01-产品介绍
本章节下载 (1.97 MB)
S10500机箱外观请以实际发货为准,本文中仅以S10506和S10510机箱为例。
图1-1 S10506前、后面板示意图
1: 业务板槽位(0~5号槽位) |
2: 电源模块 |
3: 风扇框 |
4: PoE电源接入模块槽位 |
5: 主控板槽位(6~7号槽位) |
6: 交换网板槽位(8~9号槽位) |
图1-2 S10510前、后面板示意图
1: 业务板槽位(0~9号槽位) |
2: 电源模块 |
3: 风扇框 |
4: PoE电源接入模块槽位 |
5: 主控板槽位(10~11号槽位) |
6: 交换网板槽位(12~13号槽位) |
S10500系列交换机采用了可插拔设计,交换机整机重量与所插的可插拔部件的类型及数量有关。具体计算公式为:设备最终重量=机箱重量+单板总重量+电源总重量+可插拔接口模块总重量+其它可插拔部件总重量。
机型 |
整机最大配置重量 |
尺寸 |
高(H) |
宽(W) |
深(D) |
S10504 |
满配:<75kg |
353mm(8RU) |
440mm |
660mm |
S10506 |
满配:<75kg |
353mm(8RU) |
440mm |
660mm |
S10508 |
满配:<115kg |
620mm(14RU) |
440mm |
660mm |
S10508-V |
满配:<130kg |
886mm(20RU) |
440mm |
660mm |
S10510 |
满配:<115kg |
620mm(14RU) |
440mm |
660mm |
S10512 |
满配:<150kg |
797mm(18RU) |
440mm |
660mm |
· RU(Rack Unit)是表示机柜高度的度量单位,1RU=44.45mm(1.75inch)。
· 表1-1中的尺寸数据为机箱本身的尺寸数值,不包括挂耳、走线架、单板、电源等现场安装部件和附件装配后的尺寸。
· 表1-2中的单板丝印与单板的对外型号可能存在细微差异,例如单板丝印为LSU1SUPB0,其对外型号为LSUM1SUPB0。
单板丝印 |
净重 |
尺寸 |
高(H) |
宽(W) |
深(D) |
LSU1SUPA0 |
2.83kg |
40mm |
399mm |
352mm |
LSU1SUPB0 |
2.97kg |
40mm |
399mm |
352mm |
LSUM1SUPC0 |
2.80kg |
40mm |
399mm |
352mm |
LSUM1SUPD0 |
3.05kg |
40mm |
399mm |
352mm |
LSUM1MPU06B0 |
2.00kg |
40mm |
264mm |
318mm |
LSUM1MPU10A0 |
2.75kg |
40mm |
433mm |
318mm |
LSUM1MPU10C0 |
2.90kg |
40mm |
433mm |
318mm |
LSUM2MPU10C0 |
2.97kg |
40mm |
433mm |
318mm |
LSU1FAB04A0 |
1.61kg |
40mm |
256mm |
298mm |
LSU1FAB04B0 |
1.71kg |
40mm |
256mm |
298mm |
LSU1FAB04D0 |
1.71kg |
40mm |
256mm |
298mm |
LSUM1FAB06C0 |
1.80kg |
40mm |
264mm |
318 mm |
LSU1FAB08A0 |
2.53kg |
40mm |
426mm |
298mm |
LSU1FAB08B0 |
2.50kg |
40mm |
426mm |
298mm |
LSU1FAB08D0 |
2.77kg |
40mm |
426mm |
298mm |
LSUM1FAB10A0 |
2.60kg |
40mm |
433mm |
318 mm |
LSUM1FAB10C0 |
2.75kg |
40mm |
433mm |
318 mm |
LSUM2FAB10C0 |
2.79kg |
40mm |
433mm |
318 mm |
LSU1FAB12B0 |
3.98kg |
40mm |
602mm |
298mm |
LSU1FAB12D0 |
4.51kg |
40mm |
602mm |
298mm |
LSU1CGC2SE0 |
3.97kg |
40mm |
399mm |
355mm |
