H3C S5500-SI系列以太网交换机 命令手册-RELEASE 1205(V1.04)
10-IPV6配置命令
本章节下载  (323.5 KB)
10-IPV6配置命令
  录
第1章 IPv6基础配置命令... 1-1
1.1 IPv6基础配置命令.. 1-1
1.1.1 display dns ipv6 dynamic-host 1-1
1.1.2 display ipv6 fib. 1-1
1.1.3 display ipv6 host 1-3
1.1.4 display ipv6 interface. 1-4
1.1.5 display ipv6 neighbors. 1-5
1.1.6 display ipv6 neighbors count 1-7
1.1.7 display ipv6 pathmtu. 1-7
1.1.8 display ipv6 socket 1-8
1.1.9 display ipv6 statistics. 1-10
1.1.10 display tcp ipv6 statistics. 1-12
1.1.11 display tcp ipv6 status. 1-15
1.1.12 display udp ipv6 statistics. 1-15
1.1.13 dns server ipv6. 1-16
1.1.14 ipv6. 1-17
1.1.15 ipv6 address. 1-18
1.1.16 ipv6 address auto link-local 1-18
1.1.17 ipv6 address eui-64. 1-19
1.1.18 ipv6 address link-local 1-20
1.1.19 ipv6 host 1-20
1.1.20 ipv6 icmp-error 1-21
1.1.21 ipv6 nd autoconfig managed-address-flag. 1-22
1.1.22 ipv6 nd autoconfig other-flag. 1-22
1.1.23 ipv6 nd dad attempts. 1-23
1.1.24 ipv6 nd hop-limit 1-24
1.1.25 ipv6 nd ns retrans-timer 1-24
1.1.26 ipv6 nd nud reachable-time. 1-25
1.1.27 ipv6 nd ra halt 1-25
1.1.28 ipv6 nd ra interval 1-26
1.1.29 ipv6 nd ra prefix. 1-27
1.1.30 ipv6 nd ra router-lifetime. 1-28
1.1.31 ipv6 neighbor 1-28
1.1.32 ipv6 neighbors max-learning-num.. 1-29
1.1.33 ipv6 pathmtu. 1-30
1.1.34 ipv6 pathmtu age. 1-30
1.1.35 reset dns ipv6 dynamic-host 1-31
1.1.36 reset ipv6 neighbors. 1-31
1.1.37 reset ipv6 pathmtu. 1-32
1.1.38 reset ipv6 statistics. 1-33
1.1.39 reset tcp ipv6 statistics. 1-33
1.1.40 reset udp ipv6 statistics. 1-33
1.1.41 tcp ipv6 timer fin-timeout 1-34
1.1.42 tcp ipv6 timer syn-timeout 1-34
1.1.43 tcp ipv6 window. 1-35
第2章 IPv6应用配置命令... 2-1
2.1 IPv6应用配置命令.. 2-1
2.1.1 ftp ipv6. 2-1
2.1.2 open ipv6. 2-2
2.1.3 ping ipv6. 2-3
2.1.4 telnet ipv6. 2-4
2.1.5 tftp ipv6. 2-5
2.1.6 tftp-server ipv6 acl 2-6
2.1.7 tracert ipv6. 2-6
第1章  IPv6基础配置命令
1.1  IPv6基础配置命令
【描述】
display dns ipv6 dynamic-host命令用来显示IPv6动态域名缓存信息。
# 显示IPv6动态域名缓存信息。
<Sysname> display dns ipv6 dynamic-host
No.  Domain-name     IPv6 Address        TTL
1        aaa             3001::2         6
表1-1 display dns ipv6 dynamic-host命令显示信息描述表
No.
序列号
Domain-name
域名
IPv6 Address
域名对应的IPv6地址
TTL
域名缓存信息表项的生存时间,单位为秒
display ipv6 fib [ ipv6-address ]
ipv6-address:显示目的地址为指定IPv6地址的FIB转发信息表项。
【描述】
display ipv6 fib命令用来显示FIB转发信息表项。
如果不指定任何参数,则显示所有的FIB转发信息表项。
# 显示所有的FIB转发信息表项。
<Sysname> display ipv6 fib
FIB Table:
 Total number of Routes : 1
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
Destination: ::1                         PrefixLength    : 128
NextHop     :    ::1                         Flag            : HU
Label       :    NULL                            Tunnel ID   : 0
TimeStamp  : Date- 12/5/2004, Time- 9:15:18
Interface  : InLoopBack0
表1-2 display ipv6 fib命令显示信息描述表
FIB表中路由的总数
Destination
转发的目的地址
PrefixLength
转发的目的地址的前缀长度
NextHop
向目的地址转发报文的下一跳地址
Flag
路由的标志:
l      U:表示路由可用
l      G:表示网关路由
l      H:表示主机路由
l      B:表示黑洞路由
l      D:表示动态路由
l      S:表示静态路由
Label
标签
Tunnel ID
隧道ID
TimeStamp
FIB表项的生成时间
转发报文的出接口
display ipv6 host
【描述】
display ipv6 host命令用来显示静态域名解析表中所有主机名与IPv6地址的对应关系。
# 显示静态域名解析表中所有主机名与IPv6地址的对应关系。
<Sysname> display ipv6 host
Host                 Age           Flags           IPv6Address(es)
aaa                  0             static           20::1
bbb                  0             static           20::2
表1-3 display ipv6 host命令信息描述表
Host
主机名
Age
该表项的生存时间,静态配置的显示为0
Flags
主机名与IPv6地址映射的类型标志,静态解析显示为static
IPv6Address(es)
主机名对应的IPv6地址
