令用来创建一个类,并进入类视图。如果指定的类已经存在,则直接进入类视图。
undo traffic classifier命令用来删除一个类。
未配置类。
operator:指定各规则之间的逻辑运算符。缺省情况为and
# 定义一个名为class1的类。
·     display traffic classifier
1.2  定义流行为的命令
1.2.1  accounting
accounting命令用来配置流量统计动作。
undo accounting命令用来恢复缺省情况。
accounting [ byte | packet ]
undo accounting
未配置流量统计动作。
流行为视图
byte:表示报文基于字节进行统计。
packet:表示报文基于包进行统计。
若配置流量统计动作但不指定bytepacket参数,则设备会基于包进行流量统计。
# 为流行为配置流量统计动作,基于字节进行统计。
[Sysname-behavior-database] accounting byte
1.2.2  car
car命令用来配置流量监管动作。
undo car命令用来恢复缺省情况。
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] * [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] * [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
未配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。流量的平均速率,单位为kbps,取值范围为8~160000000且必须为8的整数倍。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
·     如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过256000000。
·     如果指定cbs参数,取值范围512~256000000且必须为512的整数倍。
ebs excess-burst-size:超出突发尺寸,单位为byte。取值范围为0~256000000且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps,取值范围为8~160000000且必须为8的整数倍。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass
action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dot1p-pass new-cos:设置新的802.1P报文的优先级值,并允许数据包通过,取值范围为0~7。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63。
·     remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
hierarchy-car-name:分层CAR的名称。
mode:分层CAR和CAR动作的合作模式。有andor两种模式,默认为and模式。
·     and:在该模式下,对于多条数据流应用同一个分层CAR,必须每条流满足各自的CAR配置,同时各流量之和又满足分层CAR的配置,流量才能正常通过。
·     or:在该模式下,对于多条数据流应用同一个分层CAR,只要每条流满足各自的CAR配置或者各流量之和满足分层CAR配置,流量即可正常通过。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
如果未配置峰值速率,则表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 为流行为配置流量监管。报文正常流速为256kbps,承诺突发尺寸为51200bytes,速率大于256kbps时,报文DSCP值改为0并发送。
[Sysname-behavior-database] car cir 256 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior命令用来显示流行为的配置信息。
(独立运行模式)
display traffic behavior user-defined [ behavior-name ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定单板的流行为的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的流行为的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的流行为的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的流行为的配置信息。(IRF模式)
# 显示用户定义行为的配置信息。
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 200 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      Accounting enable:
      Filter enable: Permit
      Marking:
        Remark dot1p 1
    Behavior: 3 (ID 102)
      -none-
表1-4 display traffic behavior命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名称及其内容,内容可以有多种类型
Marking
标记相关信息
Remark dscp
重新标记报文的DSCP优先级值
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
EBS
超出突发尺寸,单位为byte
Green action
对绿色报文的动作
Red action
对红色报文的动作
Yellow action
对黄色报文的动作
Filter enable
流量过滤动作
none
表示未配置其他流行为
1.2.4  filter
filter命令用来配置流量过滤动作。
undo filter命令用来恢复缺省情况。
filter { deny | permit }
undo filter
未配置流量过滤动作。
流行为视图
deny:丢弃命中规则的数据包。
permit:允许命中规则的数据包通过,如果本QoS策略中还有其他流分类,则这类数据包可以被继续处理。
# 为流行为database配置丢弃数据包的过滤动作。
1.2.5  nest top-most
nest top-most命令用来配置添加报文的外层VLAN Tag动作。
undo nest top-most命令用来恢复缺省情况。
nest top-most vlan vlan-id
undo nest top-most
未配置添加报文外层VLAN Tag动作。
流行为视图
vlan vlan-id:添加的VLAN ID,取值范围为1~4094。
引用了添加VLAN Tag动作的QoS策略只能应用到接口的入方向上。
# 在流行为b1上配置如下动作:添加VLAN ID为123的外层VLAN Tag。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
1.2.6  redirect
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来恢复缺省情况。
redirect { cpu | interface interface-type interface-number [ track-oap ] | next-hop { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] } [ fail-action { discard | forward } ] }
undo redirect { cpu | interface interface-type interface-number | next-hop }
未配置流量重定向动作。
流行为视图
cpu:重定向到CPU。
interface:重定向到指定的接口。
interface-type interface-number:指定接口类型和接口编号。在IRF环境中,当IRF成员设备之间通过多个IRF物理端口互联时,不支持跨成员设备配置重定向到接口。即流量的入接口和重定向接口需要是同一成员设备上的接口。有关IRF的相关介绍请参见“虚拟化技术配置指导”中的“IRF”。
track-oap:重定向到内部业务接口或连接独立业务部件的接口,配置track-oap后,只有存在OAP Client且指定接口为内部业务接口或连接独立业务部件接口,才会执行重定向动作,否则,设备不执行该重定向动作。有关内部业务接口和连接独立业务部件接口的详细介绍,请参见“OAA配置指导”中的“OAP单板配置”或“OAP配置”。
next-hop:重定向到指定的下一跳。在配置重定向到下一跳的动作时,指定的下一跳地址必须路由可达,如果同时配置了优选和备选地址,则至少需要有一个地址路由可达,否则将导致重定向失败。在配置生效后,重定向功能会定期查询路由表,检查下一跳地址是否有效;如果配置了Track项,则通过Track检测结果来判断下一跳地址是否有效。如果检测到优选和备选地址均失效,则重定向到下一跳的动作将不再生效。
ipv4-add1:优选的下一跳IPv4地址。如果重定向到优选的IPv4地址失败,则会重定向到备选IPv4地址。
ipv4-add2:备选的下一跳IPv4地址。
ipv6-add1:优选的下一跳IPv6地址。如果重定向到优选的IPv6地址失败,则会重定向到备选IPv6地址。
ipv6-add2:备选的下一跳IPv6地址。
track track-entry-number:指定下一跳关联的Track项,优选和备选的地址可以分别指定不同的Track项。track-entry-number取值范围为1~1024。通过指定Track项,可实现与监测特性(如NQA、BFD)的联动,详情请参见“可靠性配置指导”中的“Track”。
fail-action:当下一跳的地址不存在时,对报文采取的处理动作。
discard:表示丢弃此报文。
forward:表示转发此报文。
基于接口应用QoS策略时,本系列设备只支持在二层以太网接口下配置流量重定向动作。
同一个流行为中,不能同时配置重定向到指定的下一跳和重新标记报文的QoS本地ID值,否则该流行为下的动作都不会生效。
# 为流行为配置流量重定向动作,重定向到接口Ten-GigabitEthernet1/0/1。
[Sysname-behavior-database] redirect interface ten-gigabitethernet 1/0/1
·     classifier behavior
·     monitoring-group(网络管理和监控命令参考/镜像)
·     qos policy
·     traffic behavior
remark customer-vlan-id命令用来重新标记报文的CVLAN。
undo remark customer-vlan-id命令用来恢复缺省情况。
未配置重新标记报文CVLAN的动作。
流行为视图
vlan-id:表示重新标记报文内层VLAN(CVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重新标记报文的CVLAN为VLAN 111。
[Sysname-behavior-b1] remark customer-vlan-id 111
1.2.8  remark dot1p
remark dot1p命令用来配置重新标记报文的802.1p优先级或内外层标签802.1p优先级复制动作。
undo remark dot1p命令用来恢复缺省情况。
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
未配置重新标记报文802.1p优先级以及内外层标签802.1p优先级复制动作。
流行为视图
green:对绿色报文进行重新标记。
red:对红色报文进行重新标记。
yellow:对黄色报文进行重新标记。
dot1p-value:802.1p优先级,取值范围为0~7。
customer-dot1p-trust:将内层VLAN tag的802.1p优先级复制为外层VLAN tag的802.1p优先级。
命令remark dot1p dot1p-valueremark dot1p customer-dot1p-trust是覆盖关系。
对于只携带一层VLAN tag的报文,配置的remark dot1p customer-dot1p-trust不会生效。
在同一个流行为中,如果多次对同一种颜色的报文重新标记802.1p优先级,则最后一次执行的命令生效。
不指定greenredyellow时,表示重标记所有颜色报文的802.1p优先级。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
# 配置内外层标签优先级复制功能。
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark drop-precedence命令用来重新标记报文的丢弃优先级。
undo remark drop-precedence命令用来恢复缺省情况。
remark drop-precedence drop-precedence-value
未配置重新标记报文丢弃优先级的动作。
流行为视图
drop-precedence-value:丢弃优先级,取值范围为0~2。
仅QoS策略应用在入方向时,重新标记报文的丢弃优先级的动作才会生效。
# 重新标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.10  remark dscp
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来恢复缺省情况。
undo remark [ green | red | yellow ] dscp
未配置重新标记报文DSCP值的动作。
流行为视图
green:对绿色报文进行重新标记。
red:对红色报文进行重新标记。
yellow:对黄色报文进行重新标记。
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
表1-5 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
# 重新标记报文的DSCP值为6。
remark ip-precedence命令用来重新标记报文的IP优先级。
undo remark ip-precedence命令用来恢复缺省情况。
remark ip-precedence ip-precedence-value
未配置重新标记报文IP优先级的动作。
流行为视图
ip-precedence-value:IP优先级,取值范围为0~7。
# 重新标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来恢复缺省情况。
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
未配置重新标记报文本地优先级的动作。
流行为视图
green:对绿色报文进行重新标记。
red:对红色报文进行重新标记。
yellow:对黄色报文进行重新标记。
local-precedence-value:本地优先级,取值范围为0~7。
设备仅支持在入方向应用QoS策略配置重新标记报文的本地优先级。
# 重新标记报文的本地优先级值为2。
remark qos-local-id命令用来重新标记报文的QoS本地ID值。
undo remark qos-local-id命令用来恢复缺省情况。
remark qos-local-id [ egress-active ] local-id-value
未配置重新标记报文的QoS本地ID值的动作。
流行为视图
egress-active:QoS本地ID值仅在出方向生效。如果未指定本参数,则QoS本地ID值仅在入方向生效。
local-id-value:QoS本地ID值,取值范围为1~4095,目前仅支持取值为1~3999。当配置了VLAN映射和IP Source Guard功能之后,仅支持取值为1~2999。如果指定egress-active参数,则取值范围为1~128。
在入方向应用QoS策略对报文的QoS本地ID值进行标记,此QoS本地ID值仅在入方向生效,如果希望其仅在出方向生效,则在标记时必须指定egress-active关键字。
配置本命令egress-active参数与MOD、iNQA实例(1~114)互斥,关于MOD的详细介绍请参见“Telemetry配置指导”中的“MOD”。关于iNQA实例的详细介绍请参见“网络管理与监控配置指导”中的“iNQA”。