LSUM1CGC2EC0 |
4.06kg |
40mm |
399mm |
355mm |
LSU1QGC4SF0 |
3.47kg |
40mm |
399mm |
355mm |
LSUM2CQGS12SG0 |
3.20kg |
40mm |
399mm |
355mm |
LSUM1CGS2FE0 |
2.82kg |
40mm |
399mm |
355mm |
LSUM1CGS8SH0 |
3.10kg |
40mm |
399mm |
355mm |
LSUM1CGS8QSSH0 |
3.30kg |
40mm |
399mm |
355mm |
LSUM2TGS32QSSG0 |
3.50kg |
40mm |
399mm |
355mm |
LSUM2QGS24RSG0 |
3.40kg |
40mm |
399mm |
355mm |
LSUM1QGS12SG0 |
3.30kg |
40mm |
399mm |
355mm |
LSUM2QGS12SG0 |
3.40kg |
40mm |
399mm |
355mm |
LSUM1YGS24CSSH0 |
3.45kg |
40mm |
399mm |
355mm |
LSU1QGS8SF0 |
3.37kg |
40mm |
399mm |
355mm |
LSU1QGS4SF0 |
3.14kg |
40mm |
399mm |
355mm |
LSUM1QGS6EC0 |
3.95kg |
40mm |
399mm |
355mm |
LSU1GP24TXSE0 |
3.08kg |
40mm |
399mm |
355mm |
LSU1GP24TXEA0 |
3.08kg |
40mm |
399mm |
355mm |
LSU1GP24TXEB0 |
3.08kg |
40mm |
399mm |
355mm |
LSU1P24XGSE3 |
2.95kg |
40mm |
399mm |
355mm |
LSU1T24XGSE3 |
2.92kg |
40mm |
399mm |
355mm |
LSU1TGX4SE0 |
2.93kg |
40mm |
399mm |
355mm |
LSU1TGX4EA0 |
2.93kg |
40mm |
399mm |
355mm |
LSU1TGX4EB0 |
2.93kg |
40mm |
399mm |
355mm |
LSUM2GT24PTSSE0 |
2.80kg |
40mm |
399mm |
355mm |
LSUM2GT24TSSE0 |
2.60kg |
40mm |
399mm |
355mm |
LSUM1TGS48SH0 |
3.55kg |
40mm |
399mm |
355mm |
LSUM2TGS48SH0 |
3.55kg |
40mm |
399mm |
355mm |
LSUM1TGS48RSH0 |
3.55kg |
40mm |
399mm |
355mm |
LSUM2GP44TSSE0 |
3.00kg |
40mm |
399mm |
355mm |
LSUM2GP24TSSE0 |
2.85kg |
40mm |
399mm |
355mm |
LSU1TGS48SF0 |
4.13kg |
40mm |
399mm |
355mm |
LSUM1GP40TS8FD0 |
3.20kg |
40mm |
399mm |
355mm |
LSUM2GP40TS8FD0 |
3.20kg |
40mm |
399mm |
355mm |
LSUM1TGS48SG0 |
3.60kg |
40mm |
399mm |
355mm |
LSUM2TGS48SG0 |
3.55kg |
40mm |
399mm |
355mm |
LSU1TGS32SF0 |
3.45kg |
40mm |
399mm |
355mm |
LSUM1TGS24FD0 |
3.05kg |
40mm |
399mm |
355mm |
LSU1TGS16SF0 |
3.16kg |
40mm |
399mm |
355mm |
LSU1TGS16SC0 |
3.03kg |
40mm |
399mm |
355mm |
LSUM1TGS16FD0 |
2.91kg |
40mm |
399mm |
355mm |
LSUM2TGS16SF0 |
3.00kg |
40mm |
399mm |
355mm |
