H3C S5500-SI系列以太网交换机 命令手册-RELEASE 1205(V1.04)
09-IP地址-IP性能命令
本章节下载  (252.19 KB)
09-IP地址-IP性能命令
  录
第1章 IP地址配置命令... 1-1
1.1 IP地址配置命令.. 1-1
1.1.1 display ip interface. 1-1
1.1.2 display ip interface brief 1-3
1.1.3 ip address. 1-4
第2章 IP性能配置命令... 2-1
2.1 IP性能配置命令.. 2-1
2.1.1 display fib. 2-1
2.1.2 display fib ip-address. 2-3
2.1.3 display fib statistics. 2-4
2.1.4 display icmp statistics. 2-5
2.1.5 display ip socket 2-6
2.1.6 display ip statistics. 2-9
2.1.7 display tcp statistics. 2-10
2.1.8 display tcp status. 2-13
2.1.9 display udp statistics. 2-14
2.1.10 ip forward-broadcast (系统视图).. 2-15
2.1.11 ip forward-broadcast (VLAN接口视图).. 2-16
2.1.12 ip redirects enable. 2-16
2.1.13 ip ttl-expires enable. 2-17
2.1.14 ip unreachables enable. 2-17
2.1.15 reset ip statistics. 2-18
2.1.16 reset tcp statistics. 2-19
2.1.17 reset udp statistics. 2-19
2.1.18 tcp timer fin-timeout 2-19
2.1.19 tcp timer syn-timeout 2-20
2.1.20 tcp window. 2-21
第1章  IP地址配置命令
1.1  IP地址配置命令
display ip interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型及接口号。
【描述】
display ip interface命令用来显示三层接口的相关信息。
如果不指定参数,则显示所有三层接口的相关信息。
# 显示VLAN接口1的相关信息。
<Sysname> display ip interface Vlan-interface 1
Vlan-interface1 current state :UP
Line protocol current state :UP
Internet Address is 192.168.0.52/16 Primary
Broadcast address : 192.168.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 15223, bytes : 802714, multicasts : 0
output packets : 14218, bytes : 744254, multicasts : 0
ARP packet input number:      665839
  Request packet:             665744
  Reply packet:                   95
  Unknown packet:                  0
TTL invalid packet number:         0
ICMP packet input number:          3
  Echo reply:                      0
  Unreachable:                     3
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
表1-1 display ip interface命令显示信息描述表
current state
接口当前的物理状态
链路层协议当前状态
Internet Address
接口的IP地址,如地址后有Primary,表示是主IP地址;如地址后有Sub,表示是从IP地址
Broadcast address
接口所在网段的广播地址
接口的最大传输单元
接口上接收和发送的单播报文数、字节数以及组播报文数
     Reply packet:                             95
     Unknown packet:                         0
接口上收到的ARP报文总数,包括ARP请求报文,ARP应答报文和未知类型报文
接口上收到的TTL无效的报文个数
  Echo reply:                                 0
  Unreachable:                              3
  Source quench:                          0
  Routing redirect:                         0
  Echo request:                             0
  Router advert:                            0
  Router solicit:                             0
  Time exceed:                              0
  IP header bad:                            0
  Timestamp reply:                       0
  Netmask request:                       0
  Netmask reply:                           0
  Unknown type:                           0
接口上收到的ICMP报文的总数,包括如下报文:
Echo应答报文、不可达报文、源站抑制报文、路由重定向报文、Echo请求报文、路由广播报文、路由请求报文、时间超期报文、IP报文头错误报文、时间戳请求报文、时间戳响应报文、信息请求报文、信息响应报文、掩码请求报文、掩码响应报文、未知类型报文