# 重新标记报文的QoS本地ID值为2。
[Sysname-behavior-database] remark qos-local-id 2
remark service-vlan-id命令用来重新标记报文的SVLAN。
undo remark service-vlan-id命令用来恢复缺省情况。
未配置重新标记报文的SVLAN的动作。
流行为视图
vlan-id:表示重新标记报文外层VLAN(SVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重新标记报文的SVLAN为VLAN 222。
[Sysname-behavior-b1] remark service-vlan-id 222
remark source-mac命令用来配置重新标记报文的源MAC地址。
undo remark source-mac命令用来恢复缺省情况。
remark source-mac mac-address
未配置重新标记报文的源MAC地址。
流行为视图
mac-address:源MAC地址,形式为H-H-H。
# 在流行为behavior1中配置重新标记报文的源MAC地址为600b-038a-a395。
[Sysname-behavior-behavior1] remark source-mac 600b-038a-a395
·     traffic behavior
traffic behavior命令用来创建一个流行为,并进入流行为视图。如果指定的流行为已经存在,则直接进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
不存在流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
# 定义一个名为behavior1的流行为。
·     display traffic behavior
1.3  定义和应用QoS策略的命令
classifier behavior命令用来为类指定流行为。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [ mode { dcbx | loose } | insert-before before-classifier-name ] *
没有为类指定流行为。
QoS策略视图
mode dcbx:表示该流分类与流行为的关联模式为DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议)模式。有关DCBX的介绍,请参见“二层技术-以太网交换配置指导”中的“LLDP”。
mode loose:表示该流分类与流行为的关联模式为宽松模式。仅基于控制平面应用QoS策略时,本模式才会生效。
insert-before before-classifier-name:表示将配置的类插入到QoS策略中已存在的指定类之前。before-classifier-name表示QoS策略中已存在的类名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示新配置的类与流行为配对将添加到QoS策略最后。
QoS策略下每个类只能与一个流行为关联。
如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
使用宽松模式(mode loose)可以对特定接口进入并上送控制平面的特定协议报文进行限速,具体配置方法为:
(1)     创建ACL,并定义匹配特定协议报文的rule规则。
(2)     创建and模式的流分类,配置if-match aclif-match inbound-interface
(3)     创建流行为并配置动作。
(4)     创建QoS策略,并在为类关联流行为时指定mode loose
(5)     将QoS策略应用在控制平面上。
其他接口进入的该类型协议报文,上送控制平面时依然受到原有控制平面协议报文限速功能的限制。
# 在QoS策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
# 在QoS策略user1中为类database指定流行为test,并将该类插入到策略中已存在的类class-a前。
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
·     qos policy
1.3.2  control-plane
control-plane命令用来进入控制平面视图。
(独立运行模式)
control-plane chassis chassis-number slot slot-number
slot slot-number:指定单板。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 进入指定slot上的控制平面视图。(独立运行模式)
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
control-plane management命令用来进入管理口控制平面视图。
# 进入管理口控制平面视图。
[Sysname] control-plane management
[Sysname-cp-management]
display qos policy命令用来显示QoS策略的配置信息。
(独立运行模式)
display qos policy user-defined [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
display qos policy user-defined [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义QoS策略。
ipv6-matching:显示IPv6 Matching类型的QoS策略。
accounting:显示统计类型的QoS策略。
mirroring:显示镜像类型的QoS策略。
remarking:显示重标记类型的QoS策略。
tcp-erspan:显示TCP ERSPAN类型的QoS策略。
policy-name:QoS策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:QoS策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定单板的QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的QoS策略的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的QoS策略的配置信息。(IRF模式)
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则显示用户定义的通用类型QoS策略的配置信息。
# 显示用户定义的通用类型QoS策略的配置信息。
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
   Classifier: 2 (ID 101)
     Behavior: 2
      Accounting enable:
        184057187 (Packets)
        844575 (pps)
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
# 显示用户定义的统计类型QoS策略的配置信息。
<Sysname> display qos policy user-defined accounting
  Accounting policy: 1 (ID 100)
     Behavior: 1
      Accounting enable:
        184057187 (Packets)
        844575 (pps)
# 显示用户定义的镜像类型QoS策略的配置信息。
<Sysname> display qos policy user-defined mirroring
  Mirroring policy: 1 (ID 100)
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# 显示用户定义的重标记类型QoS策略的配置信息。
<Sysname> display qos policy user-defined remarking
  Marking policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
# 显示用户定义的TCP ERSPAN类型QoS策略的配置信息。
<Sysname> display qos policy user-defined tcp-erspan
  TCP ERSPAN policy: 1 (ID 100)
     Behavior: 1
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/1
表1-6 display qos policy命令显示信息描述表
用户自定义QoS策略的信息
Policy
用户定义的通用类型的QoS策略名
IPv6 Matching policy
用户定义的IPv6类型的QoS策略名
Accounting policy
用户定义的统计类型的QoS策略名
Mirroring policy
用户定义的镜像类型的QoS策略名
Marking policy
用户定义的重标记类型的QoS策略名
TCP ERSPAN policy
用户定义的TCP ERSPAN类型的QoS策略名
其它显示信息解释请参见表1-1表1-4
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
(独立运行模式)
display qos policy control-plane chassis chassis-number slot slot-number
slot slot-number:显示指定单板的控制平面应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的控制平面应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 显示应用到slot 1控制平面的QoS策略信息。(独立运行模式)
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
     Behavior: 2
      Accounting enable:
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-7 display qos policy control-plane命令显示信息描述表
Direction
QoS策略应用的方向
其它显示信息解释请参见表1-1表1-4
display qos policy control-plane management pre-defined命令用来显示系统预定义的管理口控制平面应用QoS策略的信息。
# 显示系统预定义的管理口控制平面应用QoS策略的信息。
<Sysname> display qos policy control-plane management pre-defined
Pre-defined policy information
  Protocol          Priority   Bandwidth                 Group
  Default           N/A        100000 (kbps)             N/A
  ARP               N/A        128 (kbps)                normal
  BGP               N/A        256 (kbps)                critical
  BGPv6             N/A        256 (kbps)                critical
  HTTP              N/A        512 (kbps)                management
  HTTPS             N/A        512 (kbps)                management
  ICMP              N/A        128 (kbps)                monitor
  ICMPv6            N/A        128 (kbps)                monitor
  OSPF Multicast    N/A        256 (kbps)                critical
  OSPF Unicast      N/A        256 (kbps)                critical
  OSPFv3 Multicast  N/A        256 (kbps)                critical
  OSFPv3 Unicast    N/A        256 (kbps)                critical
  RIP               N/A        1024 (kbps)               critical
  RIPng             N/A        256 (kbps)                critical
  SNMP              N/A        512 (kbps)                management
  SSH               N/A        512 (kbps)                management
  TELNET            N/A        512 (kbps)                management
  FTP               N/A        512 (kbps)                management
  TFTP              N/A        512 (kbps)                management
表1-8 display qos policy control-plane management pre-defined命令显示信息描述表
预定义管理口控制平面策略内容
Protocol
系统预定义协议报文类型
Priority
优先级
Bandwidth
带宽
Group
协议组
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
(独立运行模式)
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
任意视图‌
slot slot-number:显示指定单板的系统预定义的控制平面策略信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有在位单板的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的系统预定义的控制平面策略信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有成员设备上在位单板的系统预定义的控制平面应用QoS策略的信息。(IRF模式)
# 显示指定slot上的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
  IS-IS             29         512 (kbps)         critical
  VRRP              36         512 (kbps)         important
  OSPF Multicast    30         1024 (kbps)        critical
  OSPF Unicast      30         1024 (kbps)        critical
  PIM Multicast     24         128 (kbps)         critical
  PIM Unicast       24         128 (kbps)         critical
  IGMP              18         512 (kbps)         important
  PIMv6 Multicast   24         64 (kbps)          critical
  PIMv6 Unicast     24         64 (kbps)          critical
  OSPFv3 Unicast    30         1024 (kbps)        critical
  OSPFv3 Multicast  30         1024 (kbps)        critical