LSU1TGS8EA0 |
3.43kg |
40mm |
399mm |
355mm |
LSU1TGS8EB0 |
3.44kg |
40mm |
399mm |
355mm |
LSU1TGS8SF0 |
3.02kg |
40mm |
399mm |
355mm |
LSU1TGS8SE0 |
3.29kg |
40mm |
399mm |
355mm |
LSUM1GP44TSEC0 |
3.60kg |
40mm |
399mm |
355mm |
LSUM1TGS24EC0 |
4.15kg |
40mm |
399mm |
355mm |
LSUM2GP24TSSA0 |
2.85kg |
40mm |
399mm |
355mm |
LSU1GT40PSE3 |
3.02kg |
40mm |
399mm |
355mm |
LSU1GP24TSE0 |
3.01kg |
40mm |
399mm |
355mm |
LSU1GP24TSE3 |
2.77kg |
40mm |
399mm |
355mm |
LSU1GP48SE0 |
3.25kg |
40mm |
399mm |
355mm |
LSU1GP48EA0 |
3.25kg |
40mm |
399mm |
355mm |
LSU1GP48EB0 |
3.25kg |
40mm |
399mm |
355mm |
LSUM2GP48SA0 |
3.00kg |
40mm |
399mm |
355mm |
LSU1GP48SE3 |
3.04kg |
40mm |
399mm |
355mm |
LSU1GP24SE3 |
2.78kg |
40mm |
399mm |
355mm |
LSU1GP12SE3 |
2.66kg |
40mm |
399mm |
355mm |
LSUM1GP48FD0 |
3.10kg |
40mm |
399mm |
355mm |
LSU1TGT24SF0 |
3.53kg |
40mm |
399mm |
355mm |
LSUM1TGT24FD0 |
3.40kg |
40mm |
399mm |
355mm |
LSU1GT48SE3 |
3.09kg |
40mm |
399mm |
355mm |
LSUM1GT48FD0 |
3.45kg |
40mm |
399mm |
355mm |
LSUM2GT48SA0 |
2.71kg |
40mm |
399mm |
355mm |
LSU1GT48SE0 |
3.31kg |
40mm |
399mm |
355mm |
LSU1GT48EA0 |
3.31kg |
40mm |
399mm |
355mm |
LSUM2GT48SE0 |
2.71kg |
40mm |
399mm |
355mm |
LSUM2GV48SE0 |
3.12kg |
40mm |
399mm |
355mm |
LSU1GT24SE3 |
2.72kg |
40mm |
399mm |
355mm |
LSUM1SPMAEC0 |
3.98kg |
40mm |
399mm |
355mm |
LSR1DRUP1L1 |
0.39kg |
18mm |
165mm |
142mm |
LSU1WCME0 |
4.00kg |
40mm |
399mm |
355mm |
LSU3WCMD0 |
3.62kg |
40mm |
399mm |
355mm |
LSQ1WCMD0 |
3.40kg |
40mm |
399mm |
355mm |
LSU1FWCEA0 |
3.90kg |
40mm |
399mm |
355mm |
LSU3FWCEA0 |
3.90kg |
40mm |
399mm |
355mm |
LSQM1FWDSC0 |
3.80kg |
40mm |
399mm |
355mm |
LSUM1FWCEAB0 |
3.90kg |
40mm |
399mm |
355mm |
LSUM1FWDEC0 |
3.80kg |
40mm |
399mm |
355mm |
LSQM1NSDSC0 |
3.80kg |
40mm |
399mm |
355mm |
LSUM1NSDEC0 |
3.80kg |
40mm |
399mm |
355mm |
LSUM1WCMX20RT |
4.00kg |
40mm |
399mm |
355mm |
LSUM1WCMX40RT |
4.00kg |
40mm |