display ipv6 interface [ interface-type interface-number | brief ]
interface-type interface-number:接口类型与接口编号。
brief:显示接口的IPv6摘要信息。
【描述】
display ipv6 interface命令用来显示可以配置IPv6地址的接口的IPv6信息。
当不指定接口类型和接口号时,表示显示所有可以配置IPv6地址的接口的IPv6信息。
# 查看VLAN 2接口上的IPv6信息。
<Sysname> display ipv6 interface vlan-interface 2
Vlan-interface2 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::2E0:FCFF:FE00:5503
  Global unicast address(es):
    3000::1, subnet is 3000::/64
  Joined group address(es):
    FF02::1:FF00:1
    FF02::1:FF00:5503
    FF02::2
    FF02::1
  MTU is 1500 bytes
表1-4 display ipv6 interface命令显示信息描述表
接口的物理状态
接口的链路层状态
IPv6 is enabled
接口的IPv6转发功能状态(该例中处于使能状态)
link-local address
接口上配置的链路本地地址
接口上配置的全球单播地址
接口加入的组播组地址
MTU
接口的最大传输单元
重复地址检测功能是否使能(该例中使能)及重复地址检测的次数
ND reachable time
保持邻居可达的时间
邻居请求消息重传时间间隔
主机采用无状态自动配置的方式获取IPv6地址
# 查看所有可以配置IPv6地址的接口的IPv6摘要信息。
<Sysname> display ipv6 interface brief
*down: administratively down
(s): spoofing
Interface                    Physical   Protocol IPv6 Address
LoopBack0                       up          up(s)    Unassigned
Vlan-interface1               up          up     2008::1
表1-5 display ipv6 interface brief命令显示信息描述表
*down
接口处于管理down状态,即采用shutdown命令关闭了该接口
(s)
接口的欺骗属性,即接口的链路协议状态显示是up的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立的
接口名称
Physical
接口的物理状态
Protocol
接口的链路协议状态
IPv6 Address
接口的IPv6地址(如果未配置则显示“Unassigned”)
display ipv6 neighbors { ipv6-address | all | dynamic | interface interface-type interface-number | static | vlan vlan-id } [ | { begin | exclude | include } text ]
ipv6-address:显示指定IPv6地址的邻居信息。
all:显示所有邻居的信息,包括动态获取的和静态配置的邻居信息。
dynamic:显示所有动态获取的邻居信息。
interface interface-type interface-number:显示指定接口的邻居信息。
static:显示所有静态配置的邻居信息。
vlan vlan-id:显示指定VLAN的邻居信息。vlan-id的取值范围为1~4094。
|:使用输出信息过滤功能。
begin:从第一个包含指定字符串的邻居信息项开始显示。
include:只显示那些包含指定字符串的邻居信息项。
exclude:只显示那些不包含指定字符串的邻居信息项。
text:字符串。
【描述】
display ipv6 neighbors命令用来显示邻居信息。
# 查看所有的邻居信息。
<Sysname> display ipv6 neighbors all
                Type: S-Static    D-Dynamic
IPv6 Address             Link-layer      VID Interface     State T Age
FE80::200:5EFF:FE32:B800 0000-5e32-b800  1   GE1/0/1           REACH S -
表1-6 display ipv6 neighbors命令显示信息描述表
IPv6 Address
IPv6地址
Link-layer
链路层地址(邻居地址的MAC地址)
VID
与邻居相连的接口所属的VLAN
与邻居相连的接口
邻居的状态
T
邻居信息的类型:
l      S:表示静态配置
l      D:表示动态获取
Age
静态项显示“–”,动态项显示上次可达以来经过的时间(单位为秒),如果始终处于陈旧状态则显示“#”(只适用于动态项)
display ipv6 neighbors { all | dynamic | interface interface-type interface-number | static | vlan vlan-id } count
all:显示所有邻居表项的总个数,包括动态获取的和静态配置的邻居信息。
dynamic:显示所有动态获取的邻居表项的总个数。
static:显示所有静态配置的邻居表项的总个数。
vlan vlan-id:显示指定VLAN的邻居表项的总个数。vlan-id的取值范围为1~4094。
count:邻居表项条数。
【描述】
display ipv6 neighbors count命令用来显示符合指定条件的邻居表项的总个数。
# 显示动态获取的邻居表项的总个数。
<Sysname> display ipv6 neighbors dynamic count
 Total dynamic entry(ies):  2
display ipv6 pathmtu { ipv6-address | all | dynamic | static }
ipv6-address:显示到达指定IPv6地址的PMTU信息。
all:显示所有PMTU信息。
dynamic:显示所有动态PMTU信息。
static:显示所有静态PMTU信息。
【描述】
display ipv6 pathmtu命令用来显示IPv6的PMTU信息。
# 显示所有PMTU信息。
<Sysname> display ipv6 pathmtu all
IPv6 Destination Address ZoneID  PathMTU     Age     Type
 fe80::12                    0       1300            40      Dynamic
 2222::3                 0       1280            --      Static
表1-7 display ipv6 pathmtu命令显示信息描述表
IPv6目的地址
ZoneID
地址区域,目前没有作用
PathMTU
对应IPv6地址的PMTU值
Age
PMTU的老化时间(单位为分钟),如果是静态PMTU项,则显示为“--”
PMTU的类型:
l      Dynamic:表示动态协商
l      Static:表示静态配置
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ]