  VRRPv6            36         512 (kbps)         important
  ARP               12         768 (kbps)         normal
  DHCP Snooping     18         256 (kbps)         redirect
  DHCP              18         768 (kbps)         normal
  802.1x            12         128 (kbps)         important
  STP               36         256 (kbps)         critical
  LACP              36         64 (kbps)          critical
  MVRP              18         256 (kbps)         critical
  BGP               24         256 (kbps)         critical
  ICMP              9          512 (kbps)         monitor
  IPOPTION          18         384 (kbps)         normal
  BGPv6             24         256 (kbps)         critical
  IPOPTIONv6        18         64 (kbps)          normal
  LLDP              24         64 (kbps)          important
  DLDP              24         64 (kbps)          critical
  TELNET            8          512 (kbps)         management
  SSH               8          512 (kbps)         management
  HTTP              12         64 (kbps)          management
  HTTPS             12         64 (kbps)          management
  TACACS            12         64 (kbps)          management
  RADIUS            12         64 (kbps)          management
  ARP Snooping      18         256 (kbps)         redirect
  ICMPv6            8          512 (kbps)         monitor
  PVST              35         2560 (kbps)        critical
  DHCPv6            18         256 (kbps)         normal
  BFD               31         12800 (kbps)       critical
表1-9 display qos policy control-plane pre-defined命令显示信息描述表
Pre-defined control plane policy
预定义控制平面策略内容
Protocol
系统预定义协议报文类型
其他协议
Priority
优先级
Bandwidth
带宽
Group
协议所属的协议组
其它显示信息解释请参见表1-3
display qos policy global命令用来显示基于全局应用QoS策略的配置信息和运行情况。
(独立运行模式)
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy global [ slot slot-number ] [ inbound | outbound ]
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
ipv6-matching:显示IPv6 Matching类型QoS策略的配置信息和运行情况。
accounting:显示统计类型QoS策略的配置信息和运行情况。
mirroring:显示镜像类型QoS策略的配置信息和运行情况。
remarking:显示重标记类型QoS策略的配置信息和运行情况。
tcp-erspan:显示TCP ERSPAN类型QoS策略的配置信息和运行情况。
inbound:显示入方向QoS策略的配置信息和运行情况。
outbound:显示出方向QoS策略的配置信息和运行情况。
slot slot-number:显示指定单板的基于全局应用QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于全局应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于全局应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于全局应用QoS策略的信息。(IRF模式)
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则显示通用类型QoS策略的配置信息和运行情况。
如果未指定显示方向,则同时显示出入两个方向QoS策略的配置信息和运行情况。
# 显示基于全局应用通用类型QoS策略的信息。
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        184057187 (Packets)
        844575 (pps)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# 显示基于全局应用统计类型QoS策略的信息。
<Sysname> display qos accounting policy global
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Accounting enable:
        184057187 (Packets)
        844575 (pps)
# 显示基于全局应用镜像类型QoS策略的信息。
<Sysname> display qos mirroring policy global
  Direction: Inbound
  Mirroring policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# 显示基于全局应用重标记类型QoS策略的信息。
<Sysname> display qos remarking policy global
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# 显示基于全局应用IPv6 Matching类型QoS策略的信息。
<Sysname> display qos ipv6-matching policy global
  Direction: Inbound
  IPv6 Matching policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl ipv6 3000
     Behavior: 1
      Marking:
        Remark dscp 3
# 显示基于全局应用TCP ERSPAN类型QoS策略的信息。
<Sysname> display qos tcp-erspan policy global
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: 1
      Mirroring:
表1-10 display qos policy global命令显示信息描述表
Direction
QoS策略应用的方向
Policy
用户定义的通用类型的QoS策略名
用户定义的IPv6类型的QoS策略名
Accounting policy
用户定义的统计类型的QoS策略名
Mirroring policy
用户定义的镜像类型的QoS策略名
Marking policy
用户定义的重标记类型的QoS策略名
TCP ERSPAN policy
Green packets
绿色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
(独立运行模式)
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的配置信息和运行情况。
slot slot-number:显示指定单板上指定逻辑接口的QoS策略的配置信息和运行情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板逻辑接口的QoS策略的配置信息和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定逻辑接口的QoS策略的配置信息和运行情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板逻辑接口QoS策略的配置信息和运行情况。(IRF模式)
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则显示通用类型QoS策略的配置信息。
# 显示对接口Ten-GigabitEthernet1/0/1接收到的报文应用通用类型QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        184057187 (Packets)
        844575 (pps)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# 显示对接口Ten-GigabitEthernet1/0/1接收到的报文应用统计类型QoS策略的配置信息和运行情况。
<Sysname> display qos accounting policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Accounting Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Accounting enable:
        184057187 (Packets)
        844575 (pps)
# 显示对接口Ten-GigabitEthernet1/0/1接收到的报文应用重标记类型QoS策略的配置信息和运行情况。
<Sysname> display qos remarking policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# 显示对接口Ten-GigabitEthernet1/0/1接收到的报文应用镜像类型QoS策略的配置信息和运行情况。
<Sysname> display qos mirroring policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Mirroring policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# 显示对接口Ten-GigabitEthernet1/0/1接收到的报文应用TCP ERSPAN类型QoS策略的配置信息和运行情况。
<Sysname> display qos tcp-erspan policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/2
# 显示所有接口上通用类型QoS策略的配置信息和运行情况。
  Direction: Inbound
  Mode     : Share
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Interface: Ten-GigabitEthernet1/0/3
  Direction: Inbound
  Policy: b
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        Green action  : pass
Interface: Ten-GigabitEthernet1/0/4
  Direction: Inbound
  Mode     : Share
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/5
        Green action  : pass
表1-11 display qos policy interface命令显示信息描述表
Direction
QoS策略应用的方向
Policy
用户定义的通用类型的QoS策略名
IPv6类型的QoS策略名
Accounting policy
统计类型的QoS策略名
Mirorring policy
镜像类型的QoS策略名
Marking policy
重标记类型的QoS策略名
TCP ERSPAN policy
Mode
QoS和ACL资源的共享模式,当应用QoS策略时携带了share-mode关键字,显示信息中才会出现该字段
Green packets
绿色报文的流量统计
Red packets
红色报文的流量统计
fail-action
当下一跳的地址不存在时,对报文采取的处理动作:
·     discard:表示丢弃此报文
·     forward:表示转发此报文
其它显示信息解释请参见表1-1表1-4
display qos policy l2vpn-ac命令用来显示L2VPN AC承载的以太网服务实例上QoS策略的配置信息和运行情况。
(独立运行模式)
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound | outbound ]
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ chassis chassis-number slot slot-number ] ] [ inbound | outbound ]
ipv6-matching:指定IPv6 Matching类型的QoS策略。
accounting:指定统计类型的QoS策略。
mirroring:指定镜像类型的QoS策略。
remarking:指定重标记类型的QoS策略。
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口下以太网服务实例上QoS策略的配置信息和运行情况。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将显示接口下所有以太网服务实例上QoS策略的配置信息和运行情况。
slot slot-number:显示指定单板上指定二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。(IRF模式)
# 显示对接口Ten-GigabitEthernet1/0/1下以太网服务实例1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy l2vpn-ac interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
Interface: Ten-GigabitEthernet1/0/1    Service instance ID: 1
  Direction: Inbound
  Policy: p
   Classifier: c
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        CIR 88 (kbps), CBS 5632 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 0 (Packets)
        Red packets   : 0 (Packets)
表1-12 display qos policy l2vpn-ac命令显示信息描述表
Service instance ID
以太网服务实例ID
Direction
QoS策略应用的方向
Green action
对绿色报文的动作
Yellow action
对黄色报文的动作
Red action
对红色报文的动作
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos policy user-profile命令用来显示用户上线后User Profile下应用的QoS策略的信息和运行情况。
(独立运行模式)
