A. Plenty of interfaces to connect end users' computers
B. Access security control
C. High-speed packet exchange
D. Complex routing policies
A. The IP addresses of hosts in different sub VLANs belong to the same network segment. These hosts can directly communicate with each other through Layer 2 forwarding.
B. The IP addresses of hosts in different sub VLANs belong to the same network segment, but they cannot directly communicate with each other because they are isolated from each other by the sub VLANs.
C. Layer 2 isolation applies between hosts in different sub VLANs. In terms of Layer 3, these hosts can communicate with each other by deploying the common proxy ARP technology on super VLAN interfaces.
D. Layer 2 isolation applies between hosts in different sub VLANs. In terms of Layer 3, these hosts can communicate with each other by deploying the local proxy ARP technology on super VLAN interfaces.
A. The switch periodically sends MAC address detection packets to the PC.
B. When a PC sends a data frame on the network, the switch records the source MAC address.
C. When the switch receives an ARP reply packet from a PC, it records the source MAC address.
D. The PC periodically sends MAC address packets to the switch.
A. We should adjust the Hello Time to the maximum value and the Forward Delay to the minimum value, so that we can reduce the number of Hello messages on the network and the ports can enter forwarding status within the shortest possible time.
B. We should adjust the Max Age to the minimum value to shorten the BPDU aging time and discover link faults in time.
C. We can set the Hello Time to an appropriate value to reduce the spanning tree computation loss and enhance the robustness of the spanning tree.
An excessively large or small value of the Hello Time will affect spanning tree computation/generation and network stability.
D. It is not recommended that the Hello Time, Forward Delay, and Max Age be manually configured. The switch will automatically set the timer values according to the network diameter.
A. Broadcast storm
B. Port rate changes
C. Port duplex mode changes
D. MAC address learning mistakes
A. RSTP is defined in the IEEE 802.1D standard, and its protocol idea is the same as STP, but it is improved in convergence time.
B. The switch running RSTP can work with the switch running STP and improve the convergence time of STP.
C. RSTP can balance the loads of different VLANs among Trunk links based on STP.
D. RSTP has all the features of STP, but it uses only one type of BPDU.
A. BPDU protection is configured in the edge port view.
B. The root bridge protection command is effective only after it is configured for the root bridge.
C. The loop protection command needs to be configured for each port in the physical loop.
D. After the TC protection threshold is configured, if the number of TC packets received by the device within 10s (default period) exceeds the threshold, the device will not delete the address entries within this period.
A. Switches in the same MST region must have the same VLAN and instance mapping relationship.
B. If the MST region names configured for two switches are different, the two switches must belong to different MST regions.
C. The MSTP switches need to exchange the complete information about mapping between the VLANs and the instances. If the mappings are different, the switches do not belong to the same MST region.
D. The protocol running among the MST regions is RSTP.
A. UDP 3785
B. TCP 3785
C. UDP 4784
D. UDP 3784
A. 3 seconds
B. 5 seconds
C. 12 seconds
D. 20 seconds
A. 232.255.255.255
B. 242.255.255.250
C. 239.255.255.255
D. 224.0.0.13
A. 224.0.0.1
B. 224.0.0.2
C. 224.0.0.13
D. 224.0.0.18
A. Public key authentication
B. Password authentication
C. Private key authentication
D. Random word authentication
A. Both the NMS workstation and the SNMP agent listen to UDP port 161.
B. Both the NMS workstation and the SNMP agent listen to UDP port 162.
C. The NMS workstation listens to UDP port 161, and the SNMP agent listens to UDP port 162.
D. The NMS workstation listens to UDP port 162, and the SNMP agent listens to UDP port 161.
A. Local
B. Remote-source
C. Remote-destination
D. Remote