399mm |
355mm |
LSQ2FWBSC0 |
3.23kg |
40mm |
399mm |
355mm |
LSQ1FWBSC0 |
3.23kg |
40mm |
399mm |
355mm |
LSU1NSCEA0 |
3.90kg |
40mm |
399mm |
355mm |
LSQ1NSMSC0 |
3.23kg |
40mm |
399mm |
355mm |
LSU1IPSBEA0 |
3.90kg |
40mm |
399mm |
355mm |
LSQ1IPSSC0 |
3.23kg |
40mm |
399mm |
355mm |
LSQM1IPSDSC0 |
3.80kg |
40mm |
399mm |
355mm |
LSQ1SSLSC0 |
3.10kg |
40mm |
399mm |
355mm |
LSU1ADECEA0 |
3.90kg |
40mm |
399mm |
355mm |
LSQ1ACGASC0 |
3.23kg |
40mm |
399mm |
355mm |
LSQM1ACGDSC0 |
3.80kg |
40mm |
399mm |
355mm |
LSUM1ACGDEC0 |
3.80kg |
40mm |
399mm |
355mm |
LSQM1ADEDSC0 |
3.80kg |
40mm |
399mm |
355mm |
LSQ1LBSC0 |
3.23kg |
40mm |
399mm |
355mm |
LSQM2FWDSC0 |
3.30kg |
40mm |
399mm |
355mm |
LSUM1EPSB0 |
3.25kg |
40mm |
399mm |
355mm |
LSUM1SDNB0 |
3.25kg |
40mm |
399mm |
355mm |
LSUM1WBCZ720XRT |
3.5kg |
40mm |
399mm |
355mm |
S10500系列交换机的单板尺寸以高(H)×宽(W)×深(D)形式表示。其中各项含义见以下说明:
· 高(H):指单板前面板的高度。
· 宽(W):指单板前面板的宽度。
· 深(D):指单板由前面板到连接器的深度。
表1-3 电源模块重量及尺寸列表
电源型号 |
净重 |
尺寸 |
高(H) |
宽(W) |
深(D) |
LSUM1AC1200 |
2.27kg |
41mm |
102mm |
400mm |
LSUM1AC2500 |
2.50kg |
41mm |
102mm |
400mm |
LSUM1DC2400 |
2.40kg |
41mm |
102mm |
400mm |
表1-4 风扇框重量及尺寸列表
风扇框 |
净重 |
尺寸(风扇框平放到桌面上) |
高(H) |
宽(W) |
深(D) |
S10504风扇框 |
4.60kg |
106mm |
255mm |
643mm |
S10506风扇框 |
4.50kg |
66mm |
263mm |
643mm |
S10508风扇框 |
7.40kg |
107mm |
425mm |
645mm |
S10508-V风扇框 |
8.45kg |
80mm |
440mm |
654mm |
S10510风扇框 |
6.85kg |
66mm |
433mm |
645mm |
S10512风扇框(上) |
4.50kg |
84mm |
300mm |
646mm |
S10512风扇框(下) |
3.80kg |
84mm |
299mm |
646mm |
表1-5 PoE系统部件重量及尺寸列表
部件名称 |
型号 |
净重 |
尺寸 |
高(H) |
宽(W) |
深(D) |
PoE电源接入模块 |
LSUM1PPEMA0 |
1.80kg |
40mm |
264mm |
298mm |
LSUM1PPEMB0 |
3.70kg |
40mm |
433mm |
298mm |
PoE外置电源框 |
LSUM1PSE16KA0 |
14.40kg |
88mm |
440mm |
600mm |
PoE电源模块 |
LSTM2PSRA |
2.19kg |
41mm |
102mm |
352mm |
S10500系列交换机支持的单板种类丰富,不同单板的功耗有所不同,而且同一块单板在不同状态下的功耗也存在差异,具体型号单板的功耗请参见表1-6。
· 单板静态功耗是指单板已上电运行、所有端口均处于DOWN状态且单板的光接口上无可插拔接口模块的情况下,单板所产生的功耗。