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name profile-name:指定User Profile的名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线,且必须以英文字母开始,区分大小写。User Profile的名称必须全局唯一。如果未指定本参数,将显示所有User Profile下应用的QoS策略的信息和运行情况。
user-id user-id:表示在线用户的ID,为系统所分配,取值范围为十六进制数0~fffffffe。若未指定本参数,则显示所有用户在User Profile下应用的QoS策略的信息和运行情况。
slot slot-number:显示指定单板上指定用户在User Profile下应用的QoS策略的信息和运行情况,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上的在线用户的QoS策略的信息和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上指定用户在User Profile下应用的QoS策略的信息和运行情况,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备所有单板上指定用户在User Profile下应用的QoS策略的信息和运行情况。(IRF模式)
# 显示指定全局用户(从聚合口等全局口上线的用户)在User Profile下应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy user-profile name abc user-id 30000000 inbound
User-Profile: abc
  User ID: 0x30000000(global)
    Direction: Inbound
    Policy: p1
     Classifier: default-class
       Matched : 0 (Packets) 0 (Bytes)
       Operator: AND
       Rule(s) :
        If-match any
       Behavior: be
        -none-
# 显示指定的非全局用户在User Profile下应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy user-profile name abc user-id 30000001 inbound
User-Profile: abc
  slot 2:
    User ID: 0x30000001(local)
      Direction: Inbound
      Policy: p1
         Operator: AND
         Rule(s) :
          If-match any
         Behavior: be
          -none-
表1-13 display qos policy user-profile命令显示信息描述表
User-Profile
User Profile名称
User ID
上线用户的ID
global
该用户从聚合口等全局口上线
local
该用户从物理口上线
镜像到接口
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为byte
EBS
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位为byte
PIR
峰值信息速率
Direction
QoS策略应用的方向
Matched
符合分类规则的数据包数目
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos policy vsi命令用来显示VSI上QoS策略的配置信息和运行情况。
(独立运行模式)
display qos policy vsi [ name vsi-name ] [ inbound ] [ slot slot-number ]
display qos policy vsi [ name vsi-name ] [ inbound ] [ chassis chassis-number slot slot-number ]
name vsi-name:显示指定VSI上QoS策略配置信息和运行情况。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI上QoS策略的配置信息和运行情况。
inbound:显示入方向的QoS策略配置信息和运行情况。因为VSI出方向不支持应用QoS策略,所以指定与未指定本参数,命令执行结果相同。
slot slot-number:显示QoS策略配置信息和指定单板上QoS策略的运行情况,slot-number表示单板所在的槽位号。如果未指定本参数,则显示QoS策略配置信息、VSI关联的所有单板上QoS策略的综合运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示QoS策略配置信息和指定成员设备上指定单板的QoS策略的运行情况,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示QoS策略配置信息、VSI关联的所有单板上QoS策略的综合运行情况。(IRF模式)
如果未指定可选参数,则同时显示所有VSI的QoS策略的配置信息和运行情况。
# 查看所有VSI的QoS策略的配置信息和运行情况。
<Sysname> display qos policy vsi
VSI: vsi1
  Direction: Inbound
  Policy: p
   Classifier: c
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        Green action  : pass
表1-14 display qos policy vsi命令显示信息描述表
VSI
VSI的名称
Direction
QoS策略应用的方向
Policy
QoS策略的名称
Classifier
类的名称
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
行为的名称
Green action
对绿色报文的动作
Yellow action
对黄色报文的动作
Red action
对红色报文的动作
Green packets
绿色报文的个数
Yellow packets
黄色报文的个数
Red packets
红色报文的个数
·     qos apply policy (VSI view)
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的配置信息和运行情况。
(独立运行模式)
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称,为1~31个字符的字符串,区分大小写。
vlan vlan-id:显示指定VLAN上应用QoS策略的信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
slot slot-number:显示指定单板上基于VLAN应用QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于VLAN应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于VLAN应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于VLAN应用QoS策略的信息。(IRF模式)
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        184057187 (Packets)
        844575 (pps)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-15 display qos vlan-policy命令显示信息描述表
Direction
QoS策略应用的方向
Green packets
绿色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
qos apply policy命令用来在控制平面、管理口控制平面、接口、VSI或以太网服务实例上应用QoS策略。
undo qos apply policy命令用来取消控制平面、管理口控制平面、接口、VSI或以太网服务实例上应用的QoS策略。
qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name { inbound | outbound } [ share-mode ]
undo qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name { inbound | outbound }
未应用QoS策略。
控制平面视图/管理口控制平面视图
VSI视图
以太网服务实例视图
ipv6-matching:指定IPv6 Matching类型的QoS策略。仅支持基于接口和以太网服务实例应用IPv6类型的QoS策略。
accounting:指定统计类型的QoS策略。仅支持基于接口和以太网服务实例应用统计类型的QoS策略。
mirroring:指定镜像类型的QoS策略。仅支持基于接口和以太网服务实例应用镜像类型的QoS策略。
remarking:指定重标记类型的QoS策略。仅支持基于接口和以太网服务实例应用重标记类型的QoS策略。
tcp-erspan:指定TCP ERSPAN类型的QoS策略。仅支持基于接口入方向应用TCP ERSPAN类型的QoS策略。
policy-name:策略名,为1~31个字符的字符串,区分大小写。
inbound:入方向应用QoS策略。
outbound:出方向应用QoS策略。设备不支持在控制平面、控制平面管理口、VSI出方向应用QoS策略。
share-mode:对二层以太网接口和三层以太网接口应用共享QoS和ACL资源模式的QoS策略。该模式下,同一单板相同方向应用相同QoS策略的接口共享一份QoS和ACL资源。
重标记类型的QoS策略不支持在出方向应用。
基于接口应用QoS策略时,在相同方向最多可以应用六个不同类型的策略,包括一个通用类型的QoS策略、一个IPv6 Matching类型的QoS策略、一个统计类型的QoS策略、一个镜像类型的QoS策略、一个重标记类型的QoS策略和一个TCP ERSPAN类型的QoS策略。接口同时应用不同类型的QoS策略后,可以对接口收到的同一份流量分别执行不同的流行为动作。
关于以太网服务实例的相关配置命令,请参见“MPLS命令参考”中的“MPLS L2VPN命令、VPLS命令”或“VXLAN命令参考”。
# 将通用类型QoS策略TEST1应用到接口Ten-GigabitEthernet1/0/1的出方向上。
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy TEST1 outbound
# 将统计类型QoS策略TEST2应用到接口Ten-GigabitEthernet1/0/1的入方向上。
[Sysname-Ten-GigabitEthernet1/0/1] qos apply accounting policy TEST2 inbound
# 将镜像类型QoS策略TEST3应用到接口Ten-GigabitEthernet1/0/1的入方向上。
[Sysname-Ten-GigabitEthernet1/0/1] qos apply mirroring policy TEST3 inbound
# 将重标记类型QoS策略TEST4应用到接口Ten-GigabitEthernet1/0/1的入方向上。
[Sysname-Ten-GigabitEthernet1/0/1] qos apply remarking policy TEST4 inbound
# 将TCP ERSPAN类型QoS策略TEST4应用到接口Ten-GigabitEthernet1/0/1的入方向上。
[Sysname-Ten-GigabitEthernet1/0/1] qos apply tcp-erspan policy TEST4 inbound
# 对进入3号槽控制平面的报文应用通用类型QoS策略TEST5。
[Sysname-cp-slot3] qos apply policy TEST5 inbound
# 对进入管理口控制平面的报文应用通用类型QoS策略TEST6。
[Sysname-cp-management] qos apply policy TEST6 inbound
# 对进入以太网服务实例的报文应用通用类型QoS策略TEST9。
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] qos apply policy TEST9 inbound
# 以共享QoS和ACL资源的模式将QoS策略TEST10应用到接口Ten-GigabitEthernet1/0/1的出方向上。
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy TEST10 outbound share-mode
# 在VSI的入方向上应用通用类型QoS策略TEST12。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] qos apply policy TEST12 inbound
# 将IPv6类型QoS策略TEST13应用到接口Ten-GigabitEthernet1/0/1的出方向上。
[Sysname-Ten-GigabitEthernet1/0/1] qos apply ipv6-matching policy TEST13 outbound
·     vsi (MPLS命令参考/VPLS)
qos apply policy命令用来在User Profile下应用策略。
undo qos apply policy命令用来取消User Profile下应用的策略。
undo qos apply policy policy-name { inbound | outbound }
未在User Profile下应用QoS策略。
User Profile视图
inbound:入方向应用QoS策略。
policy-name:策略名,为1~31个字符的字符串。
User Profile被删除将导致其下引用的QoS策略被删除。
User Profile视图下应用的QoS策略不能为空,因为应用空策略的User Profile不能被激活。
# 对设备发送的上线用户user的流量应用策略test(该策略已经建立)。
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
qos apply [ ipv6-matching |  accounting | mirroring | remarking | tcp-erspan ] policy policy-name global { inbound | outbound }
undo qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name global { inbound | outbound }
未在全局应用QoS策略。
tcp-erspan:指定TCP ERSPAN类型的QoS策略。仅支持在入方向应用TCP ERSPAN类型的QoS策略。
inbound:入方向应用QoS策略。
全局应用的QoS策略对全部流量生效。
基于全局应用策略时,在相同方向最多可以应用六个不同类型的策略,包括一个通用类型的QoS策略、一个IPv6 Matching类型的QoS策略、一个统计类型的QoS策略、一个镜像类型的QoS策略、一个重标记类型的QoS策略和一个TCP ERSPAN类型的QoS策略。
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则在全局应用通用类型QoS策略。
# 将通用类型QoS策略user1应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
# 将镜像类型QoS策略user2应用到全局的入方向上。
[Sysname] qos apply mirroring policy user2 global inbound
1.3.17  qos policy
qos policy命令用来创建一个QoS策略,并进入QoS策略视图。如果指定的QoS策略已经存在,则直接进入QoS策略视图。
undo qos policy命令用来删除一个QoS策略。
qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name
undo qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name