socket-type:套接字类型,取值范围为1~3,其中1表示套接字类型为TCP,2表示套接字类型为UDP,3表示套接字类型为raw IP。
task-id:任务ID,取值范围为1~100。
socket-id:套接字ID,取值范围为0~3072。
【描述】
display ipv6 socket命令用来显示指定套接字的相关信息。
如果不指定参数,表示显示所有套接字的相关信息。
# 显示所有套接字的相关信息。
<Sysname> display ipv6 socket
SOCK_STREAM:
Task = VTYD(14), socketid = 4, Proto = 6,
LA = ::->22, FA = ::->0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_REUSEPORT SO_SENDVPNID,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(14), socketid = 3, Proto = 6,
LA = ::->23, FA = ::->0,
SOCK_DGRAM:
SOCK_RAW:
表1-8 display ipv6 socket命令显示信息描述表
SOCK_STREAM
套接口类型为TCP
SOCK_DGRAM
套接口类型为UDP
SOCK_RAW
套接口类型为raw IP
创建套接字的任务ID
socketid
内核为创建的套接字分配的套接字号
Proto
协议ID
LA
本端地址与本端端口号
FA
远端地址与远端端口号
sndbuf
发送缓冲区大小
rcvbuf
接收缓冲区大小
sb_cc
发送缓冲区发送的字节数
rb_cc
接收缓冲区接收的字节数
socket option
应用程序设置的套接字选项
socket state
套接字状态
【描述】
display ipv6 statistics命令用来显示IPv6报文及ICMPv6报文的统计信息。
# 显示IPv6报文及ICMPv6报文的统计信息。
<Sysname> display ipv6 statistics
  IPv6 Protocol:
    Sent packets:
      Total:      0
        Local sent out:          0            forwarded:         0
        raw packets:         0            discarded:         0
        routing failed:          0            fragments:         0
        fragments failed:        0
    Received packets:
      Total:      12
        local host:              0            hopcount exceeded: 0
        format error:            0            option error:          0
        protocol error:          0            fragments:         0
        reassembled:         0            reassembly failed: 0
        reassembly timeout:      0
  ICMPv6 protocol:
    Sent packets:
      Total:      0
        unreached:               0             too big:              0
        hopcount exceeded:       0             reassembly timeout:   0
        parameter problem:       0
        echo request:            0             echo replied:     0
        neighbor solicit:        0             neighbor advert:      0
        router solicit:          0             router advert:        0
        redirected:              0
      Send failed:
        ratelimited:         0             other errors:     0
    Received packets:
      Total:      0
        checksum error:          0             too short:            0
        bad code:                0
        parameter problem:       0             unknown error type:   0
        echoed:              0             echo replied:     0
        redirected:              0             router renumbering:   0
        unknown info type:       0
      Deliver failed:
        bad length:              0             ratelimited:          0
表1-9 display ipv6 statistics命令显示信息描述表
IPv6 Protocol:
IPv6报文统计信息
Sent packets:
 Total:      0
  fragments failed:     0
发送IPv6报文的统计信息,包括发送报文总数、本地发送报文数、转发报文数、使用raw socket发送的报文数、丢弃报文数、路由失败报文数、发送分片报文数、分片报文发送失败的个数
Received packets:
 Total:      0
接收IPv6报文的统计信息,包括接收报文总数、本地主机接收报文数、超出跳数范围的报文数、格式错误的报文数、选项错误的报文数、协议错误的报文数、接收的分片报文数、重组报文数、重组失败的报文数、重组超时的报文数
ICMPv6 protocol:
ICMPv6报文的统计信息
Sent packets:
 Total:      0
  router solicit:      0  router advert        0
  redirected:        0
 Send failed:
发送ICMPv6报文的统计信息,包括发送报文总数、目的不可达报文数、报文太大的报文数、超出跳数限制的报文数、分片重组超时报文数、参数错误报文数、回应请求报文数、回应响应报文数、邻居请求报文数、邻居通告报文数、路由器请求报文数、路由器通告报文数、重定向报文数、因速率超过限制而未发送的报文数、其他错误的报文数
Received packets:
 Total:      0
  bad code:          0
  redirected:        0  router renumbering  0
  Deliver failed:
接收ICMPv6报文的统计信息,包括接收报文总数、校验和错误的报文数、报文太小的报文数、错误代码的报文数、不可达报文数、报文太长的报文数、超出跳数限制的报文数、分片重组超时的报文数、参数错误报文数、未知错误报文数、回应请求报文数、回应响应报文数、邻居请求报文数、邻居通告报文数、路由器请求报文数、路由器通告报文数、重定向报文数、路由器重计数、未知信息报文数、长度错误的报文数、因速率超过限制而未接收的报文数
【描述】
display tcp ipv6 statistics命令用来显示TCP6连接的统计信息。
# 显示接收和发送报文的TCP6连接的统计信息。
<Sysname> display tcp ipv6 statistics
Received packets:
      Total: 0
      packets in sequence: 0 (0 bytes)
      window probe packets: 0, window update packets: 0
      checksum error: 0, offset error: 0, short error: 0
      duplicate packets: 0 (0 bytes), partially duplicate packets: 0 (0 bytes)
      out-of-order packets: 0 (0 bytes)
      packets with data after window: 0 (0 bytes)
      packets after close: 0
      ACK packets: 0 (0 bytes)
      duplicate ACK packets: 0, too much ACK packets: 0
Sent packets:
      Total: 0
      urgent packets: 0
      control packets: 0 (including 0 RST)
     data packets: 0 (0 bytes) data packets retransmitted: 0 (0 bytes)
     ACK only packets: 0 (0 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
表1-10 display tcp ipv6 statistics命令显示信息描述表
Received packets:
     Total: 0
接收报文统计信息,包括:接收报文总数、顺序接收报文数、窗口探测报文数、窗口大小更新的报文数、校验和错误的报文数、偏移量错误的报文数、总长度短于报文头中的设置值的报文数、重复的报文数、部分复制报文数、无序报文数、超出接收窗口的报文数、连接关闭的报文数、接收到的ACK报文数、接收到的重复ACK报文数、接收到的过多ACK报文数
Sent packets:
     Total: 0
     urgent packets: 0
发送报文的统计信息,包括:发送报文总数、含有紧急指示符的报文数、发送的控制报文数、发送的窗口探测报文数、发送的窗口更新报文数、发送的数据报文数、重发的数据报文数、单独ACK报文数
重传超时报文数
重传超时断开的连接数
Keepalive timeout
Keepalive超时数
Keepalive probe
Keepalive探测数
Keepalive响应超时而断开的连接数
发起的连接数
接受的连接数
建立的连接数
Closed connections
关闭的连接数
dropped
意外丢弃连接数(收到对端SYN之后)
initiated dropped
主动连接失败数(收到对端SYN之前)
【描述】
display tcp ipv6 status命令用来显示TCP6连接的状态信息。
# 显示TCP6连接的状态信息。
<Sysname> display tcp ipv6 status
TCP6CB       Local Address       Foreign Address      State
045d8074    ::->21                ::->0                  Listening
表1-11 display tcp ipv6 status命令显示信息描述表
TCP6CB
TCP6的控制块地址(十六进制)
Local Address
本端IPv6地址
Foreign Address
对端IPv6地址
TCP6连接状态,包括:Closed、Listening、Syn_Sent、Syn_Rcvd、Established、Close_Wait、Fin_Wait1、Closing、Last_Ack、Fin_Wait2及Time_Wait
【描述】
display udp ipv6 statistics命令用来显示UDP6的统计信息。
# 显示UDP6的统计信息。
<Sysname> display udp ipv6 statistics
Received packets:
      Total: 0
      checksum error: 0
      shorter than header: 0, data length larger than packet: 0
      unicast(no socket on port): 0
      broadcast/multicast(no socket on port): 0
      not delivered, input socket full: 0
      input packets missing pcb cache: 0
Sent packets:
      Total: 0
表1-12 display udp ipv6 statistics命令显示信息描述表
Total
接收/发送报文总数
checksum error
校验和出错的报文总数
shorter than header
报文长度小于报文头长度的UDP6报文总数
数据长度超过报文长度的报文总数
端口上接收的无套接字的单播报文总数
端口上接收的无套接字的广播/组播报文数
接收缓冲区满后,未处理报文数
input packet missing pcb cache
没有匹配PCB缓存的报文数
dns server ipv6 ipv6-address [ interface-type interface-number ]
undo dns server ipv6 ipv6-address [ interface-type interface-number ]
ipv6-address:DNS服务器的IPv6地址。
interface-type interface-number:指定DNS服务器的IPv6地址为链路本地地址时,对应的出接口的接口类型与接口编号。
【描述】
dns server ipv6命令用来配置DNS服务器的IPv6地址。undo dns server ipv6命令用来删除已配置的DNS服务器。
缺省情况下,没有配置DNS服务器。
# 配置DNS服务器的IPv6地址为2002::1。
[Sysname] dns server ipv6 2002::1
1.1.14  ipv6
ipv6
undo ipv6
【描述】
ipv6命令用来使能IPv6报文转发功能。undo ipv6命令用来关闭IPv6报文转发功能。
缺省情况下,IPv6报文转发功能处于关闭状态。
# 使能对IPv6报文的转发功能。
[Sysname] ipv6
1.1.15  ipv6 address
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ]
VALN接口视图/LoopBack接口视图
ipv6-address:IPv6地址。
prefix-length:前缀长度,取值范围为1~128。
【描述】
ipv6 address命令用来手工配置接口的IPv6站点本地地址或全球单播地址。undo ipv6 address命令用来删除手工配置的接口地址。
缺省情况下,接口上没有配置站点本地地址和全球单播地址。