· 单板动态功耗是指单板所有端口满配,广播风暴情况下所产生的功耗。
单板丝印 |
单板静态功耗 min |
单板动态功耗 max |
LSU1SUPA0 |
38W |
50W |
LSU1SUPB0 |
45W |
50W |
LSUM1SUPC0 |
33W |
45W |
LSUM1SUPD0 |
46W |
52W |
LSUM1MPU06B0 |
40W |
78W |
LSUM1MPU10A0 |
56W |
92W |
LSUM1MPU10C0 |
81W |
145W |
LSUM2MPU10C0 |
58W |
99W |
LSU1FAB04A0 |
41W |
50W |
LSU1FAB04B0 |
48W |
65W |
LSU1FAB04D0 |
60W |
80W |
LSUM1FAB06C0 |
40W |
79W |
LSU1FAB08A0 |
68W |
85W |
LSU1FAB08B0 |
44W |
60W |
LSU1FAB08D0 |
101W |
135W |
LSUM1FAB10A0 |
48W |
70W |
LSUM1FAB10C0 |
69W |
136W |
LSUM2FAB10C0 |
56W |
81W |
LSU1FAB12B0 |
107W |
140W |
LSU1FAB12D0 |
195W |
255W |
LSU1CGC2SE0 |
163W |
220W |
LSUM1CGC2EC0 |
144W |
197W |
LSU1QGC4SF0 |
53W |
85W |
LSUM2CQGS12SG0 |
55W |
147W |
LSUM1CGS2FE0 |
55W |
77W |
LSUM1CGS8SH0 |
58W |
138W |
LSUM1CGS8QSSH0 |
72W |
183W |
LSUM2TGS32QSSG0 |
60W |
147W |
LSUM2QGS24RSG0 |
65W |
198W |
LSUM1QGS12SG0 |
103W |
205W |
LSUM2QGS12SG0 |
76W |
163W |
LSUM1YGS24CSSH0 |
68W |
161W |
LSU1QGS8SF0 |
100W |
135W |
LSU1QGS4SF0 |
82W |
100W |
LSUM1QGS6EC0 |
142W |
183W |
LSU1GP24TXSE0 |
54W |
95W |
LSU1GP24TXEA0 |
54W |
95W |
LSU1GP24TXEB0 |
51W |
100W |
LSU1P24XGSE3 |
40W |
55W |
LSU1T24XGSE3 |
50W |
75W |
LSU1TGX4SE0 |
53W |
80W |
LSU1TGX4EA0 |
53W |
80W |
LSU1TGX4EB0 |
53W |
80W |
LSUM2GT24PTSSE0 |
38W |
60W |
LSUM2GT24TSSE0 |
35W |
45W |
LSUM2GP44TSSE0 |
39W |
70W |
LSUM2GP24TSSE0 |
36W |
55W |
LSUM1TGS48SH0 |
54W |
130W |
LSUM2TGS48SH0 |
54W |
130W |
LSUM1TGS48RSH0 |
47W |
109W |
LSU1TGS48SF0 |
164W |
255W |
LSUM1GP40TS8FD0 |
47W |
96W |
LSUM2GP40TS8FD0 |
45W |
84W |
LSUM1TGS48SG0 |
107W |
215W |
LSUM2TGS48SG0 |
82W |
173W |
LSU1TGS32SF0 |
126W |
170W |
LSUM1TGS24FD0 |
50W |
104W |
LSU1TGS16SF0 |
98W |
115W |
LSU1TGS16SC0 |
84W |
115W |
LSUM1TGS16FD0 |
54W |
96W |
LSUM2TGS16SF0 |
45W |
75W |
LSU1TGS8EA0 |
111W |
140W |
LSU1TGS8EB0 |
117W |
170W |
LSU1TGS8SF0 |
81W |
95W |
LSU1TGS8SE0 |
104W |
135W |
LSUM1GP44TSEC0 |
110W |