不存在QoS策略。
创建QoS策略时:
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则表示通用类型的QoS策略。
·     不同类型的QoS策略不能使用相同的名称。
·     请避免使用“ipv6-matching”、“accounting”、“mirroring”、“remarking”、“tcp-erspan”做策略名称,也不要使用这些词的前几个字母做策略名称,例如“ipv6”、“acc”、“mirror”、“remark”、“tcp”等。如果这样做,会导致执行display qos policy user-defined policy-name命令时无相关信息显示,因为系统会认为输入的策略名是命令行关键字而非policy-name
如下各类型QoS策略的使用方法相同:
·     通用类型的QoS策略可以应用在所有支持的位置,包括接口、VLAN、全局等,能配置所有的流行为动作。
·     IPv6 Matching类型的QoS策略仅支持应用在接口或全局,常用于配置引用IPv6 ACL的流分类。
·     统计类型QoS策略仅支持应用在接口或全局,常用于配置流量统计动作。
·     镜像类型QoS策略仅支持应用在接口或全局,常用于配置镜像动作。
·     重标记类型QoS策略仅支持应用在接口或全局,常用于配置重标记动作。
·     TCP ERSPAN类型QoS策略仅支持应用在接口或全局,常用于配置erspan镜像动作。
TCP ERSPAN类型的QoS策略中流分类用来匹配TCP报文的标识(包括ACK、FIN、PSH、RST、SYN和URG等),QoS策略中的流量转发动作是流镜像ERSPAN,关于流镜像ERSPAN的详细介绍,请参见“网络管理和监控配置指导”中的“镜像”。
如果需要同时对用户业务流进行流镜像分析和流限速,则可以使用通用类型的QoS策略对上线用户进行带宽限速,使用TCP ERSPAN类型的QoS策略将用户业务流进行流镜像分析,两类QoS策略使用的硬件资源互不影响。
IPv6 Matching类型的QoS策略用于配置引用IPv6 ACL的流分类,其他类型的QoS策略并不区分IPv4和IPv6。
在某些场景下,需要将一个用于匹配IPv4报文的QoS策略和一个用于匹配IPv6报文的QoS策略同时应用在相同位置的相同方向,此时可以配置一个通用类型QoS策略和一个IPv6 Matching类型的QoS策略。
如果QoS策略已经被应用,则不允许删除,需要先在应用的位置上取消对QoS策略的应用,然后再使用undo qos policy命令删除。
# 定义一个名为user1的通用类型的QoS策略。
# 定义一个名为user2的统计类型的QoS策略。
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# 定义一个名为user3的重标记类型的QoS策略。
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
# 定义一个名为user4的镜像类型的QoS策略。
[Sysname] qos mirroring policy user4
[Sysname-qospolicy-user4]
# 定义一个名为user6的IPv6 Matching类型的QoS策略。
[Sysname] qos ipv6-matching policy user6
[Sysname-qospolicy-user6]
# 定义一个名为user7的TCP ERSPAN类型的QoS策略。
[Sysname] qos tcp-erspan policy user7
[Sysname-qospolicy-user7]
·     qos apply policy
·     qos apply policy global
·     qos vlan-policy
qos vlan-policy命令用来在VLAN上应用QoS策略。
undo qos vlan-policy命令用来取消VLAN上应用的QoS策略。
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
未在VLAN上应用QoS策略。
policy-name:策略名称,为1~31个字符的字符串,区分大小写。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:入方向应用QoS策略。
# 在VLAN 200、300、400、500的入方向上应用策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
(独立运行模式)
reset qos policy control-plane chassis chassis-number slot slot-number
slot slot-number:清除指定单板的基于控制平面应用QoS策略的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的基于控制平面应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 清除应用到指定slot上的控制平面的QoS策略统计信息。(独立运行模式)
<Sysname> reset qos policy control-plane slot 1
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
reset qos [ ipv6-matching | accounting | mirroring | remarking| tcp-erspan ] policy global [ inbound | outbound ]
inbound:清除入方向QoS策略的统计信息。
outbound:清除出方向QoS策略的统计信息。
如果未指定ipv6-matchingaccountingmirroringremarkingtcp-erspan,则清除通用类型QoS策略的统计信息。
如果未指定清除方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除全局入方向应用的通用类型QoS策略的统计信息。
<Sysname> reset qos policy global inbound
# 清除全局入方向应用的镜像类型QoS策略的统计信息。
<Sysname> reset qos mirroring policy global inbound
reset qos policy l2vpn-ac命令用来清除L2VPN AC承载的以太网服务实例上QoS策略的统计信息。
reset qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ] [ inbound | outbound ]
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将清除所有接口下以太网服务实例上QoS策略的统计信息。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将清除接口下所有以太网服务实例上QoS策略的统计信息。
如果未指定ipv6-matchingaccountingmirroringremarking,则清除通用类型QoS策略的统计信息。
# 清除接口Ten-GigabitEthernet1/0/1下以太网服务实例1入方向QoS策略的统计信息。
<Sysname> reset qos policy l2vpn-ac interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
# 清除接口Ten-GigabitEthernet1/0/1下以太网服务实例1收到的IPv6 Matching类型QoS策略的统计信息。
<Sysname> reset qos ipv6-matching policy l2vpn-ac interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
·     display qos policy l2vpn-ac
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
vlan vlan-id:指定VLAN。vlan-id为指定VLAN的ID号,取值范围为1~4094。
如果未指定方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射
2.1  优先级映射表配置命令
display qos map-table命令用来显示优先级映射表的配置情况。
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p ]
表2-1 优先级映射表
优先级映射
dot1p-dp
802.1p优先级到丢弃优先级映射表
dot1p-exp
802.1p优先级到EXP映射表
dot1p-lp
802.1p优先级到本地优先级映射表
dscp-dot1p
DSCP到802.1p优先级映射表
dscp-dp
DSCP到丢弃优先级映射表
dscp-dscp
DSCP到DSCP映射表
exp-dot1p
EXP到802.1p优先级映射表
exp-dscp
EXP到DSCP映射表
如果未指定表的类型,将显示所有映射表的配置情况。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名称
TYPE
映射表的类型
IMPORT
映射表的输入值
EXPORT
映射表的输出值
2.1.2  import
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 B。
优先级映射表视图
import-value-list:输入值列表。
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
# 配置802.1p优先级到本地优先级映射表的映射关系,与802.1p优先级4、5相对应的本地优先级为1。
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
·     display qos map-table
2.1.3  map export
map export命令用来将映射关系配置到指定MPLS标签的EXP域。
undo map export命令用来恢复缺省情况。
map export mpls-exp
undo map export
如果入方向的报文为不带MPLS标签的私网报文,则映射关系同时被配置到出方向添加得第一层和第二层MPLS标签的EXP域;如果入方向的报文为带两层MPLS标签的公网报文,则映射关系只被配置到出方向第一层MPLS标签的EXP域。
优先级映射表视图
mpls-exp:表示映射关系仅配置到第一层MPLS标签的EXP域。
该命令仅对输出值为EXP的优先级映射表生效。
如果入方向的报文为不带MPLS标签的私网报文,则本命令配置后映射关系只被配置到第一层MPLS标签的EXP域,同时第二层MPLS标签的EXP域会被设置为0;如果入方向的报文为带两层MPLS标签的公网报文,则本命令配置后则映射关系不会被配置到MPLS标签的EXP域。
# 配置802.1p优先级到EXP优先级映射表的映射关系,与802.1p优先级4、5相对应的EXP优先级为1,并且仅将映射关系配置到第一层MPLS标签的EXP域。
[Sysname] qos map-table dot1p-exp
[Sysname-maptbl-dot1p-exp] import 4 5 export 1
[Sysname-maptbl-dot1p-exp] map export mpls-exp
2.1.4  qos map-table
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p }
其它参数请参见表2-1
# 进入802.1p优先级到本地优先级映射表视图。
·     import
2.2  端口优先级信任模式配置命令
display qos trust interface命令用来显示端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示端口优先级信任模式信息。
<Sysname> display qos trust interface ten-gigabitethernet 1/0/1
 Port priority information
  Port priority: 4
  Port priority trust type: dscp
表2-3 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
端口优先级信任信息
Port priority
端口优先级
端口优先级信任类型,取值为:
·     dot1p:802.1p优先级
·     dscp:DSCP优先级
2.2.2  qos trust
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { dot1p | dscp }
undo qos trust
设备信任报文的802.1p优先级。
VXLAN网络的公网侧端口不支持配置优先级信任模式为DSCP。关于VXLAN的配置,请参见“VXLAN配置指导”中的“VXLAN”。
# 在接口Ten-GigabitEthernet1/0/1上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname-Ten-GigabitEthernet1/0/1] qos trust dot1p
·     display qos trust interface
qos trust tunnel-dscp命令用来配置信任VXLAN报文外层IP头的DSCP优先级。
undo qos trust tunnel-dscp命令用来恢复缺省情况。
未配置信任VXLAN报文外层IP头的DSCP优先级。
如果希望VXLAN隧道接口信任VXLAN报文外层IP头的DSCP优先级,除了VXLAN隧道所在的以太网接口下配置qos trust dscp,系统视图下还需要配置qos trust tunnel-dscp
# 配置设备信任VXLAN报文外层IP头的DSCP优先级。
[Sysname] qos trust tunnel-dscp
2.3  端口优先级配置命令
2.3.1  qos priority
qos priority命令用来配置端口的端口优先级。
undo qos priority命令用来恢复端口优先级为缺省值。
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
端口优先级的缺省值为0,未配置修改报文的DSCP优先级的值。
priority-value:端口优先级值。未配置DSCP关键字时,表示配置端口优先级,端口优先级的取值范围为0~7;配置DSCP关键字后,表示修改报文的DSCP优先级,取值范围为0~63。
未配置端口优先级信任模式时,表示设备以端口优先级作为报文的802.1P优先级进行映射,如果携带dscp关键字,同时对于三层报文将改写报文的DSCP优先级。
在端口上配置端口DSCP优先级后,该端口上的dscp-dp优先级映射表将不再生效。
在端口上配置端口优先级信任模式为dscp,同时配置在该端口上配置端口DSCP优先级,则端口DSCP优先级不生效。
在端口上同时配置端口优先级和端口DSCP优先级,则端口优先级不生效。
在同一聚合组中,所有成员端口的端口优先级配置必须相同。
# 配置接口Ten-GigabitEthernet1/0/1的端口优先级为2。
[Sysname-Ten-GigabitEthernet1/0/1] qos priority 2
3 流量整形和限速
3.1  流量整形配置命令
display qos gts interface命令用来显示接口的流量整形配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量整形配置情况。
# 显示所有接口的流量整形配置情况。
 Rule: If-match queue 1
  CIR 1000 (kbps), CBS 62976 (Bytes)
 Rule: If-match queue 4
  CIR 400 (kbps), CBS 25088 (Bytes)
表3-1 display qos gts命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成
Rule
匹配规则
CIR
承诺信息速率,当采用绝对值形式输入时,单位为kbps
CBS
承诺突发尺寸,当采用绝对值形式输入时,单位为byte
3.1.2  qos gts
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
undo qos gts queue queue-id
未配置流量整形。