l              一个接口上全球单播地址和站点本地地址可以配置的总数最多为5个。
l              在LoopBack接口视图下配置IPv6站点本地地址或全球单播地址时,只能配置128位的前缀长度。
l              undo ipv6 address命令不带参数则删除该接口的所有IPv6地址,但自动配置的链路本地地址除外。
# 指定VLAN接口1的IPv6全球单播地地址为2001::1/64。
[Sysname-Vlan-interface1] ipv6 address 2001::1/64
undo ipv6 address auto link-local
【描述】
ipv6 address auto link-local命令用来配置系统自动为接口生成链路本地地址。undo ipv6 address auto link-local命令用来删除接口自动生成的链路本地地址。
缺省情况下,当接口配置了IPv6站点本地地址或全球单播地址后,会自动生成链路本地地址。
# 配置VLAN接口1自动生成链路本地地址。
[Sysname-Vlan-interface1] ipv6 address auto link-local
ipv6 address ipv6-address/prefix-length eui-64
undo ipv6 address ipv6-address/prefix-length eui-64
ipv6-address/prefix-length:IPv6地址/前缀长度,共同指定采用EUI-64格式形成的IPv6地址的前缀。
【描述】
ipv6 address eui-64命令用来给接口配置EUI-64格式的IPv6站点本地地址或全球单播地址。undo ipv6 address eui-64命令用来删除接口上已配置的EUI-64格式的IPv6站点本地地址或全球单播地址。
缺省情况下,接口上没有配置EUI-64格式的IPv6站点本地地址和全球单播地址。
l              在VLAN接口视图下配置EUI-64格式的IPv6站点本地地址和全球单播地址时,前缀长度取值不能大于64。
l              在LoopBack接口视图下配置EUI-64格式的IPv6站点本地地址和全球单播地址时,只能配置128位的前缀长度。
# 配置VLAN接口1采用EUI-64格式形成IPv6地址。
[Sysname-Vlan-interface1] ipv6 address 2001::1/64 eui-64
undo ipv6 address ipv6-address link-local
ipv6-address:IPv6链路本地地址,地址前面10位必须为1111111010(二进制标识),即地址最前面的一组十六进制数为FE80~FEBF。
【描述】
ipv6 address link-local命令用来手动配置指定接口的链路本地地址。undo ipv6 address link-local命令用来删除接口上手动配置的链路本地地址。
# 配置VLAN接口1的链路本地地址。
[Sysname-Vlan-interface1] ipv6 address fe80::1 link-local
1.1.19  ipv6 host
ipv6 host hostname ipv6-address
undo ipv6 host hostname [ ipv6-address ]
hostname:主机名,为1~20个字符的字符串,字符串中可以包含字母、数字、“_”、“-”或“.”,且必须至少包含一个字母。
【描述】
ipv6 host命令用来配置主机名与IPv6地址的对应关系。undo ipv6 host命令用来取消已配置的主机名与IPv6地址的对应关系。
每个主机名最多可对应8个IPv6地址。
# 配置主机名为aaa,对应的IPv6地址为2001::1。
[Sysname] ipv6 host aaa 2001::1
ipv6 icmp-error { bucket bucket-size | ratelimit interval }*
undo ipv6 icmp-error
bucket-size:令牌桶中容纳的令牌数,取值范围为1~200个。
interval:令牌桶的刷新周期,取值范围为0~2147483647,单位为毫秒。
【描述】
ipv6 icmp-error命令用来配置ICMPv6差错报文发送的令牌桶容量和刷新周期。undo ipv6 icmp-error命令用来恢复缺省情况。
缺省情况下,令牌桶容量为10,令牌桶的刷新周期为100毫秒,即每一个刷新周期内最多可以发送10个ICMPv6差错报文。
# 配置令牌桶容量为50个,令牌桶的刷新周期为100毫秒,即100毫秒中最多可以发送50个ICMPv6差错报文。
[Sysname] ipv6 icmp-error bucket 50 ratelimit 100
undo ipv6 nd autoconfig managed-address-flag
VLAN接口视图
【描述】
ipv6 nd autoconfig managed-address-flag命令用来配置被管理地址的配置标志位为1,即主机通过有状态自动配置(例如DHCP服务器)获取IPv6地址。undo ipv6 nd autoconfig managed-address-flag命令用来恢复该标志位为缺省值0,即主机通过无状态自动配置获取IPv6地址。
缺省情况下,被管理地址标志位为0。
# 配置主机通过状态自动配置获取IPv6地址。
[Sysname-Vlan-interface1] ipv6 nd autoconfig managed-address-flag
undo ipv6 nd autoconfig other-flag
VLAN接口视图
【描述】
ipv6 nd autoconfig other-flag命令用来配置其他信息配置标志位为1,即主机通过有状态自动配置(例如DHCP服务器)获取除IPv6地址外的其他信息。undo ipv6 nd autoconfig other-flag命令用来恢复该标志位为缺省值0,即主机通过无状态自动配置获取其他信息。
缺省情况下,其他信息配置标志位为0。
# 配置主机通过无状态自动配置来获取除IPv6地址外的其他信息。
[Sysname-Vlan-interface1] undo ipv6 nd autoconfig other-flag
ipv6 nd dad attempts value
undo ipv6 nd dad attempts
VLAN接口视图
value:进行重复地址检测时发送邻居请求消息的次数,取值范围为0~600。当设置为0时,表示禁止重复地址检测。
【描述】
ipv6 nd dad attempts命令用来配置进行重复地址检测时发送邻居请求消息的次数。undo ipv6 nd dad attempts命令用来恢复缺省情况。
缺省情况下,进行重复地址检测时发送邻居请求消息的次数为1。
# 配置VLAN接口1进行重复地址检测时发送邻居请求消息的次数为20次。
[Sysname-Vlan-interface1] ipv6 nd dad attempts 20
ipv6 nd hop-limit value
undo ipv6 nd hop-limit
value:跳数值,取值范围为0~255。当指定为0时,设备发布的RA消息中Hop Limit字段的值为0,即不对主机进行指定。
【描述】
ipv6 nd hop-limit命令用来配置设备发布的跳数限制。undo ipv6 nd hop-limit命令用来恢复缺省情况。
缺省情况下,设备发布的跳数限制为64。
# 配置设备发布的跳数限制为100跳。
[Sysname] ipv6 nd hop-limit 100
undo ipv6 nd ns retrans-timer
VLAN接口视图
value:NS消息重传时间间隔,取值范围为1000~3600000,单位为毫秒。
【描述】