125W |
LSUM1TGS24EC0 |
153W |
209W |
LSUM2GP24TSSA0 |
31W |
50W |
LSU1GT40PSE3 |
41W |
95W |
LSU1GP24TSE0 |
47W |
75W |
LSU1GP24TSE3 |
25W |
45W |
LSU1GP48SE0 |
44W |
95W |
LSU1GP48EA0 |
44W |
95W |
LSU1GP48EB0 |
43W |
110W |
LSUM2GP48SA0 |
34W |
65W |
LSU1GP48SE3 |
43W |
85W |
LSU1GP24SE3 |
38W |
55W |
LSU1GP12SE3 |
26W |
35W |
LSUM1GP48FD0 |
49W |
78W |
LSU1TGT24SF0 |
103W |
190W |
LSUM1TGT24FD0 |
60W |
112W |
LSU1GT48SE3 |
60W |
90W |
LSUM1GT48FD0 |
48W |
65W |
LSUM2GT48SA0 |
33W |
47W |
LSU1GT48SE0 |
67W |
95W |
LSU1GT48EA0 |
67W |
95W |
LSUM2GT48SE0 |
37W |
51W |
LSUM2GV48SE0 |
37W |
51W |
LSU1GT24SE3 |
42W |
50W |
LSUM1SPMAEC0 |
94W |
105W |
LSR1DRUP1L1 |
14W |
18 W |
LSU1WCME0 |
125W |
180W |
LSU3WCMD0 |
118W |
150W |
LSQ1WCMD0 |
86W |
117W |
LSU1FWCEA0 |
109W |
157W |
LSU3FWCEA0 |
109W |
157W |
LSQM1FWDSC0 |
115W |
123W |
LSUM1FWCEAB0 |
109W |
157W |
LSUM1FWDEC0 |
156w |
170W |
LSQM1NSDSC0 |
115W |
123W |
LSUM1NSDEC0 |
156w |
170W |
LSUM1WCMX20RT |
125W |
180W |
LSUM1WCMX40RT |
125W |
180W |
LSQ2FWBSC0 |
80W |
104W |
LSQ1FWBSC0 |
80W |
104W |
LSU1NSCEA0 |
109W |
157W |
LSQ1NSMSC0 |
80W |
104W |
LSU1IPSBEA0 |
109W |
157W |
LSQ1IPSSC0 |
80W |
104W |
LSQM1IPSDSC0 |
116W |
124W |
LSQ1SSLSC0 |
80W |
89W |
LSU1ADECEA0 |
109W |
157W |
LSQ1ACGASC0 |
80W |
104W |
LSQM1ACGDSC0 |
116W |
124W |
LSUM1ACGDEC0 |
157W |
170W |
LSQM1ADEDSC0 |
116W |
124W |
LSQ1LBSC0 |
80W |
104W |
LSQM2FWDSC0 |
60W |
66W |
LSUM1EPSB0 |
106W |
126W |
LSUM1SDNB0 |
106W |
126W |
LSUM1WBCZ720XRT |
160W |
210W |
S10500系列交换机的风扇框中均采用了具有自动调速功能的风扇(风扇的转速会随着设备散热需要进行自动调节)。在不同风扇速率下,风扇框产生的功耗有所不同,具体机型风扇框的功耗请参见表1-7。
表1-7 机箱风扇框功耗列表
机型 |
风扇框功耗 min |
风扇框功耗 max |
S10504 |
12W |
240W |
S10506 |
19W |
195W |
S10508 |
11W |
234W |
S10508-V |
13W |
329W |
S10510 |
21W |
255W |
S10512(上) |
9W |
200W |
S10512(下) |
7W |
124W |
对于S10504、S10508、S10508-V和S10512交换机,总功耗等于交换机整机功耗。
对于S10506和S10510交换机,总功耗=交换机整机功耗+PoE功耗。