queue queue-id:对队列上的数据包进行流量整形。queue-id为匹配的队列号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。千兆端口的取值范围为8~1000000,万兆端口的取值范围为8~10000000,40GE端口的取值范围为8~40000000,100GE端口的取值范围为8~100000000。用户配置的数值必须是8的倍数。‌‌
cbs committed-burst-size:承诺突发尺寸,单位为byte。
·     如果不指定cbs参数,committed-burst-size缺省取值为62.5*committed-information-rate,且必须为512的整数倍,如果乘积不是512的整数倍,就取比乘积大的最近的512的整数倍,最大不能超过16000000。
·     如果指定cbs参数,取值范围为512~16000000,committed-burst-size必须为512的整数倍。
# 在接口Ten-GigabitEthernet1/0/1上对队列1中的报文进行流量整形。正常流速为6400kbps,突发流量为51200bytes。
[Sysname-Ten-GigabitEthernet1/0/1] qos gts queue 1 cir 6400 cbs 51200
3.2  限速配置命令
display qos lr interface命令用来显示接口上的限速配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的限速配置情况。
# 显示所有接口的接口限速配置情况。
 Direction: outbound
  CIR 2000 (kbps), CBS 20480 (Bytes)
Interface: Bridge-Aggregation1
 Direction: Outbound
  CIR 64 (kbps), CBS 512 (Bytes)
表3-2 display qos lr命令显示信息描述表
Direction
接口限速应用的方向
CIR
CBS
3.2.2  qos lr
qos lr命令用来配置接口限速。
undo qos lr命令用来取消接口配置的限速。
qos lr  outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
未配置限速。
outbound:出方向限速。
cir committed-information-rate:承诺信息速率,单位为kbps。千兆端口的取值范围为8~1000000,万兆端口的取值范围为8~10000000,40GE端口的取值范围为8~40000000,100GE端口的取值范围为8~100000000。用户配置的数值必须是8的倍数。对于LSUM1CQGS32SF0接口板上的端口,最大取值不能超过1000000。
cbs committed-burst-size:承诺突发尺寸,单位为bytes。
·     如果不指定cbs参数,committed-burst-size缺省取值为62.5ms*committed-information-rate,且必须为512的整数倍,如果乘积不是512的整数倍,就取比乘积大的最近的512的整数倍,最大不能超过128000000。
·     如果指定cbs参数,取值范围为512~128000000,committed-burst-size必须为512的整数倍。
# 对接口Ten-GigabitEthernet1/0/1上出方向的报文进行限速。正常流速为256kbps,突发流量为51200bytes,以后速率小于等于256kbps时正常发送,速率大于256kbps时,将进行限速。
[Sysname-Ten-GigabitEthernet1/0/1] qos lr outbound cir 256 cbs 51200
4 拥塞管理
4.1  拥塞管理公共配置命令
display qos queue interface命令用来显示接口上队列配置情况和统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的接口队列配置情况和运行统计信息。
# 显示所有接口下的队列信息。
<Sysname> display qos queue interface
 Output queue: Weighted Round Robin queuing
 Queue ID     Queue name     Group     Byte count
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         5
 5            ef             1         9
 6            cs6            1         13
 7            cs7            1         15
Interface: Ten-GigabitEthernet1/0/2
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         5
 5            ef             1         9
 6            cs6            1         13
 7            cs7            1         15
.....(省略部分显示信息)
表4-1 display qos queue interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列的相关信息
Queue ID
队列号
Queue name
队列名称
Group
分组号,说明队列属于哪一个分组
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算,N/A表示该队列采用SP调度算法
Byte count
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算
4.2  严格优先级队列配置命令
display qos queue sp interface命令用来显示接口的SP(Strict Priority,严格优先级)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的SP队列配置情况。
# 显示Ten-GigabitEthernet1/0/1的严格优先级队列配置情况。
<Sysname> display qos queue sp interface ten-gigabitethernet 1/0/1
 Output queue: Strict Priority queuing
表4-2 display qos queue sp interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
4.2.2  qos sp
qos sp命令用来在接口上配置严格优先队列。
undo qos sp命令用来恢复缺省情况。
qos sp
undo qos sp
端口采用SP调度算法。
# 在接口Ten-GigabitEthernet1/0/1上应用SP模式的队列调度。
[Sysname-Ten-GigabitEthernet1/0/1] qos sp
·     display qos queue sp interface
4.3  加权轮询队列配置命令
display qos queue wrr interface命令用来显示接口的WRR(Weighted Round Robin,加权轮询)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WRR队列配置情况。
# 显示接口Ten-GigabitEthernet1/0/1的WRR队列配置情况。
<Sysname> display qos queue wrr interface ten-gigabitethernet 1/0/1
 Queue ID        Queue    name      Group           Weight
 0               be              1               1
 1               af1             1               1
 2               af2             1               1
 3               af3             1               1
 4               af4             1               1
 5               ef              1               1
 6               cs6             1               1
 7               cs7             sp              N/A
表4-3 display qos queue wrr interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
Queue ID
队列号
Queue name
队列名称
Group
分组号,说明队列属于哪一个分组
Weight
Byte count
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算,N/A表示该队列采用SP调度算法
4.3.2  qos wrr
qos wrr命令用来在接口上开启WRR队列。
undo qos wrr命令用来恢复缺省情况。
qos wrr { byte-count | weight }
undo qos wrr { byte-count | weight }
接口使用SP队列调度算法。
byte-count:表示按照每次轮询可发送的字节数进行计算。
weight:表示按照每次轮询可发送的报文个数进行计算。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行WRR配置。
# 在接口Ten-GigabitEthernet1/0/1上开启WRR队列,并按照每次轮询可发送的报文个数进行计算。
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr weight
# 在接口Ten-GigabitEthernet1/0/1上开启WRR队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr byte-count
·     display qos queue wrr interface
4.3.3  qos wrr { byte-count | weight }
qos wrr { byte-count | weight }命令用来配置WRR队列或修改WRR队列的参数。
undo qos wrr命令用来恢复指定队列的缺省情况。
qos wrr queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wrr queue-id
在使用WRR队列时,所有队列都处于WRR调度组1中,调度权重从队列0到7分别为1、2、3、4、5、6、7、8。
queue-id:队列序号。取值范围为0~7或表4-4中的关键字。
表4-4 queue-id数字和关键字对应表
queue-id数字
queue-id关键字
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
group { 1 | 2 }:表示该队列属于哪个WRR优先组,缺省为group 1。其中group 1表示该队列属于WRR优先组1,group 2表示该队列属于WRR优先组2。各组之间执行优先级调度,由组1至组2优先级依次降低。当前暂不支持配置WRR调度组2。
schedule-value:配置队列的调度权重,取值范围为1~127。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行本配置。
# 在接口Ten-GigabitEthernet1/0/1上应用WRR队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
·     qos wrr
4.3.4  qos wrr group sp
qos wrr group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wrr group sp命令用来取消将队列加入SP组。
qos wrr queue-id group sp
当使用WRR队列时,所有队列都处于WRR调度组1中。
queue-id:队列序号。取值范围为0~7。
本命令需要在端口队列为WRR调度模式下使用。
SP组与普通WRR优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WRR优先组。
# 在接口Ten-GigabitEthernet1/0/1上应用WRR队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group sp
·     qos wrr
4.4  加权公平队列配置命令
4.4.1  display qos queue wfq interface
display qos queue wfq interface命令用来显示接口的WFQ配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WFQ配置情况。
# 显示接口Ten-GigabitEthernet1/0/1的加权公平队列配置情况。
<Sysname> display qos queue wfq interface ten-gigabitethernet 1/0/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Queue name      Group           Byte count      Min Bandwidth
 0               be              1               1               64
 1               af1             1               1               64
 2               af2             1               1               64
 3               af3             1               1               64
 4               af4             1               1               64
 5               ef              1               1               64
 6               cs6             1               1               64
 7               cs7             1               1               64
表4-5 display qos queue wfq interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
Queue ID
队列号
Queue name
队列名称
Group
分组号,说明队列属于哪一个分组
Byte-count
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算, N/A表示该队列采用SP调度算法
Min-Bandwidth
队列的最小保证带宽值
4.4.2  qos bandwidth queue
qos bandwidth queue命令用来配置端口队列的最小带宽保证。
undo qos bandwidth queue命令用来恢复缺省情况。
undo qos bandwidth queue queue-id
在使用WFQ队列时,没有配置队列的最小带宽保证。
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。千兆端口的取值范围为8~1000000,万兆端口的取值范围为8~10000000,40GE端口的取值范围为8~40000000,100GE端口的取值范围为8~100000000,单位为kbps。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行本配置。
# 在接口Ten-GigabitEthernet1/0/1上配置队列0的最小保证带宽值为100kbps。
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq weight
[Sysname-Ten-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
·     qos wfq
4.4.3  qos wfq