display ip interface brief [ interface-type interface-number ]
【描述】
display ip interface brief用来显示三层接口的IP基本配置信息。
如果不指定接口,则显示所有三层接口的IP基本配置信息。
相关配置可参考命令display ip interface
# 显示VLAN接口1的基本配置信息。
<Sysname> display ip interface brief Vlan-interface 1
*down: administratively down
(s): spoofing
Interface                             Physical   Protocol   IP Address
Vlan-interface1                         up         up       192.168.0.52
表1-2 display ip interface brief命令显示信息描述表
*down
接口处于管理down状态,即采用shutdown命令关闭了该接口
(s)
接口的欺骗属性,即接口的链路协议状态显示是up的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立的
接口的名称
Physical
接口的物理状态
Protocol
接口的链路层协议状态
IP Address
接口的IP地址(如果未配置则显示“unassigned”)
1.1.3  ip address
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
ip-address:接口的IP地址,为点分十进制格式。
mask:接口IP地址相应的子网掩码,为点分十进制格式。
mask-length:子网掩码长度,即掩码中连续“1”的个数,取值范围为0~32。
sub:表示该地址为接口的从IP地址。
【描述】
ip address命令用来配置接口的IP地址。undo ip address命令用来删除接口的IP地址。
缺省情况下,没有为接口配置IP地址。
主从地址的配置关系为:
l              当配置主IP地址时,如果接口上已经有主IP地址,则新配置的地址将覆盖原有的主IP地址,成为新的主IP地址。
l              主、从IP地址可以是同一网段。
l              在删除主IP地址前必须先删除对应的所有从IP地址。
l              undo ip address命令中不指定任何参数表示删除该接口的所有IP地址。
l              undo ip address ip-address { mask | mask-length }表示删除主IP地址。
l              undo ip address ip-address { mask | mask-length } sub表示删除指定的从IP地址。
l              当接口被配置为通过BOOTP、DHCP动态获取IP地址,则不能再给该接口配置从IP地址。
&  说明:
S5500-SI系列以太网交换机支持为VLAN接口和Loopback接口配置IP地址,在Loopback接口上只能配置32位的子网掩码。
# 指定VLAN接口1的主IP地址为129.12.0.1,从IP地址为202.38.160.1,子网掩码都为255.255.255.0。
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface1] ip address 202.38.160.1 255.255.255.0 sub
第2章  IP性能配置命令
2.1  IP性能配置命令
2.1.1  display fib
display fib [ | { begin | include | exclude } text | acl acl-number | ip-prefix ip-prefix-name ]
| { begin | include | exclude } text:根据正则表达式显示缓冲区中与指定字符串相关的FIB信息。
l              begin表示从第一个包含指定字符串text的FIB表项开始显示。
l              include表示只显示那些包含指定字符串text的FIB表项。
l              exclude表示只显示那些不包含指定字符串text的FIB表项。
l              text为字符串。
acl acl-number:显示通过指定访问控制列表过滤的FIB信息,acl-number取值范围为2000~2999。
ip-prefix ip-prefix-name:显示通过指定前缀列表过滤的FIB信息,ip-prefix-name为1~19个字符的字符串。
【描述】
display fib命令用来显示FIB转发信息。
如果不选择参数,表示显示所有的FIB转发信息。
# 显示所有的FIB转发信息。
<Sysname> display fib
FIB Table:
Total number of Routes : 2
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Reject   L:Generated by ARP or ESIS
Destination/Mask Nexthop     Flag    TimeStamp      Interface
127.0.0.0/8      127.0.0.1   U   t[1141138116]  InLoop0
127.0.0.1/32     127.0.0.1   HU  t[1141138116]  InLoop0
表2-1 display fib命令显示信息描述表
FIB表中路由的总数
Destination/Mask
目的地址/掩码长度
Nexthop
转发的下一跳地址
Flag
路由的标志:
l      U:表示路由可用
l      G:表示网关路由
l      H:表示主机路由
l      B:表示黑洞路由
l      D:表示动态路由
l      S:表示静态路由
l      R:表示是被拒绝的路由,不可用
l      L:表示是由ARP或ESIS生成的路由
TimeStamp
时间戳
转发接口