ipv6 nd ns retrans-timer命令用来配置邻居请求消息的重传时间间隔。该时间间隔既用于本接口发送NS消息的时间间隔,同时也作为本接口发布的RA消息中Retrans Timer字段的值。undo ipv6 nd ns retrans-timer命令用来恢复缺省情况。
缺省情况下,接口发送NS消息的时间间隔为1000毫秒,接口发布的RA消息中Retrans Timer字段的值为0。
# 配置VLAN接口1发送NS消息的时间间隔为10000毫秒。
[Sysname-Vlan-interface1] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time value
undo ipv6 nd nud reachable-time
VLAN接口视图
value:保持邻居可达状态的时间,取值范围为1~3600000,单位为毫秒。
【描述】
ipv6 nd nud reachable-time命令用来配置接口保持邻居可达状态的时间。该时间既用于本接口保持邻居可达状态的时间,同时也作为本接口发布的RA消息中Reachable Timer字段的值。undo ipv6 nd nud reachable-time命令用来恢复接口保持邻居可达状态的时间为缺省值,同时指定该接口发布的RA消息中Reachable Timer字段的值为0,即不对主机进行指定。
缺省情况下,接口保持邻居可达状态的时间为30000毫秒,接口发布的RA消息中Reachable Timer字段的值为0。
# 配置VLAN接口1上保持邻居可达状态的时间为10000毫秒。
[Sysname-Vlan-interface1] ipv6 nd nud reachable-time 10000
ipv6 nd ra halt
undo ipv6 nd ra halt
VLAN接口视图
【描述】
ipv6 nd ra halt命令用来抑制RA消息的发布。undo ipv6 nd ra halt命令用来恢复缺省情况。
缺省情况下,抑制发布RA消息。
# 抑制在VLAN接口1上发布RA消息。
[Sysname-Vlan-interface1] ipv6 nd ra halt
ipv6 nd ra interval max-interval-value min-interval-value
undo ipv6 nd ra interval
VLAN接口视图
max-interval-value:指定RA消息发布的最大时间间隔,取值范围是4~1800,单位为秒。
min-interval-value:指定RA消息发布的最小时间间隔,取值范围是3~1350,单位为秒。
【描述】
ipv6 nd ra interval命令用来配置RA消息发布的最大时间间隔和最小时间间隔。设备在最大时间间隔与最小时间间隔之间随机选取一个值作为周期性发布RA消息的时间间隔。undo ipv6 nd ra interval命令用来恢复缺省情况。
缺省情况下,RA消息发布的最大时间间隔为600秒,最小时间间隔为200秒。
l              配置的最小时间间隔应该小于等于最大时间间隔的0.75倍;
l              RA消息发布的最大实际间隔应该小于或等于RA消息中路由器的生存时间。
# 配置设备周期性发布RA消息的最大时间间隔为1000秒,最小时间间隔为700秒。
[Sysname-Vlan-interface1] ipv6 nd ra interval 1000 700
ipv6 nd ra prefix { ipv6-address prefix-length | ipv6-address/prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig | off-link ]*
undo ipv6 nd ra prefix ipv6-prefix
VLAN接口视图
ipv6-address:IPv6地址或IPv6前缀。
ipv6-prefix:IPv6地址前缀。
valid-lifetime:前缀的有效存活时间,取值范围为0~4294967295,单位为秒。
preferred-lifetime:前缀用于无状态地址配置的优选项的存活时间,取值范围为0~4294967295,单位为秒。
no-autoconfig:指定前缀不用于无状态地址配置。如果不选择该参数,则指定前缀用于无状态地址配置。
off-link:指定前缀不是该链路上直连可达的。如果不选择该参数,则表示指定前缀是直连可达的。
【描述】
ipv6 nd ra prefix命令用来配置RA消息中的前缀信息。undo ipv6 nd ra prefix命令用来取消RA消息中前缀信息的配置。
缺省情况下,没有配置RA消息中的前缀信息,此时将使用发送RA消息的接口IPv6地址作为RA中的前缀信息。
# 配置VLAN接口1上RA消息中的前缀信息。
[Sysname-Vlan-interface1] ipv6 nd ra prefix 2001:10::100/64 100 10
ipv6 nd ra router-lifetime value
undo ipv6 nd ra router-lifetime
VLAN接口视图
value:RA消息中路由器的生存时间,取值范围为0~9000,单位为秒。当配置为0时,表示本设备不作为默认路由器。
【描述】
ipv6 nd ra router-lifetime命令用来配置RA消息中路由器的生存时间。undo ipv6 nd ra router-lifetime命令用来恢复缺省情况。
缺省情况下,RA消息中路由器的生存时间为1800秒。
需要注意的是,RA消息中路由器的生存时间应该大于或等于RA消息的发布时间间隔。
# 配置VLAN接口1上RA消息中路由器的生存时间为1000秒。
[Sysname-Vlan-interface1] ipv6 nd ra router-lifetime 1000
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
undo ipv6 neighbor ipv6-address interface-type interface-number
ipv6-address:静态邻居表项中的IPv6地址。
mac-address:静态邻居表项中的链路层地址(48位,格式为H-H-H)。
vlan-id:静态邻居表项所对应的VLAN ID,取值范围为1~4094。
port-type port-number:静态邻居表项所对应的二层端口类型和端口号。
interface-type interface-number:静态邻居表项所对应的三层接口类型和接口号。
【描述】
ipv6 neighbor命令用来配置静态邻居表项。undo ipv6 neighbor命令用来删除静态邻居表项。
需要注意的是,如果使用vlan-id port-type port-number参数进行配置,需保证VLAN所对应的VLAN接口已存在。在配置后,设备会将VLAN所对应的VLAN接口与IPv6地址相对应来唯一标识一个静态邻居表项。在删除静态邻居表项时,只需要指定VLAN对应的VLAN接口即可。
# 配置VLAN1的以太网端口GigabitEthernet1/0/1对应的静态邻居表项。
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 1 GigabitEthernet 1/0/1
ipv6 neighbors max-learning-num number
undo ipv6 neighbors max-learning-num
VLAN接口视图
number:接口上允许动态学习的邻居的最大个数,取值范围1~1024。
【描述】
ipv6 neighbors max-learning-num命令用来配置指定接口上允许动态学习的邻居的最大个数。undo ipv6 neighbors max-learning-num命令用来恢复缺省情况。