qos wfq命令用来在接口上开启WFQ队列。
undo qos wfq命令用来恢复缺省情况。
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
接口使用SP队列调度算法。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行WFQ配置。
# 在接口Ten-GigabitEthernet1/0/1上开启WFQ队列,并按照每次轮询可发送的报文个数进行计算。
# 在接口Ten-GigabitEthernet1/0/1上开启WFQ队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq byte-count
·     display qos queue wfq interface
4.4.4  qos wfq { byte-count | weight }
qos wfq { byte-count | weight }命令用来配置WFQ队列或修改WFQ队列的参数。
undo qos wfq命令用来恢复指定队列的缺省情况。
qos wfq queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wfq queue-id
在使用WFQ队列时,所有队列都处于WFQ调度组1中,各队列的调度权重均为1。
group { 1 | 2 }:表示该队列属于哪个WFQ优先组,缺省为group 1。其中group 1表示该队列属于WFQ优先组1,group 2表示该队列属于WFQ优先组2。各组之间执行优先级调度,由组1至组2优先级依次降低。当前暂不支持配置WFQ优先组2。
# 在接口Ten-GigabitEthernet1/0/1上应用WFQ队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
·     qos bandwidth queue
·     qos wfq
4.4.5  qos wfq group sp
qos wfq group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wfq group sp命令用来取消将队列加入SP组。
qos wfq queue-id group sp
所有队列均处于WFQ调度组1中。
本命令需要在端口队列为WFQ调度模式下使用。
SP组与普通WFQ优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WFQ优先组。
# 在接口Ten-GigabitEthernet1/0/1上应用WFQ队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group sp
·     qos wfq
4.5  队列调度策略配置命令
4.5.1  bandwidth queue
bandwidth queue命令用来配置队列调度策略下队列的最小带宽保证。
undo bandwidth queue命令用来恢复缺省情况。
undo bandwidth queue queue-id
在队列调度策略中配置某个队列为WFQ队列后,没有配置队列的最小带宽。
队列调度策略视图
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。取值范围为8~100000000。
必须先在队列调度策略中将某个队列配置为WFQ队列,才能为该队列配置最小带宽保证。
# 在队列调度策略myprofile中,配置队列0使用WFQ队列算法,使用报文个数作为调度权重,权重值为1,分组为1,并为该队列配置最小保证带宽值为100kbps。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
4.5.2  display qos qmprofile configuration
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
(独立运行模式)
display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number ]
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有队列调度策略的配置情况。
slot slot-number:显示指定单板的队列调度策略的配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的队列调度策略的配置情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的队列调度策略的配置情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的队列调度策略的配置情况。(IRF模式)
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
 Queue ID  Type  Group   Schedule   Schedule  Min         Max
                         unit       value     bandwidth   bandwidth
 be        SP    N/A     N/A        N/A       0           N/A
 af1       WFQ   1       weight     1         200         N/A
 af2       WFQ   1       weight     1         0           N/A
 af3       WFQ   1       weight     2         0           N/A
 af4       WFQ   1       weight     2         0           N/A
 ef        WFQ   1       weight     3         0           N/A
 cs6       WFQ   1       weight     4         0           N/A
 cs7       WFQ   1       weight     3         0           N/A
表4-6 display qos qmprofile configuration命令显示信息描述表
队列调度策略名称
Queue ID
队列号
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)、WFQ(加权公平队列)
Group
优先组,N/A表示无效
Schedule unit
队列调度单位,包括weight和byte-count,N/A表示无效
Schedule vlaue
·     队列调度单位为weight时,表示报文个数
·     队列调度单位为byte-count时,表示字节个数
·     N/A表示无效
Min Bandwidth
最小保证带宽,N/A表示无效
Max bandwidth
最大带宽值,N/A表示无效
4.5.3  display qos qmprofile interface
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface ten-gigabitethernet 1/0/1
Direction: Outbound
表4-7 display qos qmprofile interface命令显示信息描述表
接口名称
Direction
队列调度策略应用的方向
队列调度策略名称
4.5.4  qos apply qmprofile
qos apply qmprofile命令用来在接口出方向上应用队列调度策略。
undo qos apply qmprofile命令用来恢复缺省情况。
接口上未应用队列调度策略。
每个接口在同一方向上只能应用一个队列调度策略。
# 在接口Ten-GigabitEthernet1/0/1出方向上应用队列调度策略myprofile。
[Sysname-Ten-GigabitEthernet1/0/1] qos apply qmprofile myprofile
·     display qos qmprofile interface
4.5.5  qos qmprofile
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入相应的队列调度策略视图。如果指定的队列调度策略已经存在,则直接进入该队列调度策略视图。
undo qos qmprofile命令用来删除用户自定义的队列调度策略。
qos qmprofile profile-name
undo qos qmprofile profile-name
不存在用户自定义的队列调度策略。
如果需要删除已经应用到接口的队列调度策略,必须先在应用的位置上取消对该队列调度策略的应用,然后再删除该队列调度策略。
# 创建队列调度策略myprofile,并进入队列调度策略视图。
·     queue
4.5.6  queue (queue scheduling profile view)
queue命令用来配置队列调度参数。
undo queue命令用来取消队列调度参数的配置。
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
缺省情况下,队列调度策略的内容是所有队列均采用SP方式调度。
队列调度策略视图
sp:配置队列为严格优先级调度。
wfq:配置队列为加权公平调度。
wrr:配置队列为加权轮询调度。
group group-id:优先组号。取值只能为1。
schedule-value:配置队列的调度权重。取值范围为1~127。
# 创建自定义的队列调度策略myprofile,并配置队列0为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 0 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,分组为1,权重为10。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
·     qos qmprofile
5 拥塞避免
5.1  WRED配置命令
5.1.1  display qos wred interface
display qos wred interface命令用来显示接口上WRED配置情况和统计信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的WRED配置情况和统计信息。
# 显示所有接口下应用的WRED表配置情况和统计信息。
<Sysname> display qos wred interface
 Current WRED configuration:
 Applied WRED table name: q1
Table type: Queue based WRED
QID gmin     gmax     gpro ymin     ymax     ypro rmin     rmax     rpro exp ECN
0   100      1000     10   100      1000     10   100      1000     10   9   N
1   100      1000     10   100      1000     10   100      1000     10   9   N
2   100      1000     10   100      1000     10   100      1000     10   9   N
3   100      1000     10   100      1000     10   100      1000     10   9   N
4   100      1000     10   100      1000     10   100      1000     10   9   N
5   100      1000     10   100      1000     10   100      1000     10   9   N
6   100      1000     10   100      1000     10   100      1000     10   9   N
7   100      1000     10   100      1000     10   100      1000     10   9   N
# 显示所有接口下配置的WRED配置情况和统计信息。
表5-1 display qos wred interface命令显示信息描述表
接口名,由接口类型和接口编号组成
当前WRED的配置情况
当前应用的WRED表的名称
Table type
WRED表类型,当前仅支持Queue based WRED
QID
队列ID
gmin
绿色报文的队列下限
gmax
绿色报文的队列上限
gpro
绿色报文的丢弃概率
ymin
黄色报文的队列下限
ymax
黄色报文的队列上限
ypro
黄色报文的丢弃概率
rmin
红色报文的队列下限
rmax
红色报文的队列上限
rpro
红色报文的丢弃概率
exp
计算平均队列长度指数
ECN
是否对该队列开启了拥塞通知功能,Y表示开启,N表示未开启
5.1.2  display qos wred table
display qos wred table命令用来显示WRED表的配置情况。
(独立运行模式)
display qos wred table [ name table-name ] [ chassis chassis-number slot slot-number ]
name table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则显示所有WRED表配置情况。
slot slot-number:显示指定单板的WRED表配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的WRED表配置情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的WRED表配置情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的WRED表配置情况。(IRF模式)
# 显示WRED表1的配置情况,表1是一个已经配置好的WRED参数表。
<Sysname> display qos wred table name 1
Table name: 1
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
表5-2 display qos wred table命令显示信息描述表
Table name
WRED表名
Table type
WRED表类型
QID
队列ID
gmin
绿色报文的队列下限
gmax
绿色报文的队列上限
gprob
绿色报文的丢弃概率
ymin
黄色报文的队列下限
ymax
黄色报文的队列上限
yprob
黄色报文的丢弃概率
rmin
红色报文的队列下限
rmax
红色报文的队列上限
rprob
红色报文的丢弃概率
exponent
计算平均队列长度指数
ECN
‌是否对该队列开启了拥塞通知功能,Y表示开启,N表示未开启
5.1.3  qos wred apply
qos wred apply命令用来在接口上应用WRED表。
undo qos wred apply命令用来恢复缺省情况。
qos wred apply [ table-name ]
undo qos wred apply
接口没有应用WRED表,即接口采用尾丢弃。
table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则在接口上应用缺省WRED表。
# 在接口Ten-GigabitEthernet1/0/1上应用WRED表。
[Sysname-Ten-GigabitEthernet1/0/1] qos wred apply table1
·     display qos wred interface
·     display qos wred table
·     qos wred queue table
5.1.4  qos wred queue
qos wred queue命令用来配置队列的WRED参数。
undo qos wred queue命令用来恢复缺省情况。
qos wred queue queue-id low-limit low-limit high-limit high-limit [ discard-probability discard-prob ] [ ecn ] [ weighting-constant exponent ]
qos wred queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo qos wred queue { queue-id [ drop-level drop-level ] | all }