# 显示通过访问控制列表2000过滤的FIB转发信息。
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.2.0.0 0.0.255.255
[Sysname-acl-basic-2000] display fib acl 2000
Route entry matched by access-list 2000:
Summary counts: 2
Flag:
# 显示从包含字符串“127”那一行开始的所有行:
<Sysname> display fib | begin 127
Flag:
# 显示通过abc0前缀列表过滤的FIB转发信息。
<Sysname> display fib ip-prefix abc0
Route Entry matched by prefix-list abc0:
Summary count: 2
Flag:
display fib ip-address1 [ { mask1 | mask-length1 } [ ip-address2 { mask2 | mask-length2 } | longer ] | longer ]
ip-address1ip-address2:目的IP地址,点分十进制格式。ip-address1ip-address2共同确定一个地址范围,显示该地址范围内的FIB表项。
mask1mask2:IP地址掩码。
mask-length1、mask-length2:IP地址掩码长度,即掩码中连续“1”的个数。
longer:显示与指定地址/掩码对匹配的FIB表项。如果不输入掩码,则显示与自然网段的目的地址匹配的FIB表项。
【描述】
display fib ip-address命令用来显示与指定目的IP地址匹配的FIB表项。输出信息的每一行代表一条FIB表项。
# 显示目的地址与10.1.0.0在自然掩码范围内匹配的FIB项。
<Sysname> display fib 10.1.0.0 longer
  Route Entry Count: 2
 Flag:
10.0.0.0/8       10.1.1.1        U   t[1141140133]  Vlan1
10.1.1.1/32      127.0.0.1   HU  t[1141140133]  InLoop0
以上显示信息的解释请参见表2-1
【描述】
display fib statistics命令用来显示FIB表项的统计信息。
# 显示FIB表项的统计信息。
<Sysname> display fib statistics
Route Entry Count          : 2
表2-2 display fib statistics命令显示信息描述表
Route Entry Count
FIB表项数目
【描述】
display icmp statistics命令用来显示ICMP流量统计信息。
相关配置可参考命令display ip interfacereset ip statistics
# 显示ICMP流量统计信息。
<Sysname> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          5                   destination unreachable 0
         source quench 0                   redirects               0
         echo reply    10                  parameter problem       0
         timestamp     0                   information request     0
         mask requests 0                   mask replies            0
         time exceeded 0
  Output:echo          10                  destination unreachable 0
         echo reply    5                   parameter problem       0
         timestamp     0                   information reply       0
         time exceeded 0
表2-3 display icmp statistics命令显示信息描述表
bad formats
输入的格式错误报文数
bad checksum
输入的校验和错误报文数
echo
输入/输出的响应请求报文数
输入/输出的目的不可达报文数
source quench
输入/输出的源站抑制报文数
redirects
输入/输出的重定向报文数
echo reply
输入/输出的响应应答报文数
parameter problem
输入/输出的参数错误报文数
timestamp
输入/输出的时间戳报文数
information request
输入的信息请求报文数
mask requests
输入/输出的掩码请求报文数
mask replies
输入/输出的掩码应答报文数
information reply
输出的信息应答报文数
time exceeded
输入/输出的超时报文数
display ip socket [ socktype sock-type ] [ task-id socket-id ]
sock-type:套接口类型,取值范围为1~3,其中1表示套接字类型为TCP、2表示套接字类型为UDP、3表示套接字类型为raw IP。
task-id:任务号,取值范围为1~100。
socket-id:套接口号,取值范围为0~3072。
【描述】
display ip socket命令用来显示套接口信息。
# 显示所有套接口的信息。
<Sysname> display ip socket
SOCK_STREAM:
Task = FTPS(69), socketid = 1, Proto = 6,
LA = 0.0.0.0:21, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_REUSEADDR SO_KEEPALIVE SO_SETKEEPALIVE,
socket state = SS_PRIV