缺省情况下,接口上允许动态学习的邻居的最大个数为1024。
# 配置VLAN接口1上允许动态学习的邻居的最大个数为10个。
[Sysname-Vlan-interface1] ipv6 neighbors max-learning-num 10
1.1.33  ipv6 pathmtu
ipv6 pathmtu ipv6-address [ value ]
undo ipv6 pathmtu ipv6-address
ipv6-address:指定的IPv6地址。
value:指定IPv6地址对应的PMTU值,单位为字节。取值范围1280~10000,缺省值为1500。如果不指定该参数,则表示采用缺省值。
【描述】
ipv6 pathmtu命令用来配置指定IPv6地址对应的静态PMTU。undo ipv6 pathmtu 命令用来删除指定IPv6地址的PMTU配置。
缺省情况下,没有配置静态PMTU值。
# 配置指定IPv6地址对应的静态PMTU值。
[Sysname] ipv6 pathmtu fe80::12 1300
ipv6 pathmtu age age-time
undo ipv6 pathmtu age
age-time:PMTU老化时间,取值范围为10~100,单位为分钟。
【描述】
ipv6 pathmtu age命令用来配置动态PMTU的老化时间。undo ipv6 pathmtu age命令用来恢复缺省情况。
缺省情况下,动态PMTU的老化时间为10分钟。
需要注意的是,该配置对静态PMTU不起作用。
相关配置可参考命令display ipv6 pathmtu
# 配置动态PMTU的老化时间为40分钟。
[Sysname] ipv6 pathmtu age 40
【描述】
reset dns ipv6 dynamic-host命令用来清除IPv6动态域名缓存信息。
# 清除IPv6动态域名缓存信息。
<Sysname> reset dns ipv6 dynamic-host
reset ipv6 neighbors { all | dynamic | interface interface-type interface-number | static }
all:清除所有接口上的静态与动态邻居信息。
dynamic:清除所有接口上的动态邻居信息。
interface interface-type interface-number:清除指定接口上的所有邻居信息。
static:清除所有接口上的静态邻居信息。
【描述】
reset ipv6 neighbors命令用来清除IPv6邻居信息。
# 清除所有接口上的所有邻居信息。
<Sysname> reset ipv6 neighbors all
reset ipv6 pathmtu { all | static | dynamic }
all:清除所有PMTU信息。
static:清除所有静态PMTU信息。
dynamic:清除所有动态PMTU信息。
【描述】
reset ipv6 pathmtu命令用来清除PMTU信息。
# 清除所有PMTU信息。
<Sysname> reset ipv6 pathmtu all
【描述】
reset ipv6 statistics命令用来清除IPv6报文统计信息。
# 清除IPv6报文统计信息。
<Sysname> reset ipv6 statistics
【描述】
reset tcp ipv6 statistics命令用来清除所有TCP6连接的统计信息。
# 清除所有TCP6连接的统计信息。
<Sysname> reset tcp ipv6 statistics
【描述】
reset udp ipv6 statistics命令用来清除所有UDP6的统计信息。
# 清除所有UDP6的统计信息。
<Sysname> reset udp ipv6 statistics
tcp ipv6 timer fin-timeout wait-time
undo tcp ipv6 timer fin-timeout
wait-time:TCP6的finwait定时器值,取值范围为76~3600,单位为秒。
【描述】
tcp ipv6 timer fin-timeout命令用来配置TCP6的finwait定时器值。undo tcp ipv6 timer fin-timeout命令用来恢复缺省情况。
缺省情况下,TCP6的finwait定时器值为675秒。
# 配置TCP6的finwait定时器值为800秒。
[Sysname] tcp ipv6 timer fin-timeout 800
tcp ipv6 timer syn-timeout wait-time
undo tcp ipv6 timer syn-timeout
wait-time:TCP6的synwait定时器值,取值范围为2~600,单位为秒。
【描述】
tcp ipv6 timer syn-timeout命令用来配置TCP6的synwait定时器值。undo tcp ipv6 timer syn-timeout命令用来恢复缺省情况。
缺省情况下,TCP6的synwait定时器值为75秒。
# 配置TCP6的synwait定时器值为100秒。
[Sysname] tcp ipv6 timer syn-timeout 100
tcp ipv6 window size
undo tcp ipv6 window
【描述】
tcp ipv6 window命令用来配置TCP6的接收和发送缓冲区大小。undo tcp ipv6 window命令用来恢复缺省情况。
缺省情况下,TCP6的接收和发送缓冲区大小为8KB。
# 配置TCP6的接收和发送缓冲区大小为4KB。
[Sysname] tcp ipv6 window 4
第2章  IPv6应用配置命令
2.1  IPv6应用配置命令
2.1.1  ftp ipv6
ftp ipv6 [ remote-system [ port-number ] [ -a source-ipv6-address ] [ -i interface-type interface-number ] ]
remote-system:目的设备的IPv6地址或主机名(主机名为1~46个字符的字符串)。
port-number:远端设备提供FTP服务的TCP端口号,取值范围为0~65535,缺省值为21。
-a source-ipv6-address:源IPv6地址。需要注意的是,此处所指定的源地址必须是设备上已配置的IPv6地址。
-i interface-type interface-number:出接口的接口类型与编号。当目的地址是链路本地地址时需要指定此参数。
【描述】
ftp ipv6命令用来以IPv6寻址方式与远程FTP服务器建立控制连接,并进入FTP客户端视图。
l              如果不指定任何参数,则只进入FTP客户端视图,不登录FTP服务器。
l              如果指定参数,系统会提示用户输入登录FTP服务器的用户名和密码。如果用户名和密码正确,则登录成功,并进入FTP客户端视图;否则,登录失败。
# 登录到IPv6地址为3000::200的远程FTP服务器。
<Sysname> ftp ipv6 3000::200
Trying 3000::200 ...
Press CTRL+K to abort
Connected to 3000::200.
220 Welcome!
User(3000::200:(none)): MY_NAME
331 Please specify the password.
Password:
230 Login successful.
[ftp]
2.1.2  open ipv6
open ipv6 remote-system [ port-number ] [ -a source-ipv6-address ] [ -i interface-type interface-number ]