未配置队列的WRED参数。
queue-id:队列编号。取值范围为0~7。
low-limit low-limit:队列平均长度的下限。取值范围为0~16383,单位为208byte。
high-limit high-limit:队列平均长度的上限。取值范围为0~16383且必须大于丢弃下限,单位为208byte。
discard-probability discard-prob:丢弃概率,取值越大,计算出的丢弃概率越大。取值范围为0~100。
ecn:表示开启指定队列的拥塞通知功能。
weighting-constant exponent:计算平均队列长度的指数。exponent的取值范围为1~15。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,表示后续配置的参数对该队列所有丢弃级别的报文都生效。
all:表示所有队列。
当队列平均长度小于下限时,不丢弃报文。当队列平均长度在上限和下限之间时,设备随机丢弃报文,队列越长,丢弃概率越高。当队列平均长度超过上限时,丢弃所有到来的报文。
配置本命令时指定ecn参数,与配置qos wred queue ecn命令等效。
配置本命令时指定weighting-constant exponent参数,与配置qos wred queue weighting-constant命令等效。
通过本命令直接在接口下配置队列的WRED参数,与使用qos wred apply命令在接口下应用WRED表等效,且两种配置方式互斥。
# 配置接口Ten-GigabitEthernet1/0/1下队列1中的WRED参数:丢弃级别为1,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30%。
[Sysname-Ten-GigabitEthernet1/0/1] qos wred queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
·     qos wred queue ecn
5.1.5  qos wred queue ecn
qos wred queue ecn命令用来开启指定队列的拥塞通知功能。
undo qos wred queue ecn命令用来恢复缺省情况。
qos wred queue queue-id ecn
undo qos wred queue queue-id ecn
对任何队列都未开启拥塞通知功能。
在报文的发送端和接收端都支持ECN功能时,设备可以通过对ECN域的识别和标记将拥塞状况告知终端,避免拥塞加剧。
配置本命令与配置qos wred queue命令时指定ecn参数等效。
当启用ECN功能时,请勿在iNQA中指定比特位6或7作为其染色位,反之亦然。有关iNQA的详细介绍,请参见“网络管理与监控配置指导”中的“iNQA”。
# 开启接口Ten-GigabitEthernet1/0/1下队列1的拥塞通知功能。
[Sysname-Ten-GigabitEthernet1/0/1] qos wred queue 1 ecn
·     qos wred queue
5.1.6  qos wred queue table
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。如果指定的WRED表已经存在,则直接进入WRED表视图。
undo qos wred queue table命令用来删除WRED表。
undo qos wred queue table table-name
设备上不存在WRED表。
table table-name:指定WRED表的名称,为1~32个字符的字符串,区分大小写。
设备不允许删除正在使用的WRED表。如果需要删除正在使用的表,请先在接口上取消应用的WRED表。
缺省WRED表可以通过display qos wred table命令显示,不允许修改和删除。
# 创建基于queue的WRED表queue-table1。
[Sysname-wred-table-queue-table1]
5.1.7  qos wred queue weighting-constant
qos wred queue weighting-constant命令用来配置计算平均队列长度的指数。
undo qos wred queue weighting-constant命令用来恢复缺省情况。
qos wred queue queue-id weighting-constant exponent
undo qos wred queue queue-id weighting-constant
计算平均队列长度的指数为9。
平均队列长度的指数越大,计算平均队列长度时对队列的实时变化越不敏感。计算队列平均长度的公式为:平均队列长度=(以前的平均队列长度×(1-1/2n))+(当前队列长度×(1/2n))。其中n表示指数。
配置本命令与配置qos wred queue命令时指定weighting-constant exponent参数等效。
# 配置接口Ten-GigabitEthernet1/0/1下队列1计算平均队列长度的指数为12。
[Sysname-Ten-GigabitEthernet1/0/1] qos wred queue 1 weighting-constant 12
·     qos wred queue
5.1.8  queue (Wred table view)
queue命令用来配置基于队列的WRED表的内容。
undo queue命令用来恢复缺省情况。
undo queue { queue-id [ drop-level drop-level ] | all }
WRED表在创建之后,low-limit的缺省取值为100,high-limit的缺省取值为1000,discard-prob的缺省取值为10。
WRED表视图
all:表示所有队列。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,后续配置的参数对该队列所有丢弃级别的报文都生效。
# 配置基于队列的WRED表queue-table1中队列1的丢弃参数:丢弃级别为1,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30%。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
5.1.9  queue ecn
queue ecn命令用来对指定队列开启拥塞通知功能。
undo queue ecn命令用来恢复缺省情况。
queue queue-id ecn
undo queue queue-id ecn
对任何队列都未开启拥塞通知功能。
WRED表视图
拥塞通知功能仅对TCP连接中的已知单播生效。
# 在WRED表queue-table1中,对队列1开启拥塞通知功能。
[Sysname-wred-table-queue-table1] queue 1 ecn
5.1.10  queue weighting-constant
undo queue weighting-constant命令用来恢复缺省情况。
undo queue queue-id weighting-constant
计算平均队列长度的指数为9。
WRED表视图
# 在WRED表queue-table1中,配置计算平均队列长度的指数为12。
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
6 全局CAR
6.1  全局CAR配置命令
6.1.1  car name
car name命令用来配置全局CAR动作。
undo car用来恢复缺省情况。
car name car-name [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
未配置全局CAR动作。
流行为视图
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
hierarchy-car-name:分层CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
mode:分层CAR和聚合CAR动作的合作模式。有andor两种模式,默认为and模式。
·     and:在该模式下,对于多条数据流应用同一个分层CAR,必须每条流满足各自的聚合CAR配置,同时各流量之和又满足分层CAR的配置,流量才能正常通过。
·     or:在该模式下,对于多条数据流应用同一个分层CAR,只要每条流满足各自的聚合CAR配置或者各流量之和满足分层CAR配置,流量即可正常通过。
# 配置流行为be1的聚合CAR动作为aggcar-1。
# 配置流行为be1的聚合CAR动作为aggcar-1,分层CAR动作为hcar,合作模式为or。
[Sysname-behavior-be1] car name aggcar-1 hierarchy-car hcar mode or
·     display qos car name
·     display traffic behavior user-defined
6.1.2  display qos car name
display qos car name命令用来显示全局CAR的配置和统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。显示指定全局CAR的配置和统计信息。如果未指定本参数,将显示所有全局CAR的配置和统计信息,包含聚合CAR和分层CAR。
# 显示全局CAR的配置和统计信息。(独立运行模式)
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
   Green action  : pass
   Yellow action : pass
   Red action    : discard
  Mode: hierarchy
   CIR 64 (kbps) CBS: 2048 (Bytes)
表6-1 display qos car name命令显示信息描述表
Name
全局CAR的名称
Mode
聚合CAR的类型,取值为aggregative(聚合CAR)和hierarchy(分层CAR)
CIR  CBS  PIR  EBS
流量监管流量的参数配置
Green action
对绿色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Yellow action
对黄色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Red action
对红色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
6.1.3  qos car (system view)
qos car命令用来配置聚合CAR或分层CAR。
undo qos car命令用来取消聚合CAR或分层CAR的配置。
qos car car-name { aggregative | hierarchy } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name { aggregative | hierarchy } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
未配置聚合CAR或分层CAR。
aggregative:该全局CAR为聚合模式。
hierarchy:该全局CAR为分层模式。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~160000000且必须为8的整数倍。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,单位为byte。
·     如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过256000000。
·     如果指定cbs参数,取值范围512~256000000且必须为512的整数倍。
ebs excess-burst-size:过度突发尺寸,单位为byte。本参数仅全局CAR为聚合模式时支持。
配置pir参数后:
·     如果不指定ebs,则ebs缺省取值为与62.5 × peak-information-rate的乘积最接近且不小于512的整数倍,但是最大值不能超过256000000。
·     如果指定ebs,取值范围0~256000000且必须为512的整数倍。
未配置pir参数时,ebs的取值范围为0~256000000且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为8~160000000且必须为8的整数倍,本参数仅全局CAR为聚合模式时支持。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass,本参数仅全局CAR为聚合模式时支持。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard,本参数仅全局CAR为聚合模式时支持。
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass,本参数仅全局CAR为聚合模式时支持。
action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dot1p-pass new-cos:设置新的802.1P报文的优先级值,并允许数据包通过,取值范围为0~7。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63;用文字表示时,可以选取af11af12af13af21af22af23af31af32af33af41af42af43cs1cs2cs3cs4cs5cs6cs7defaultef
聚合CAR配置需要在策略中引用后才能生效。
分层CAR配置需要在策略中引用后才能生效。
不配置峰值速率表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 配置聚合CAR采取的CAR参数取值,cir取值为25600,cbs取值为512000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
# 配置分层CAR采取的CAR参数取值,cir取值为120,cbs取值为51200。
[Sysname] qos car h-car hierarchy cir 120 cbs 51200
6.1.4  reset qos car name
reset qos car name命令用来清除全局CAR的统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。清除指定全局CAR的统计信息。如果未指定本参数,将清除所有全局CAR的统计信息,包含聚合CAR和分层CAR。
# 清除全局CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
7 端口队列统计
7.1  端口队列统计配置命令
7.1.1  display qos queue-statistics interface outbound
display qos queue-statistics interface outbound命令用来显示端口队列出方向的统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列出方向统计信息。
# 显示接口Ten-GigabitEthernet1/0/1的队列出方向统计信息。
<Sysname> display qos queue-statistics interface ten-gigabitethernet 1/0/1 outbound
 Direction: outbound
 Forwarded: 0 packets, 0 bytes
 Dropped: 0 packets, 0 bytes
 Queue 0
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Current queue length: 0 packets
 Queue 1
 Queue 2
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
表7-1 display qos queue-statistics interface outbound命令显示信息描述表
端口队列统计的端口
Direction
端口队列统计的方向
Forwarded
转发的数据包数目和字节数
Dropped
丢弃的数据包数目和字节数
Queue 0、Queue 1、Queue 2、Queue 3、Queue 4、Queue 5、Queue 6、Queue 7
某端口队列统计信息
当前队列长度
·     reset counters interface(接口管理命令参考/以太网接口)