Task = VTYD(44), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_REUSEPORT SO_SENDVPNID(3073) SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = HTTP(42), socketid = 1, Proto = 6,
LA = 0.0.0.0:80, FA = 0.0.0.0:0,
socket option = SO_ACCEPTCONN SO_REUSEPORT,
socket state = SS_PRIV SS_NBIO
Task = VTYD(44), socketid = 5, Proto = 6,
LA = 192.168.0.52:23, FA = 192.168.0.10:1115,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 714, rb_cc = 0,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_REUSEPORT SO_SENDVPNID(0) SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
SOCK_DGRAM:
Task = DHCP(45), socketid = 1, Proto = 17,
LA = 0.0.0.0:67, FA = 0.0.0.0:0,
sndbuf = 9216, rcvbuf = 41600, sb_cc = 0, rb_cc = 0,
socket option = SO_BROADCAST SO_REUSEPORT SO_UDPCHECKSUM,
Task = DHCC(46), socketid = 1, Proto = 17,
LA = 0.0.0.0:68, FA = 0.0.0.0:0,
socket option = SO_BROADCAST SO_REUSEPORTSO_SENDDATAIF SO_UDPCHECKSUM,
Task = NTPT(43), socketid = 1, Proto = 17,
LA = 0.0.0.0:123, FA = 0.0.0.0:0,
socket option = SO_UDPCHECKSUM,
Task = AGNT(52), socketid = 1, Proto = 17,
LA = 0.0.0.0:161, FA = 0.0.0.0:0,
socket state = SS_PRIV SS_NBIO SS_ASYNC
Task = RDSO(59), socketid = 1, Proto = 17,
LA = 0.0.0.0:1024, FA = 0.0.0.0:0,
Task = TRAP(53), socketid = 1, Proto = 17,
LA = 0.0.0.0:1026, FA = 0.0.0.0:0,
Task = LSSO(57), socketid = 1, Proto = 17,
LA = 0.0.0.0:1645, FA = 0.0.0.0:0,
Task = LSSO(57), socketid = 2, Proto = 17,
LA = 0.0.0.0:1646, FA = 0.0.0.0:0,
Task = RDSO(59), socketid = 2, Proto = 17,
LA = 0.0.0.0:1812, FA = 0.0.0.0:0,
SOCK_RAW:
表2-4 display ip socket命令显示信息描述表
SOCK_STREAM
套接口类型为TCP
SOCK_DGRAM
套接口类型为UDP
SOCK_RAW
套接口类型为raw IP
任务号
socketid
套接口号
Proto
套接口使用的协议号
LA
本端地址与本端端口号
FA
远端地址与远端端口号
sndbuf
套接口的发送缓冲区大小
rcvbuf
套接口的接收缓冲区大小
sb_cc
发送缓存区中现有的数据大小(只有TCP会缓存数据,该值才有用)
rb_cc
接收缓存区中现有的数据大小
socket option
套接口选项
socket state
套接口状态
【描述】
display ip statistics命令用来显示IP流量统计信息。
# 显示IP流量统计信息。
<Sysname> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
表2-5 display ip statistics命令显示信息描述表
Input:
sum
接收报文总数
local
接收的目的地址是本地的报文数
bad protocol
未知协议的报文数
bad format
格式错误的报文数
bad checksum
校验和错误的报文数
bad options
选项错误的报文数
Output:
forwarding
转发的报文数
local
本地发送报文数
dropped
发送时丢弃的报文数
no route
查不到路由的报文数
compress fails
压缩失败的报文数
Fragment:
input
接收的分片报文数
output
发送的分片报文数
dropped
丢弃的分片报文数
fragmented
成功分片的报文数
couldn't fragment
不能分片的报文数
Reassembling:
sum
重组报文总数
timeouts
重组超时的分片报文数
【描述】
display tcp statistics命令用来显示TCP连接的流量统计信息。
相关配置可参考命令display tcp statusreset tcp statistics
# 显示TCP连接的流量统计信息。
<Sysname> display tcp statistics
Received packets:
Total: 753
packets in sequence: 412 (11032 bytes)
window probe packets: 0, window update packets: 0
checksum error: 0, offset error: 0, short error: 0
duplicate packets: 4 (88 bytes), partially duplicate packets: 5 (7 bytes)
out-of-order packets: 0 (0 bytes)
packets of data after window: 0 (0 bytes)
packets received after close: 0
ACK packets: 481 (8776 bytes)
duplicate ACK packets: 7, too much ACK packets: 0