交换机整机功耗是指交换机所有在位运行的单板功耗及风扇框功耗的和。S10500系列交换机整机功耗与所插的单板类型及数量、风扇框功耗有关,具体计算方式为:
· 交换机整机最小功耗=单板静态总功耗+风扇框最小功耗(例如,有一台S10506交换机插有2块LSUM1MPU06B0主控板、2块LSUM1CGC2EC0业务板、2块LSUM1FAB06C0网板和1个S10506风扇框,那么该交换机当前的最小功耗为2×40+2×144+2×40+19=467W)。
· 交换机整机最大功耗=单板动态总功耗+风扇框最大功耗(例如,有一台 S10506交换机插有2块LSUM1MPU06B0主控板、2块LSUM1CGC2EC0业务板、2块LSUM1FAB06C0网板和1个S10506风扇框,那么该交换机当前的最大功耗为2×78+2×197+2×79+195=903W)。
表1-8提供了S10500系列交换机的整机满配最大功耗。
· “整机满配最大输入功耗”指的是设备在满配最大功耗单板和风扇时,整机的最大输入功率。
· “单板+风扇满配最大功耗”指的是设备满配最大功耗的单板和风扇时,整机中所有单板和风扇实际消耗的最大功率总和。
主机型号 |
整机满配最大输入功耗 |
单板+风扇满配最大功耗 |
S10504-AC |
1900W |
1680W |
S10504-DC |
1890W |
1680W |
S10506-AC |
2300W |
2039W |
S10506-DC |
2290W |
2039W |
S10508-AC |
3290W |
2914W |
S10508-DC |
3270W |
2914W |
S10508-V-AC |
3400W |
3009W |
S10508-V-DC |
3380W |
3009W |
S10510-AC |
3800W |
3367W |
S10510-DC |
3780W |
3367W |
S10512-AC |
5080W |
4504W |
S10512-DC |
5060W |
4504W |
PoE功耗是指交换机下挂的所有PD设备功耗的和。
交换机的最大PoE功耗与配备的PoE单板(丝印为LSUM2GV48SE0)数量、支持PoE的端口数量以及单板最大PoE供电功率有关。
· 对于S10506交换机,仅Slot 0~Slot 3支持PoE单板;对于S10510交换机,仅Slot 0~Slot 5支持PoE单板。
· PoE单板共48个端口,均支持PoE供电,单端口供电功率为0~30W。
· PoE单板最大PoE供电能力为800W。
例如,有一台S10506交换机插有3块LSUM2GV48SE0,那么该交换机当前的最大PoE功耗为3×800=2400W。
有关PoE供电的详细介绍请参见《H3C S10500系列交换机 安装指南》。
设备的发热量和设备功耗密切相关。计算S10500系列交换机发热量时,一般假定:90%的功耗转换成热量,电源的转换效率为90%。因此S10500系列交换机每小时散热量的计算公式为:交换机每小时散热量=0.9*(单板总功耗+风扇框功耗)/0.9*3.4121。
表1-9 设备每小时散热量列表
主机型号 |
热耗散(BTU/H) |
S10504 |
5732 |
S10506 |
6957 |
S10508 |
9943 |
S10508-V |
10267 |
S10510 |
11489 |
S10512 |
15369 |
· S10500系列交换机各型号单板及风扇框的功耗请参见“表1-5”。
· 热量单位一般为BTU/h,1瓦=3.4121BTU/h。
表1-10 S10500系列交换机环境适应性指标列表
指标 |
工作环境 |
贮存环境 |
温度 |
0℃~45℃ |
-40℃~70℃ |
相对湿度 |
5%~95%RH,无冷凝 |
5%~95%RH,无冷凝 |
S10500系列交换机的风扇框中均采用了具有自动调速功能的风扇(风扇的转速会随着设备散热需要进行自动调节)。在不同风扇速率下,设备的噪声值有所不同,具体请参见表1-11。
表1-11 S10500系列交换机噪声级别列表
常温下风扇调速设备噪声值 |
风扇全速设备噪声 |
S10504 |
62.3dBA |
75.5dBA |
S10506 |
66.9 dBA |
74.4dBA |
S10508 |
63dBA |
75.8dBA |
S10508-V |
61.6dBA |
72.6dBA |
S10510 |
63dBA |
75.8dBA |
S10512 |
66 dBA |
79 dBA |