FTP客户端视图
-i interface-type interface-number:出接口的接口类型与接口编号。当目的地址是链路本地地址时,需要指定此参数。
【描述】
open ipv6命令用来在FTP客户端视图下登录FTP服务器。
登录时,系统会提示用户输入登录用户名和密码。如果用户名和密码正确,则登录成功;否则,登录失败。
# 在FTP客户端视图下登录FTP服务器(IPv6地址为3000::200)。
<Sysname> ftp ipv6
[ftp] open ipv6 3000::200
220 Welcome!
Password:
[ftp]
2.1.3  ping ipv6
ping ipv6 [ -a source-ipv6-address | -c count | -m interval | -s packet-size | -t timeout ]* remote-system [ -i interface-type interface-number ]
-a source-ipv6-address:指定源IPv6地址。
-c count:发送的ICMPv6回显请求报文的数目,取值范围为1~4294967295,缺省值为5。
-m interval:发送ICMPv6回显请求报文的时间间隔,取值范围为1~65535,单位为毫秒,缺省值为200毫秒。
l              如果在timeout时间内收到目的主机的响应报文,则下次ICMP回显请求报文的发送时间间隔为报文的实际响应时间与interval之和;
l              如果在timeout时间内没有收到目的主机的响应报文,则下次ICMP回显请求报文的发送时间间隔为timeoutinterval之和。
-s packet-size:发送的ICMPv6回显请求报文的长度,取值范围为20~8100,单位为字节,缺省值为56字节。
-t timeout:接收ICMPv6响应的超时时间,单位为毫秒,取值范围是0~65535,缺省值为2000毫秒。
-i interface-type interface-number:出接口的接口类型与接口编号。当目的地址是链路本地地址或组播地址时需要指定此参数。
【描述】
ping ipv6命令用来检验目的地是否可达,并输出相应的统计信息。
# 检查IPv6地址为2001::1的设备是否可达。
<Sysname> ping ipv6 2001::1
  PING 2001::1 : 56  data bytes, press CTRL_C to break
    Reply from 2001::1
    bytes=56 Sequence=1 hop limit=64  time = 20 ms
    Reply from 2001::1
    bytes=56 Sequence=2 hop limit=64  time = 0 ms
    Reply from 2001::1
    bytes=56 Sequence=3 hop limit=64  time = 0 ms
    Reply from 2001::1
    bytes=56 Sequence=4 hop limit=64  time = 0 ms
    Reply from 2001::1
    bytes=56 Sequence=5 hop limit=64  time = 0 ms
  --- 2001::1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 0/4/20 ms
该显示信息中的“hop limit”字段与IPv4 ping命令显示信息中的“ttl”字段含义相同,均表示ICMP回显请求报文中的TTL值。
2.1.4  telnet ipv6
telnet ipv6 remote-system [ -i interface-type interface-number ] [ port-number ]
-i interface-type interface-number:出接口的接口类型与接口编号。当目的地址是链路本地地址时需要指定此参数。
port-number:Telnet服务器连接的端口号,取值范围为0~65535,缺省值为23。
【描述】
telnet ipv6命令用来从当前设备登录到其它设备进行远程管理。用户可以键入<Ctrl+K>来中断本次Telnet登录。
# 连接远端的Telnet服务器,其IPv6地址为3001::1。
<Sysname> telnet ipv6 3001::1
Trying 3001::1 ...
Connected to 3001::1 ...
* Copyright(c) 2004-2006 Hangzhou H3C Technologies Co., Ltd.   *
* Without the owner's prior written consent,                             *
* no decompiling or reverse-engineering shall be allowed.             *
<Sysname>
2.1.5  tftp ipv6
tftp ipv6 remote-system [ -i interface-type interface-number ] { get | put } source-filename [ destination-filename ]
-i interface-type interface-number:出接口的接口类型与接口编号。当TFTP服务器的地址是链路本地地址时需要指定此参数。
get:执行下载文件操作。
put:执行上传文件操作。
source-filename:源文件的名称,为1~135个字符的字符串。
destination-filename:目的文件的名称,为1~135个字符的字符串。如果不指定该参数,则目的文件的名称与源文件的名称相同。
【描述】
tftp ipv6命令用来执行下列操作:
l              下载文件操作:将TFTP服务器上的指定源文件下载到本地。
l              上传文件操作:将本地的指定源文件上传到TFTP服务器。
# 从TFTP服务器下载文件。
<Sysname> tftp ipv6 fe80::250:daff:fe91:e058 -i GigabitEthernet 1/0/1 get filetoget
  File will be transferred in binary mode
  Downloading file from remote tftp server, please wait....
  TFTP:       13 bytes received in 0 second(s)
  File downloaded successfully.
tftp-server ipv6 acl acl-number
undo tftp-server ipv6 acl
acl-number:IPv6的ACL号,取值范围是2000~2999。
【描述】
tftp-server ipv6 acl命令用来将已配置的ACL与TFTP应用相关联。用户利用IPv6 ACL中配置的规则可以允许或禁止对网络中特定TFTP服务器的使用。undo tftp-server ipv6 acl命令用来取消ACL与TFTP应用的关联。
缺省情况下,没有ACL与TFTP应用关联。
# 配置ACL2000与TFTP应用相关联。
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source 2030:5060::9050/64
[Sysname-acl6-basic-2000] quit
[Sysname] tftp-server ipv6 acl 2000
2.1.7  tracert ipv6
tracert ipv6 [ -f first-ttl | -m max-ttl | -p port | -q packet-num | -w timeout ]* remote-system
-f first-ttl:指定一个初始TTL,即第一个报文所允许的跳数。取值范围为1~255,且小于最大TTL,缺省值为1。
-m max-ttl:指定一个最大TTL,即一个报文所允许的最大跳数。取值范围为1~255,且大于初始TTL,缺省值为30。
-p port:指明目的设备的UDP端口号,取值范围为1~65535,缺省值为33434。用户一般不需要更改此选项。
-q packet-num:指明每次发送的探测报文个数,取值范围为1~65535,缺省值为3。
-w timeout:等待探测报文响应的超时时间,取值范围为1~65535,单位为毫秒,缺省值为5000毫秒。
remote-system:目的设备的IPv6地址或主机名(主机名是长度为1~46个字符的字符串)。
【描述】
tracert ipv6命令用来查看IPv6报文从当前设备传到目的设备所经过的路径。
# 查看报文从当前设备到目的设备(IPv6地址为3002::1)所经过的路径。
<Sysname> tracert ipv6 3002::1
 traceroute to 3002::1  30 hops max,60 bytes packet, press CTRL_C to break
 1 3003::1 30 ms  0 ms  0 ms
 2 3002::1 10 ms 10 ms 0 ms