Sent packets:
Total: 665
urgent packets: 0
control packets: 5 (including 1 RST)
window probe packets: 0, window update packets: 2
data packets: 618 (8770 bytes) data packets retransmitted: 0 (0 bytes)
ACK-only packets: 40 (28 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections:0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
表2-6 display tcp statistics命令显示信息描述表
Received packets:
Total
接收的报文总数
packets in sequence
按顺序到达的报文数,括号中为字节数
接收的窗口探测报文数
接收的窗口更新报文数
checksum error
接收的校验错误报文数
offset error
接收的偏移量错误报文数
short error
接收的报文长度太短的报文数
duplicate packets
接收的完全重复报文数,括号中为字节数
接收的部分重复报文数,括号中为字节数
接收的顺序错乱的报文数,括号中为字节数
落在接收窗口外的报文数,括号中为字节数
在连接关闭后到达的报文数
ACK packets
接收的ACK确认报文数,括号中为字节数
接收的重复的ACK确认报文数
接收的确认了未发送数据的ACK报文数
Sent packets:
Total
发送的报文总数
urgent packets
发送的紧急数据报文数
control packets
发送的控制报文数,括号中为包含的重传数据报文数
发送的窗口探测报文数
发送的窗口更新报文数
data packets
发送的数据报文数,括号中为字节数
重发的报文数,括号中为字节数
ACK-only packets
发送的ACK报文数,括号中为延迟ACK报文数
重传定时器超时次数
重传次数超过限制而丢弃的连接数
Keepalive timeout
存活定时器超时次数
keepalive probe
发送存活探测报文数
存活探测失败丢弃连接数
发起连接次数
接受连接次数
已建立连接数
Closed connections
已关闭连接数目,括号中为意外丢弃连接数(收到SYN之后)、主动连接失败数(收到对端SYN之前)
MD5验证丢弃报文数
MD5验证通过报文数
display tcp status
【描述】
display tcp status命令用来显示全部TCP连接的状态,使用户随时监控TCP连接。
# 显示全部TCP连接状态。
<Sysname> display tcp status
*: TCP MD5 Connection
TCPCB            Local Add:port      Foreign Add:port        State
03e37dc4     0.0.0.0:4001            0.0.0.0:0           Listening
04217174     100.0.0.204:23      100.0.0.253:65508   Established
表2-7 display tcp status命令显示信息描述表
如果某个连接前有此标识,则表示该TCP连接是采用MD5加密算法认证的连接
TCPCB
TCP控制块
Local Add:port
本端IP地址及端口号
Foreign Add:port
对端IP地址及端口号
TCP连接的状态
【描述】
display udp statistics命令用来显示UDP流量统计信息。
相关配置可参考命令reset udp statistics
# 显示UDP流量统计信息。
<Sysname> display udp statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
表2-8 display udp statistics命令显示信息描述表
Received packets:
Total
接收的UDP报文总数
checksum error
校验和出错的报文数
shorter than header
报文长度比报文头部短的报文数
报文数据长度超过报文长度的报文数
端口上无socket的单播报文数
端口上无socket的广播和组播报文数
因为socket缓冲区已经满而没有向上层传送的报文数
没有匹配PCB缓存的报文数
Sent packets:
Total
发送UDP报文总数
undo ip forward-broadcast
【描述】
ip forward-broadcast命令用来配置允许接收直连网段广播报文。undo ip forward-broadcast命令用来禁止接收直连网段广播报文。
缺省情况下,不允许接收直连网段广播报文。
# 配置允许接收直连网段广播报文。
[Sysname] ip forward-broadcast
ip forward-broadcast [ acl acl-number ]
VLAN接口视图
acl-number:对直连网段广播报文应用该ACL规则号对应的过滤条件,根据过滤结果决定是否转发该直连网段广播报文。取值范围为2000~3999,其中2000到2999是基本ACL规则,3000到3999是高级ACL规则。
【描述】
ip forward-broadcast命令用来配置允许接口转发直连网段广播报文。undo ip forward-broadcast命令用来禁止接口转发直连网段广播报文。
缺省情况下,不允许接口转发直连网段广播报文。
# 配置允许VLAN接口2转发通过ACL 2001过滤的直连广播报文。
[Sysname] interface Vlan-interface 2
[Sysname-Vlan-interface2] ip forward-broadcast acl 2001
ip redirects enable
undo ip redirects
【描述】
ip redirects enable命令用来使能设备的ICMP重定向报文的发送功能。undo ip redirects命令用来关闭设备的ICMP重定向报文的发送功能。
缺省情况下,ICMP重定向报文发送功能处于使能状态。
# 关闭设备的ICMP重定向报文发送功能。
[Sysname] undo ip redirects
 The function is disabled!
undo ip ttl-expires
【描述】
ip ttl-expires enable命令用来使能设备的ICMP超时报文的发送功能。undo ip ttl-expires命令用来关闭设备的ICMP超时报文的发送功能。
缺省情况下,ICMP超时报文发送功能处于使能状态。
需要注意的是,关闭ICMP超时报文发送功能后,设备不会再发送“TTL超时”ICMP差错报文,但“重组超时”ICMP差错报文仍会正常发送。
# 关闭设备的ICMP超时报文发送功能。
[Sysname] undo ip ttl-expires
undo ip unreachables
【描述】
ip unreachables enable命令用来使能设备的ICMP目的不可达报文的发送功能。undo ip unreachables命令用来关闭设备的ICMP目的不可达报文的发送功能。
缺省情况下,ICMP目的不可达报文发送功能处于使能状态。
需要注意的是,关闭ICMP发送目的不可达报文功能后,设备不会再发送“网络不可达”和“源站路由失败”的ICMP差错报文,但其他目的不可达报文仍会正常发送。
# 关闭设备的ICMP目的不可达报文发送功能。
[Sysname] undo ip unreachables
reset ip statistics
【描述】
reset ip statistics命令用来清除IP报文统计信息。
相关配置可参考命令display ip interfacedisplay ip statistics
# 清除IP统计信息。
<Sysname> reset ip statistics
【描述】
reset tcp statistics命令用来清除TCP连接的流量统计信息。
相关配置可参考命令display tcp statistics
# 清除TCP连接的流量统计信息。
<Sysname> reset tcp statistics
【描述】
reset udp statistics命令用来清除UDP流量统计信息。
# 清除UDP流量统计信息。
<Sysname> reset udp statistics
undo tcp timer fin-timeout
time-value:TCP finwait定时器值,取值范围为76~3600,单位为秒。
【描述】
tcp timer fin-timeout命令用来设置TCP finwait定时器。undo tcp timer fin-timeout命令用来恢复缺省情况。
缺省情况下,TCP finwait定时器的值为675秒。
相关配置可参考命令tcp timer syn-timeouttcp window
# 配置TCP finwait定时器的值为800秒。
[Sysname] tcp timer fin-timeout 800
undo tcp timer syn-timeout
time-value:TCP synwait定时器值,取值范围为2~600,单位为秒。
【描述】
tcp timer syn-timeout命令用来设置TCP synwait定时器。undo tcp timer syn-timeout命令用来恢复缺省情况。
缺省情况下,TCP synwait定时器的值为75秒。
相关配置可参考命令tcp timer fin-timeouttcp window
# 设置TCP synwait定时器的值为80秒。
[Sysname] tcp timer syn-timeout 80
2.1.20  tcp window
tcp window window-size
undo tcp window
window-size:TCP连接的收发缓冲区大小,取值范围为1~32,单位为KB(千字节)。
【描述】
tcp window命令用来设置TCP连接的收发缓冲区大小。undo tcp window命令用来恢复缺省情况。
缺省情况下,TCP连接的收发缓冲区大小为8KB。
相关配置可参考命令tcp timer fin-timeouttcp timer syn-timeout
# 设置TCP连接的收发缓冲区大小为3KB。
[Sysname] tcp window 3
